Reading the Hudi COW Table View
Copy-on-write (COW) tables store data in Parquet files. Internal update operations require rewriting the original Parquet files.
- Advantage: It is efficient because only one data file in the corresponding partition needs to be read.
- Disadvantage: During data writes, a previous copy must be copied to generate a new data file. This process is time-consuming. Therefore, the data read by the request is delayed.
Example: Reading a Hudi COW Table
- Reading the real-time view (using Hive and SparkSQL as an example): Directly read the Hudi table stored in Hive and use ${table_name} to specify the table name.
select count(*) from ${table_name}; - Reading the real-time view (using the Spark DataSource API as an example): This is similar to reading a common DataSource table.
The query type QUERY_TYPE_OPT_KEY must be set to QUERY_TYPE_SNAPSHOT_OPT_VAL. Use ${table_name} to specify the table name.
spark.read.format("hudi") .option(QUERY_TYPE_OPT_KEY, QUERY_TYPE_SNAPSHOT_OPT_VAL) // Set the query type to the real-time view. .load("/tmp/default/cow_bugx/") // Specify the path of the Hudi table to read. .createTempView("mycall") spark.sql("select * from mycall").show(100) - Reading the incremental view (using Hive as an example and ${table_name} to specify the table name.)
set hoodie.${table_name}.consume.mode=INCREMENTAL; //Set incremental read. set hoodie.${table_name}.consume.max.commits=3; // Specify the maximum number of commits to be consumed. set hoodie.${table_name}.consume.start.timestamp=20201227153030; // Specify the initial commit to pull incremental views. select count(*) from default.${table_name} where `_hoodie_commit_time`>'20201227153030'; // This filtering condition must be added, and the value is the initial commit to pull incremental views. - Reading the incremental view (using SparkSQL as an example and ${table_name} to specify the table name.)
set hoodie.${table_name}.consume.mode=INCREMENTAL; //Set incremental read. set hoodie.${table_name}.consume.start.timestamp=20201227153030; // Specify the initial commit to pull incremental views. set hoodie.${table_name}.consume.end.timestamp=20210308212318; // Specify the end commit to pull incremental views. If this parameter is not specified, the latest commit is used. select count(*) from default.${table_name} where `_hoodie_commit_time`>'20201227153030'; // This filtering condition must be added, and the value is the initial commit to pull incremental views. - Reading the incremental view (using the Spark DataSource API as an example):
QUERY_TYPE_OPT_KEY must be set to QUERY_TYPE_INCREMENTAL_OPT_VAL.
spark.read.format("hudi") .option(QUERY_TYPE_OPT_KEY, QUERY_TYPE_INCREMENTAL_OPT_VAL) // Set the query type to the incremental mode. .option(BEGIN_INSTANTTIME_OPT_KEY, "20210308212004") // Specify the initial incremental pull commit. .option(END_INSTANTTIME_OPT_KEY, "20210308212318") //: Specify the end commit of the incremental pull. .load("/tmp/default/cow_bugx/") // Specify the path of the Hudi table to read. .createTempView("mycall") // Register as a Spark temporary table. spark.sql("select * from mycall where `_hoodie_commit_time`>'20210308211131'")// Start the query. The statement is the same as the Hive incremental query statement. .show(100, false) - Reading the read-optimized view: The read-optimized view of COW tables is equivalent to the real-time view.
