On this page
SELECT: Querying Table Data
Updated on 2023-04-28 GMT+08:00
This section describes the basic syntax and usage of the SQL statement for querying table data in ClickHouse.
Basic Syntax
SELECT [DISTINCT] expr_list
[FROM [database_name.]table | (subquery) | table_function] [FINAL]
[SAMPLE sample_coeff]
[ARRAY JOIN ...]
[GLOBAL] [ANY|ALL|ASOF] [INNER|LEFT|RIGHT|FULL|CROSS] [OUTER|SEMI|ANTI] JOIN (subquery)|table (ON <expr_list>)|(USING <column_list>)
[PREWHERE expr]
[WHERE expr]
[GROUP BY expr_list] [WITH TOTALS]
[HAVING expr]
[ORDER BY expr_list] [WITH FILL] [FROM expr] [TO expr] [STEP expr]
[LIMIT [offset_value, ]n BY columns]
[LIMIT [n, ]m] [WITH TIES]
[UNION ALL ...]
[INTO OUTFILE filename]
[FORMAT format]
Example
-- View ClickHouse cluster information.
select * from system.clusters;
-- View the macros set for the current node.
select * from system.macros;
-- Check the database capacity.
select
sum(rows) as "Total number of rows",
formatReadableSize(sum(data_uncompressed_bytes)) as "Original size",
formatReadableSize(sum(data_compressed_bytes)) as "Compression size",
round(sum(data_compressed_bytes) / sum(data_uncompressed_bytes) * 100,
0) "Compression rate"
from system.parts;
-- Query the capacity of the test table. Add or modify the where clause based on the site requirements.
select
from system.parts
where table in ('test')
and partition like '2020-11-%'
group by table;
