Adding a ClickHouse Data Source
Updated on 2024-10-25 GMT+08:00
In a ClickHouse data source, a schema or database cannot contain tables with the same name but different case formats, for example, cktable (lowercase), CKTABLE (uppercase), and CKtable (uppercase and lowercase). Otherwise, HetuEngine cannot use the tables in the schema or database.
Procedure for Adding a ClickHouse Data Source
  1. Log in to FusionInsight Manager as a HetuEngine administrator and choose Cluster > Services > HetuEngine. The HetuEngine service page is displayed.
  2. In the Basic Information area on the Dashboard tab page, click the link next to HSConsole WebUI. The HSConsole page is displayed.
  3. Choose Data Source and click Add Data Source. On the Add Data Source page that is displayed, configure parameters.
    1. In the Basic Configuration area, configure Name and choose JDBC > ClickHouse for Data Source Type.
    2. Configure parameters in the ClickHouse Configuration area. For details, see Table 1.
      Table 1 ClickHouse Configuration
      Example Value
      Driver
      The default value is clickhouse.
      clickhouse
      JDBC URL
      JDBC URL of the ClickHouse data source.
      • If the ClickHouse data source uses IPv4, the format is jdbc:clickhouse://<host>:<port>.
      • If the ClickHouse data source uses IPv6, the format is jdbc:clickhouse://[<host>]:<port>.
      • To obtain the value of <host>, log in to Manager of the cluster where the ClickHouse data source is located, choose Cluster > Services > ClickHouse > Instance, and view the ClickHouseBalancer service IP address. Select an IP address randomly. Currently, only one IP address can be entered.
      • To obtain the value of <port>, log in to Manager of the cluster where the ClickHouse data source is located, click Cluster, choose Services > ClickHouse, click Configurations, and click All Configurations. If the ClickHouse data source is in security mode, check the HTTPS port number of the ClickHouseBalancer instance, that is, the value of lb_https_port. If the ClickHouse data source is in normal mode, check the HTTP port number of the ClickHouseBalancer instance, that is, the value of lb_http_port.
      jdbc:clickhouse://10.162.156.243:21426 or jdbc:clickhouse://10.162.156.243:21425
      Username
      Username used for connecting to the ClickHouse data source.
      Change the value based on the username being connected with the data source.
      Password
      User password used for connecting to the ClickHouse data source.
      Change the value based on the user password for connecting to the data source.
      Case-sensitive Table/Schema Name
      Whether to support case-sensitive schema/table names of the data source.
      HetuEngine supports case-sensitive schema/table names of the data source.
      • No: If multiple table names exist in the same schema of a data source, for example, cktable (lowercase), CKTABLE (uppercase), and CKtable (lowercase and uppercase), only cktable (lowercase) can be used by HetuEngine.
      • Yes: Only one table name can exist in the same schema of the data source, for example, cktable (lowercase), CKTABLE (uppercase), or CKtable (lowercase and uppercase). Otherwise, all tables in the schema cannot be used by HetuEngine.
    3. (Optional) Customize the configuration.
      You can click Add to add custom configuration parameters. Configure custom parameters of the ClickHouse data source. For details, see Table 2.
      Table 2 Custom parameters of the ClickHouse data source
      Example Value
      use-connection-pool
      Whether to use the JDBC connection pool.
      true
      jdbc.connection.pool.maxTotal
      Maximum number of connections in the JDBC connection pool.
      8
      jdbc.connection.pool.maxIdle
      Maximum number of idle connections in the JDBC connection pool.
      8
      jdbc.connection.pool.minIdle
      Minimum number of idle connections in the JDBC connection pool.
      0
      jdbc.connection.pool.testOnBorrow
      Whether to check the connection validity when using a connection obtained from the JDBC connection pool.
      false
      clickhouse.map-string-as-varchar
      Whether to convert the ClickHouse data source of the String and FixedString types to the Varchar type.
      Default value: true
      true
      clickhouse.socket-timeout
      Timeout interval for connecting to the ClickHouse data source.
      Unit: millisecond
      Default value: 120000
      120000
      case-insensitive-name-matching.cache-ttl
      Timeout interval for caching case-sensitive names of schemas or tables of the data sources.
      Unit: minute
      Default value: 1
      You can click Delete to delete custom configuration parameters.
    1. Click OK.
  4. Log in to the node where the cluster client is located and run the following commands to switch to the client installation directory and authenticate the user:
    cd /opt/client
    source bigdata_env
    kinit User performing HetuEngine operations (If the cluster is in normal mode, skip this step.)
  5. Run the following command to log in to the catalog of the data source:
    hetu-cli --catalog Data source name --schema Database name
    For example, run the following command:
    hetu-cli --catalog clickhouse_1 --schema default
  6. Run the following command. If the database table information can be viewed or no error is reported, the connection is successful.
    show tables;
ClickHouse Data Type Mapping
Mapping from ClickHouse data types to HetuEngine data types
HetuEngine Data Type
BOOLEAN
BOOLEAN
UInt8
SMALLINT
UInt16
INTEGER
UInt32
BIGINT
UInt64
DECIMAL(20, 0)
Int8
TINYINT
Int16
SMALLINT
Int32
INTEGER
Int64
BIGINT
Float32
REAL
Float64
DOUBLE
Decimal(P, S)
DECIMAL(P, S)
Decimal32(S)
DECIMAL(P, S)
Decimal64(S)
DECIMAL(P, S)
Decimal128(S)
DECIMAL(P, S)
IPv4
VARCHAR
IPv6
VARCHAR
UUID
VARCHAR
Enum8
VARCHAR
Enum16
VARCHAR
String
VARCHAR / VARBINARY
Fixedstring(N)
VARCHAR / VARBINARY
Date
DATE
DateTime
TIMESTAMP
Performance Optimization
  • Subquery pushdown
    The query pushdown function is supported to improve query speed.
  • Scalar UDF pushdown
    The Scalar UDF pushdown function is enabled by default. Before you use this function, create a mapping function in HetuEngine as needed.
Constraints on ClickHouse Data Source
  • HetuEngine supports interconnecting with ClickHouse using the following SQL syntaxes: SHOW CATALOGS, SCHEMAS, TABLES, COLUMNS, DESCRIBE, USE, and SELECT TABLE/VIEW.
  • Tables and views that support interconnection between HetuEngine and ClickHouse:
    Item
    Supported Table and View
    Tables that support interconnection between HetuEngine and ClickHouse
    Local table (MergeTree)
    Replicated table (ReplicatedReplacingMergeTree)
    Distributed table
    Views that support interconnection between HetuEngine and ClickHouse
    Normal view
    Materialized view
