Creating a FlinkServer Job to Write Data to an HDFS
This section applies to MRS 3.1.2 or later clusters.
This section describes the data definition language (DDL) of HDFS as a sink table, as well as the WITH parameters and example code for creating a sink table, and provides guidance on how to perform operations on the FlinkServer job management page.
If your Kafka cluster is in security mode, the following example SQL statements can be used.
  • The HDFS, Yarn, and Flink services have been installed in a cluster.
  • The client that contains the HDFS service has been installed, for example, in the /opt/client directory.
  • You have created a user assigned with the FlinkServer Admin Privilege (for example, flink_admin) for accessing the Flink web UI by referring to Creating a FlinkServer Role.
Creating a Job
  1. Log in to Manager as user flink_admin and choose Cluster > Services > Flink. In the Basic Information area, click the link on the right of Flink WebUI to access the Flink web UI.
  2. Create a Flink SQL job by referring to Creating a FlinkServer Job. On the job development page, configure the job parameters and start the job.
    In Basic Parameter, select Enable CheckPoint, set Time Interval(ms) to 60000, and retain the default value for Mode.
    CREATE TABLE kafka_table (
      user_id STRING,
      order_amount DOUBLE,
      log_ts TIMESTAMP(3),
      WATERMARK FOR log_ts AS log_ts - INTERVAL '5' SECOND
    ) WITH (
      'connector' = 'kafka',
      'topic' = 'user_source',
      'properties.bootstrap.servers' = 'IP address of the Kafka broker instance:Kafka port number',
      'properties.group.id' = 'testGroup',
      'scan.startup.mode' = 'latest-offset',
      'format' = 'csv',
       --Ignore the CSV data that fails to be parsed.
      'csv.ignore-parse-errors' = 'true',--If the data is in JSON format, set json.ignore-parse-errors to true.
      'properties.sasl.kerberos.service.name' = 'kafka',--This parameter is not required for clusters in normal mode. Delete the comma (,) in the previous line.
      'properties.security.protocol' = 'SASL_PLAINTEXT',--This parameter is not required for clusters in normal mode.
      'properties.kerberos.domain.name' = 'hadoop.System domain name'--This parameter is not required for clusters in normal mode.
    CREATE TABLE fs_table (
      user_id STRING,
      dt STRING,
      `hour` STRING
    ) PARTITIONED BY (dt, `hour`) WITH ( --Date-specific file partitioning
      'connector'='filesystem',
      'path'='hdfs:///sql/parquet',
      'format'='parquet',
      'sink.partition-commit.delay'='0 s',-- Partitions will not be committed before the delay time. If the files are partitioned by day, set this parameter to '1 d'. If the files are partitioned by hour, set this parameter to '1 h'.
      'sink.partition-commit.policy.kind'='success-file'
    -- streaming sql, insert into file system table
    INSERT INTO fs_table SELECT user_id, order_amount, DATE_FORMAT(log_ts, 'yyyy-MM-dd'), DATE_FORMAT(log_ts, 'HH') FROM kafka_table;
    • Kafka port
      • Value of sasl.port when Authentication Mode of the cluster is Security Mode, 21007 by default.
      • Value of port when Authentication Mode of the cluster is Normal Mode, 9092 by default. If the port number is set to 9092, set allow.everyone.if.no.acl.found to true. The procedure is as follows:
        Log in to FusionInsight Manager and choose Cluster > Services > Kafka. On the page that is displayed, click the Configurations tab then the All Configurations sub-tab. On the displayed page, search for allow.everyone.if.no.acl.found, set it to true, and click Save.
    • System domain name: You can log in to FusionInsight Manager, choose System > Permission > Domain and Mutual Trust, and check the value of Local Domain.
  3. On the job management page, check whether the job status is Running.
  4. Execute the following commands to view the topic and write data to Kafka. For details, see Managing Messages in Kafka Topics.
    ./kafka-topics.sh --list --bootstrap-server Service IP address of the Kafka Broker instance:Kafka port --command-config Client directory/Kafka/kafka/config/client.properties
    sh kafka-console-producer.sh --broker-list IP address of the node where Kafka instances reside:Kafka port number --topic Topic name --producer.config Client directory/Kafka/kafka/config/producer.properties
    For example, if the topic name is user_source, the script is sh kafka-console-producer.sh --broker-list IP address of the node where Kafka instances are deployed:Kafka port --topic user_source --producer.config /opt/client/Kafka/kafka/config/producer.properties
    Enter the message content.
    3,3333,"2021-09-10 14:00"
    4,4444,"2021-09-10 14:01"
    Press Enter to send the message.
  5. Run the following command to check whether data is written from the HDFS directory to the sink table:
    hdfs dfs -ls -R /sql/parquet
Interconnecting Flink with HDFS Partitions
  • Customized partitioning
    Flink's file system supports partitions in the standard Hive format. You do not need to register partitions with a table catalog. Partitions are inferred based on the directory structure.
    For example, a table that is partitioned based on the following directory is inferred to contain datetime and hour partitions.
    path
    └── datetime=2021-09-03
        └── hour=11
            ├── part-0.parquet
            ├── part-1.parquet
        └── hour=12
            ├── part-0.parquet
    └── datetime=2021-09-24
        └── hour=6
            ├── part-0.parquet
  • Rolling policy of partition files
    Data in the partition directories is split into part files. Each partition contains at least one part file, which is used to receive the data written by the subtask of the sink.
    The following parameters describe the rolling policies of partition files.
    Table 1 Rolling policy of partition files
    Default Value
    Type
    sink.rolling-policy.file-size
    128 MB
    MemorySize
    Maximum size of a partition file before it is rolled.
    sink.rolling-policy.rollover-interval
    30 minutes
    Duration
    Maximum duration that a partition file can stay open before it is rolled.
    sink.rolling-policy.check-interval
    1 minute
    Duration
    Interval for checking time-based rolling policies.
  • File merging
    File compression is supported, allowing applications to have a shorter checkpoint interval without generating a large number of files.
    Only files in a single checkpoint are compressed. That is, the number of generated files is at least the same as the number of checkpoints. Files are invisible before merged. They are visible after both the checkpoint and compression are complete. If file compression takes too much time, the checkpoint will be prolonged.
    Table 2 File merging in partition directories
    Default Value
    Type
    auto-compaction
    false
    Boolean
    Whether to enable automatic compression. Data will be written to temporary files. After a checkpoint is complete, the temporary files generated by the checkpoint are compressed. These temporary files are invisible before compression.
    compaction.file-size
    none
    MemorySize
    Size of the target file to be compressed. The default value is the size of the file to be rolled.
  • Partition commit
    After a file is written to a partition, for example, a partition is added to Hive metastore (HMS) or a _SUCCESS file is written to a directory, the downstream application needs to be notified. Triggers and policies are used to commit partition files.
    Table 3 Trigger parameters for committing partition files
    Default Value
    Type
    sink.partition-commit.trigger
    process-time
    String
    • process-time: System time of the compute node. It does not need to extract the partition time or generate watermarks. If the current system time exceeds the system time generated when a partition is created plus the delay time, the partition should be submitted.
    • partition-time: Time extracted from the partition. Watermarks are required. If the time for generating watermarks exceeds the time extracted from a partition plus the delay time, the partition should be submitted.
    0 s
    Duration
    Partitions will not be committed before the delay time. If it is a daily partition, the value is 1 d. If it is an hourly one, the value is 1 h.
    Table 4 Policy parameters for committing partition files
    Configuration Item
    Default Value
    Type
    String
    Policy for committing partitions:
    • metastore: used to add partitions to metastore. Only Hive tables support the metastore policy. The file system manages partitions based on the directory structure.
    • success-file: used to add success-file files to a directory.
    • The two policies can be configured at the same time, that is, 'sink.partition-commit.policy.kind'='metastore,success-file'.
    sink.partition-commit.policy.class
    String
    Class that implements partition commit policy interfaces.
    This parameter takes effect only in the customized submission policies.
    sink.partition-commit.success-file.name
    _SUCCESS
    String
    File name of the success-file partition commit policy. The default value is _SUCCESS.
