Adding a Ranger Access Permission Policy for CDL
Ranger administrators can use Ranger to configure creation, execution, query, and deletion permissions for CDL users.
- The Ranger service has been installed and is running properly.
- You have created users, user groups, or roles for which you want to configure permissions.
- Log in to the Ranger web UI as the Ranger administrator. For details, see Logging In to the Ranger Web UI.
- On the home page, click the component plug-in name in the CDL area, for example, CDL.
- Click Add New Policy to add a CDL permission control policy.
- Configure the parameters listed in the table below based on the service demands.
Table 1 CDL permission parameters Parameter
Policy Type
Policy type. An access policy controls permissions based on specific resource paths.
Policy Conditions
IP address filtering policy, which can be customized. You can enter one or more IP addresses or IP address segments. An IP address can contain the wildcard character (*), for example, 192.168.1.10,192.168.1.20 or 192.168.1.*.
Policy Name
Policy name, which can be customized and must be unique in the service.
Policy Label
A label specified for the current policy. You can search for reports and filter policies based on labels.
job
Name of the job applicable to the current policy. You can enter multiple values. The value can contain wildcards, such as test, test*, and *.
The Include policy applies to the current input object, and the Exclude policy applies to objects other than the current input object.
Policy description.
Audit Logging
Whether to audit the policy.
Allow Conditions
Permission and exception conditions allowed by a policy. The priority of an exception condition is higher than that of a normal condition.
In the Select Role, Select Group, and Select User columns, select the role, user group, or user to which you want to assign permissions.
Click Add Conditions to add the IP address range to which the policy applies and click Add Permissions to add corresponding permissions.
- Create: creation permission
- Execute: execution permission
- Delete: deletion permission
- Update: update permission
- Get: permission to obtain information
- Select/Deselect All: permission to select or deselect all
To add multiple permission control rules, click
.If users or user groups in the current condition need to manage this policy, select Delegate Admin. These users will become the agent administrators. The agent administrators can update and delete this policy and create sub-policies based on the original policy.
Deny Conditions
Deny condition. It specifies the permissions and exceptions to be denied in the policy. The configuration method is the same as that of Allow Conditions. Deny conditions take precedence over the allowed conditions configured in Allow Conditions.
Table 2 Setting user permissions Scenario
Role Authorization
Setting the CDL administrator permission
- Select the policies whose Policy Name is all - job, all - link, all - driver or all - env, and click
to edit the policies. - In the Allow Conditions area, select a user from the Select User drop-down list.
- Click Add Permissions and select Select/Deselect All.
Setting the permission to manage a CDL job
- Select a CDL job name from the job drop-down list.
Setting the permission to create a CDL job
- Click Add Permissions and select Create. NOTE:
By default, all users have the permission to create a CDL job.
Setting the permission to delete a CDL job
- Click Add Permissions and select Delete.
Setting the permission to obtain information about a CDL job
- Click Add Permissions and select Get.
Setting the permission to execute a CDL job
- Click Add Permissions and select Execute.
Setting the permission to manage a CDL data link
- Select the CDL data link name on the right of the link drop-down list.
Setting the permission to create a CDL data link
By default, all users have the permission to create CDL data links.
Setting the permission to delete a CDL data link
Setting the permission to update a CDL data link
- Click Add Permissions and select Update.
Setting the permission to obtain information about a CDL data link
Setting the permission to manage a CDL driver
- Select the CDL driver name on the right of the driver drop-down list.
Setting the permission to delete a CDL driver
Setting the permission to update a CDL driver
Setting the permission to obtain information about a CDL driver
Setting the permission to manage a CDL environment variable
- Select the CDL environment variable name on the right of the env drop-down list.
Setting the permission to create a CDL environment variable
By default, all users have the permission to create a CDL environment variable.
Setting the permission to delete a CDL environment variable
Setting the permission to update a CDL environment variable
Setting the permission to obtain information about a CDL environment variable
- (Optional) Configure the policy validity period. Click Add Validity period in the upper right corner of the page, set Start Time and End Time, and select Time Zone. Click Save. To add multiple policy validity periods, click
. To delete a policy validity period, click
. - Click Add to view basic information about the policy in the policy list. After the policy takes effect, check whether the related permissions are normal.
To disable a policy, click
and set the policy to Disabled.If a policy is no longer used, click
to delete it.
