SET/RESET
Function
This command is used to dynamically add, update, display, or reset Hudi parameters without restarting the driver.
Syntax
  • Add or update a parameter value:
    SET parameter_name=parameter_value
    This command is used to add or update the value of parameter_name.
  • Display a parameter value:
    SET parameter_name
    This command is used to display the value of parameter_name.
  • Display session parameters:
    SET
    This command is used to display all supported session parameters.
  • Display session parameters along with usage details:
    SET -v
    This command is used to display all supported session parameters and their usage details.
  • Reset parameter values:
    RESET
    This command is used to reset all session parameters.
Parameter Description
Table 1 Parameters
parameter_name
Name of the parameter to be dynamically added, updated, or displayed.
parameter_value
New value to be set for parameter_name.
Precautions
The following table lists the properties to be used in the SET or RESET commands.
Table 2 Properties
Property
hoodie.insert.shuffle.parallelism
Degree of parallelism (DOP) of Spark shuffle for writing data in insert mode.
hoodie.upsert.shuffle.parallelism
DOP of Spark shuffle for writing data in upsert mode.
hoodie.delete.shuffle.parallelism
DOP of Spark shuffle for deleting data in delete mode.
hoodie.sql.insert.mode
Insert mode. The value can be strict, non-strict, or upsert.
hoodie.sql.bulk.insert.enable
Whether to enable bulk insert.
spark.sql.hive.convertMetastoreParquet
Converts the parquet table into a data source table for reading. If the provider of Hudi is Hive and Spark SQL or Spark Beeline is used to read data, set this parameter to false.
Examples
  • Add or Update command:
    set hoodie.insert.shuffle.parallelism = 100;
    set hoodie.upsert.shuffle.parallelism = 100;
    set hoodie.delete.shuffle.parallelism = 100;
  • Reset command:
    RESET
System Response
  • You can view the success result in driver logs.
  • You can view the failure result on the UI.
