Updated on 2026-06-27 GMT+08:00
CREATE TABLE
In MRS 3.6.0-LTS.1, Hudi table creation parameters are simplified. For details, see Simplifying Hudi Parameters.
Function
This command is used to create a Hudi table by specifying the list of fields along with the table options.
Syntax
CREATE TABLE [ IF NOT EXISTS] [database_name.]table_name
[ (columnTypeList)]
USING hudi
[ COMMENT table_comment ]
[ LOCATION location_path ]
[ OPTIONS (options_list) ]
Parameter Description
Table 1 Parameters
database_name
Database name that contains letters, digits, and underscores (_).
table_name
Database table name that contains letters, digits, and underscores (_).
columnTypeList
List of comma-separated columns with data types. The column name contains letters, digits, and underscores (_).
using
Uses hudi to define and create a Hudi table.
table_comment
Description of the table.
location_path
HDFS path. If this parameter is set, the Hudi table will be created as an external table.
options_list
List of Hudi table options.
Table 2 Table options
primaryKey
Mandatory. Primary key name. Separate multiple primary key names with commas (,).
type
Type of the table. "cow" indicates a copy-on-write (COW) table, and "mor" indicates a merge-on-read (MOR) table. If this parameter is not specified, the default value is "cow".
preCombineField
Pre-Combine field in the table, which is used to identify the sequence of two data records with the same primary key. This field is mandatory. The field is used together with the primary key to merge data by primary key.
payloadClass
Logic that uses preCombineField for data filtering. DefaultHoodieRecordPayload is used by default. In addition, multiple preset payloads are provided, such as OverwriteNonDefaultsWithLatestAvroPayload, OverwriteWithLatestAvroPayload, and EmptyHoodieRecordPayload.
useCache
Whether to cache table relationships in Spark. This parameter does not need to be configured. This parameter is set to false by default to support the incremental view query of the COW table in Spark SQL.
Examples
  • Create a non-partitioned table.
    create table if not exists hudi_table0 (
    id int,
    name string,
    price double
    ) using hudi
    options (
    type = 'cow',
    primaryKey = 'id',
    preCombineField = 'price'
  • Create a partitioned table.
    create table if not exists hudi_table_p0 (
    id bigint,
    name string,
    ts bigint,
    dt string,
    hh string
    ) using hudi
    options (
    type = 'cow',
    primaryKey = 'id',
    preCombineField = 'ts'
    partitioned by (dt, hh);
  • Create a table in a specified path.
    create table if not exists h3(
    id bigint,
    name string,
    price double
    ) using hudi
    options (
    primaryKey = 'id',
    location '/path/to/hudi/h3';
  • Create a table and specify table attributes.
    id bigint,
    name string,
    price double
    ) using hudi
    options (
    primaryKey = 'id',
    type = 'mor',
    hoodie.cleaner.fileversions.retained = '20',
    hoodie.keep.max.commits = '20'
Precautions
  • Currently, only the following types of data support the configuration of default values: int, bigint, float, double, decimal, string, date, timestamp, boolean, and binary.
  • You must specify primaryKey and preCombineField for Hudi tables.
  • When you create a table in a specified path and there already are Hudi tables in the path, you do not need to specify columns during table creation.
  • In MRS 3.5.0-LTS or later: It is recommended that you use lowercase letters for Hudi column names (to ensure case compatibility between engines). The Hudi column names cannot start with digits.
Response
The table is successfully created, and the success message is logged in the system.
