Importing and Exporting Data Using the ClickHouse Client
This section describes the basic syntax and instructions for using the ClickHouse client to import and export file data.
Using the ClickHouse Client to Import and Export Data
- Importing data in CSV format
clickhouse client --host Host name or IP address of the ClickHouse instance --database Database name --port Port number --secure --format_csv_delimiter="CSV file delimiter" --query="INSERT INTO Table name FORMAT CSV" < Host path where the CSV file is stored
Exampleclickhouse client --host 10.5.208.5 --database testdb --port 9440 --secure --format_csv_delimiter="," --query="INSERT INTO testdb.csv_table FORMAT CSV" < /opt/data
You need to create a table in advance.
- Exporting data in CSV format
Exporting data files in CSV format may cause CSV injection. Exercise caution when performing this operation.
clickhouse client --host Host name or IP address of the ClickHouse instance --database Database name --port Port number -m --secure --query="SELECT * FROM Table name" > CSV file export path
Exampleclickhouse client --host 10.5.208.5 --database testdb --port 9440 -m --secure --query="SELECT * FROM test_table" > /opt/test
- Importing data in Parquet format
cat Parquet file | clickhouse client --host Host name or IP address of the ClickHouse instance --database Database name --port Port number -m --secure --query="INSERT INTO Table name FORMAT Parquet"
Examplecat /opt/student.parquet | clickhouse client --host 10.5.208.5 --database testdb --port 9440 -m --secure --query="INSERT INTO parquet_tab001 FORMAT Parquet"
- Exporting data in Parquet format
clickhouse client --host Host name or IP address of the ClickHouse instance --database Database name --port Port number -m --secure --query="select * from Table name FORMAT Parquet" > Parquet file export path
Exampleclickhouse client --host 10.5.208.5 --database testdb --port 9440 -m --secure --query="select * from test_table FORMAT Parquet" > /opt/student.parquet
- Importing data in ORC format
cat ORC file path | clickhouse client --host Host name or IP address of the ClickHouse instance --database Database name --port Port number -m --secure --query="INSERT INTO Table name FORMAT ORC"
Examplecat /opt/student.orc | clickhouse client --host 10.5.208.5 --database testdb --port 9440 -m --secure --query="INSERT INTO orc_tab001 FORMAT ORC" # Data in the ORC format can be exported from HDFS. For example: hdfs dfs -cat /user/hive/warehouse/hivedb.db/emp_orc/000000_0_copy_1 | clickhouse client --host 10.5.208.5 --database testdb --port 9440 -m --secure --query="INSERT INTO orc_tab001 FORMAT ORC"
- Exporting data in ORC format
clickhouse client --host Host name or IP address of the ClickHouse instance --database Database name --port Port number -m --secure --query="select * from Table name FORMAT ORC" > ORC file export path
Exampleclickhouse client --host 10.5.208.5 --database testdb --port 9440 -m --secure --query="select * from csv_tab001 FORMAT ORC" > /opt/student.orc
- Importing data in JSON format
INSERT INTO Table name FORMAT JSONEachRow JSON string 1 JSON string 2
ExampleINSERT INTO test_table001 FORMAT JSONEachRow {"PageViews":5, "UserID":"4324182021466249494", "Duration":146,"Sign":-1} {"UserID":"4324182021466249494","PageViews":6,"Duration":185,"Sign":1} - Exporting data in JSON format
clickhouse client --host Host name or IP address of the ClickHouse instance --database Database name --port Port number -m --secure --query="SELECT * FROM Table name FORMAT JSON|JSONEachRow|JSONCompact|..." > JSON file export path
Example# Export JSON file. clickhouse client --host 10.5.208.5 --database testdb --port 9440 -m --secure --query="SELECT * FROM test_table FORMAT JSON" > /opt/test.json # Export json(JSONEachRow). clickhouse client --host 10.5.208.5 --database testdb --port 9440 -m --secure --query="SELECT * FROM test_table FORMAT JSONEachRow" > /opt/test_jsoneachrow.json # Export json(JSONCompact). clickhouse client --host 10.5.208.5 --database testdb --port 9440 -m --secure --query="SELECT * FROM test_table FORMAT JSONCompact" > /opt/test_jsoncompact.json
