ALTER TABLE: Modifying a Table Structure
This section describes the basic syntax and usage of the SQL statement for modifying a table structure in ClickHouse.
Basic Syntax
ALTER TABLE [database_name].name [ON CLUSTER cluster] ADD|DROP|CLEAR|COMMENT|MODIFY COLUMN ...
   ALTER supports only *MergeTree, Merge, and Distributed engine tables.
Example
-- Add the test01 column to the t1 table. ALTER TABLE t1 ADD COLUMN test01 String DEFAULT 'defaultvalue'; -- Query the modified table t1. desc t1 ┌─name────┬─type─┬─default_type─┬─default_expression ┬─comment─┬─codec_expression─┬─ttl_expression─┐ │ id │ UInt8 │ │ │ │ │ │ │ name │ String │ │ │ │ │ │ │ address │ String │ │ │ │ │ │ │ test01 │ String │ DEFAULT │ 'defaultvalue' │ │ │ │ └───────┴────┴────────┴────────── ┴───── ┴──────────┴─────────┘ -- Change the type of the name column in the t1 table to UInt8. ALTER TABLE t1 MODIFY COLUMN name UInt8; -- Query the modified table t1. desc t1 ┌─name────┬─type─┬─default_type─┬─default_expression ┬─comment─┬─codec_expression─┬─ttl_expression─┐ │ id │ UInt8 │ │ │ │ │ │ │ name │ UInt8 │ │ │ │ │ │ │ address │ String │ │ │ │ │ │ │ test01 │ String │ DEFAULT │ 'defaultvalue' │ │ │ │ └───────┴────┴────────┴────────── ┴───── ┴──────────┴─────────┘ -- Delete the test01 column from the t1 table. ALTER TABLE t1 DROP COLUMN test01; -- Query the modified table t1. desc t1 ┌─name────┬─type─┬─default_type─┬─default_expression ┬─comment─┬─codec_expression─┬─ttl_expression─┐ │ id │ UInt8 │ │ │ │ │ │ │ name │ UInt8 │ │ │ │ │ │ │ address │ String │ │ │ │ │ │ └───────┴────┴────────┴────────── ┴───── ┴──────────┴─────────┘
