Typical Hudi Configuration Parameters
This section describes important Hudi configurations. For details, visit the Hudi official website at https://hudi.apache.org/docs/overview.
Write Configuration
| Parameter | Description | Default Value |
| hoodie.datasource.write.table.name | Name of the Hudi table to which data is written | None |
| hoodie.datasource.write.operation | Type of the operation for writing data to the Hudi table. Value options are as follows:
| upsert |
| hoodie.datasource.write.table.type | Type of the Hudi table. This parameter cannot be modified once the table is created. The value can be COPY_ON_WRITE or MERGE_ON_READ.
| COPY_ON_WRITE |
| hoodie.datasource.write.precombine.field | Merges and deduplicates rows with the same key before write. | A specific table field |
| hoodie.datasource.write.payload.class | Class used to merge the records to be updated and the updated records during update. This parameter can be customized. You can compile it to implement your merge logic. | org.apache.hudi.common.model.DefaultHoodieRecordPayload |
| hoodie.datasource.write.recordkey.field | Unique primary key of the Hudi table | A specific table field |
| hoodie.datasource.write.partitionpath.field | Partition key. This parameter can be used together with hoodie.datasource.write.keygenerator.class to meet different partition needs. | None |
| hoodie.datasource.write.hive_style_partitioning | Flag to indicate whether to use Hive style partitioning. When this parameter is set to true, Hive partitions store data in separate directories based on partition field values, simplifying data management and querying. The recommended value is true.
| true |
| hoodie.datasource.write.keygenerator.class | Used with hoodie.datasource.write.partitionpath.field and hoodie.datasource.write.recordkey.field to generate the primary key and partition mode. NOTE: If the value of this parameter is different from that saved in the table, a message is displayed, indicating that the value must be the same. | org.apache.hudi.keygen.ComplexKeyGenerator |
Configuration of Hive Table Synchronization
| hoodie.datasource.hive_sync.enable | Whether to enable Hive metadata synchronization when Hudi writes data. When this configuration is enabled, Hudi automatically synchronizes table metadata to the Hive Metastore during data writes. This allows Hive to query Hudi tables directly. Set this parameter to true to use Hive to centrally manage Hudi tables.
| false |
| hoodie.datasource.hive_sync.database | Name of the destination database to which the Hive table will be synchronized after Hive metadata synchronization is enabled. | default |
| hoodie.datasource.hive_sync.table | Name of the destination table to which the Hive table will be synchronized after Hive metadata synchronization is enabled. It is recommended that this value be the same as that of hoodie.datasource.write.table.name. | unknown |
| hoodie.datasource.hive_sync.username | Username for connecting to the Hive Metastore after Hive metadata synchronization is enabled. | hive |
| hoodie.datasource.hive_sync.password | Password for connecting to the Hive Metastore after Hive metadata synchronization is enabled. | hive |
| hoodie.datasource.hive_sync.jdbcurl | JDBC URL for connecting to the Hive Metastore after Hive metadata synchronization is enabled. | "" |
| hoodie.datasource.hive_sync.use_jdbc | Whether to use Hive JDBC to connect to Hive and synchronize Hudi table information. Set this parameter to false to invalidate the JDBC connection configuration.
| true |
| hoodie.datasource.hive_sync.partition_fields | Hive partition columns Partitioning significantly improves query performance, especially for large datasets, because queries only scan the relevant partition directories. | "" |
| hoodie.datasource.hive_sync.partition_extractor_class | Class used to extract Hudi partition column values and convert them into Hive partition columns. | org.apache.hudi.hive.SlashEncodedDayPartitionValueExtractor |
| hoodie.datasource.hive_sync.support_timestamp | If the Hudi table contains a field of the timestamp type, set this parameter to true to synchronize the timestamp type to the Hive metadata. The default value is false, indicating that the timestamp type is converted to bigint during synchronization by default. In this case, an error may occur when you query a Hudi table that contains a field of the timestamp type using SQL statements. | true |
Index Configuration
| hoodie.index.class | Full path of a user-defined index, which must be a subclass of HoodieIndex. When this parameter is specified, the configuration takes precedence over that of hoodie.index.type. | "" |
| hoodie.index.type | Index type. The default value is BLOOM. The possible options are BLOOM, HBASE, GLOBAL_BLOOM, SIMPLE, and GLOBAL_SIMPLE. The Bloom filter eliminates the dependency on an external system and is stored in the footer of a Parquet data file. | BLOOM |
| hoodie.index.bloom.num_entries | This is the number of entries to be stored in the bloom filter. Assume the maxParquetFileSize is 128 MB and averageRecordSize is 1024 bytes and hence a total of 130 KB records are recorded in a file. The default (60000) is roughly half of this approximation. CAUTION: Setting this very low will generate many false positives and index lookup will have to scan a lot more files than it has to, and setting this to a very high number will increase the size every data file linearly (roughly 4 KB for every 50,000 entries). | 60000 |
| hoodie.index.bloom.fpp | Error rate allowed given the number of entries. This is used to calculate how many bits should be assigned for the bloom filter and the number of hash functions. This is usually set very low (default: 0.000000001) to tradeoff disk space for lower false positives. | 0.000000001 |
| hoodie.bloom.index.parallelism | Parallelism for bloom filter index lookup, which involves a shuffle. Increasing parallelism improves index-building performance but also increases resource consumption. By default, it is automatically calculated based on input workload characteristics. | 0 |
| hoodie.bloom.index.prune.by.ranges | Whether to optimize the index using range pruning when building a Bloom filter index. When this parameter is set to true, range information from files is used to speed up index lookup. This is particularly helpful if the keys have monotonously increasing prefixes, such as timestamp.
| true |
| hoodie.bloom.index.use.caching | Whether to enable caching when building and using a Bloom filter index. When this parameter is set to true, the input RDD will be cached to speed up index lookup by reducing I/O for computing parallelism or affected partitions. This improves query performance, especially for frequently queried data.
| true |
| hoodie.bloom.index.use.treebased.filter | Whether to enable interval tree-based file pruning optimization in the Bloom filter index. This mode speeds up file pruning based on key ranges when compared with the brute-force mode.
| true |
| hoodie.bloom.index.bucketized.checking | Whether to enable bucketized bloom filtering in the Bloom filter index. Enabling bucketized bloom filtering reduces skew seen in sort based bloom index lookup.
| true |
| hoodie.bloom.index.keys.per.bucket | This parameter is available only if bloomIndexBucketizedChecking is enabled and the index type is BLOOM. This configuration controls the "bucket" size which tracks the number of record-key checks made against a single file and is the unit of work allocated to each partition performing bloom filter lookup. A higher value would amortize the fixed cost of reading the Bloom filter to memory. | 10000000 |
| hoodie.bloom.index.update.partition.path | Whether to update the partition path during record updates when the index type is GLOBAL_BLOOM.
| true |
| hoodie.index.hbase.zkquorum | Mandatory. This parameter is available only when the index type is HBase. This parameter specifies the HBase ZooKeeper quorum URL to be connected. | None |
| hoodie.index.hbase.zkport | Mandatory. This parameter is available only when the index type is HBase. This parameter specifies the HBase ZooKeeper quorum port to be connected. | None |
| hoodie.index.hbase.zknode.path | Mandatory. This parameter is available only when the index type is HBase. It is the root znode that will contain all the znodes created and used by HBase. | None |
| hoodie.index.hbase.table | Mandatory. This parameter is available only when the index type is HBase. HBase table name to be used as an index. Hudi stores the row_key and [partition_path, fileID, commitTime] mapping in the table. | None |
Storage Configuration
| hoodie.parquet.max.file.size | Specifies the target size for Parquet files generated in Hudi write phases. For DFS, this parameter needs to be aligned with the underlying file system block size for optimal performance. | 120 * 1024 * 1024 byte |
| hoodie.parquet.block.size | Specifies the Parquet page size. Page is the unit of read in a Parquet file. In a block, pages are compressed separately. | 120 * 1024 * 1024 byte |
| hoodie.parquet.compression.ratio | Specifies the expected compression ratio of Parquet data when Hudi attempts to adjust the size of a new Parquet file. If the size of the file generated by bulk_insert is smaller than the expected size, increase the value. | 0.1 |
| hoodie.parquet.compression.codec | Compression codec for parquet files. The default value is snappy. Possible options are gzip, snappy, uncompressed, and lzo.
| snappy |
| hoodie.logfile.max.size | Maximum size of a Hudi log file. It is the maximum size allowed for a log file before it is rolled over to the next version. | 1GB |
| hoodie.logfile.data.block.max.size | Specifies the maximum size of a LogFile data block. It is the maximum size allowed for a single data block to be appended to a log file. It helps to ensure that the data appended to the log file is broken up into sizable blocks to prevent OOM errors. The size should be greater than the JVM memory. | 256MB |
| hoodie.logfile.to.parquet.compression.ratio | Specifies the expected additional compression when records move from log files to Parquet files. It is used for MOR tables to send inserted content into log files and control the size of compacted Parquet files. | 0.35 |
Compaction and Cleaning Configurations
| hoodie.clean.automatic | Whether data cleaning is performed automatically. Data cleaning is a critical Hudi function that deletes expired or unnecessary data files to optimize storage space and query performance.
| true |
| hoodie.cleaner.policy | Cleaning policy to manage the Hudi table. Hudi will delete the Parquet file of an old version to reclaim space. Any query or computation referring to this version of the file will fail. You are advised to ensure that the data retention time exceeds the maximum query execution time. Available options are as follows:
| KEEP_LATEST_COMMITS |
| hoodie.cleaner.commits.retained | In Hudi, each write operation (such as an insert, update, or delete) generates a new commit. Each commit includes a unique timestamp that identifies the specific write operation. This parameter specifies the number of commits to retain during Hudi cleaning operations. When the number of commits exceeds this value, Hudi deletes the oldest commits and their associated data files to reclaim storage space. | 10 |
| hoodie.keep.max.commits | In Hudi, each write operation generates a new commit. Each commit includes a unique timestamp that identifies the specific write operation. Hudi supports time travel queries, which allow users to query the state of data as it existed at a specific point in time. To support this feature, Hudi retains data across multiple historical versions. This parameter specifies the maximum number of commits that Hudi retains. When the number of commits exceeds this value, Hudi deletes the oldest commits and their associated data files to reclaim storage space. | 30 |
| hoodie.keep.min.commits | Minimum number of commits reserved for archiving operations. | 20 |
| hoodie.commits.archival.batch | Number of commit instants read in memory as a batch and archived together. Adjusting this parameter controls the frequency of archiving operations and the number of records processed in each batch. | 10 |
| hoodie.parquet.small.file.limit | The value must be smaller than that of maxFileSize. If maxFileSize is set to 0, this function is disabled. Small files always exist because of the large number of insert records in a partition of batch processing. Hudi provides an option to solve the problem of small files by masking inserts into this partition as updates to existing small files. The size here is the minimum file size that is considered as a "small file size". | 104857600 B |
| hoodie.copyonwrite.insert.split.size | Parallelism for inserting and writing data. It is the number of inserts grouped for a single partition. Writing out 100 MB files with at least 1 KB records means 100 KB records exist in each file. Overprovision to 500 KB by default. To improve insert latency, adjust the value to match the number of records in a single file. If it is set to a smaller value, the file size will shrink (especially when compactionSmallFileSize is set to 0). | 500000 |
| hoodie.copyonwrite.insert.auto.split | Whether Hudi dynamically computes insertSplitSize based on the last 24 commit metadata. This function is disabled by default.
| true |
| hoodie.copyonwrite.record.size.estimate | Average record size. If specified, Hudi will use this parameter and not compute dynamically based on the last 24 commit metadata. There is no default value. This is critical in computing the insert parallelism and packing inserts into small files. | 1024 |
| hoodie.compact.inline | Whether to enable inline compression during write operations. Compaction is a crucial mechanism in Hudi for optimizing storage and performance. It improves read efficiency and reduces file fragmentation by merging small files and removing redundant data. Inline Compaction: Compaction automatically performed during write operations (such as an insert, update, or delete). This approach eliminates the need for independent compaction tasks and improves overall write performance. Async Compaction: Compaction performed in the background by independent tasks. This approach provides greater flexibility in controlling the frequency and timing of compaction, though it may increase system complexity.
| true |
| hoodie.compact.inline.max.delta.commits | Maximum number of delta commits during inline compaction. This parameter is critical when inline compaction is enabled, as it determines the maximum number of delta commits merged within a single write operation. | 5 |
| hoodie.compaction.lazy.block.read | When CompactedLogScanner merges all log files, this parameter helps to choose whether the logblocks should be read lazily. Set it to true to use I/O-intensive lazy block read (low memory usage) or false to use memory-intensive immediate block read (high memory usage). | true |
| hoodie.compaction.reverse.log.read | HoodieLogFormatReader reads a log file in the forward direction from pos=0 to pos=file_length. If this parameter is set to true, Reader reads a log file in reverse direction from pos=file_length to pos=0. If this parameter is set to false, log files are read sequentially. | false |
| hoodie.cleaner.parallelism | The cleaning operation in Hudi removes obsolete data files, such as expired incremental files and redundant base files. Adjusting this parameter controls the degree of parallelism for the cleaning operation, balancing resource utilization against cleaning performance. Increase this parameter if cleaning becomes slow. | 200 |
| hoodie.compaction.strategy | Which file groups are selected for compaction during each compaction run. By default, Hudi selects the log file with most accumulated unmerged data. | org.apache.hudi.table.action.compact.strategy. LogFileSizeBasedCompactionStrategy |
| hoodie.compaction.target.io | Number of MBs to spend during compaction run for LogFileSizeBasedCompactionStrategy. This parameter can limit ingestion latency when compaction is run in inline mode. | 500 * 1024 MB |
| hoodie.compaction.daybased.target.partitions | Used by org.apache.hudi.io.compact.strategy.DayBasedCompactionStrategy to denote the number of latest partitions to compact during a compaction run. | 10 |
| hoodie.compaction.payload.class | It needs to be same as class used during insert or upsert. Similar to writing, compaction also uses the record payload class to merge records in the log against each other, merge again with the base file, and produce the final record to be written after compaction. | org.apache.hudi.common.model.DefaultHoodieRecordPayload |
| hoodie.schedule.compact.only.inline | Whether to only generate a compaction plan during inline compaction without executing it. This parameter is valid only when hoodie.compact.inline is set to true.
| false |
| hoodie.run.compact.only.inline | Whether to execute only existing compaction plans when the run compaction SQL command is triggered. If no pre-existing plan is found, the command completes without taking further action.
| false |
Clustering Configuration
- Clustering configuration applies only to MRS 3.2.0-LTS or later.
- Clustering has two strategies: hoodie.clustering.plan.strategy.class and hoodie.clustering.execution.strategy.class. Typically, if hoodie.clustering.plan.strategy.class is set to SparkRecentDaysClusteringPlanStrategy or SparkSizeBasedClusteringPlanStrategy, hoodie.clustering.execution.strategy.class does not need to be specified. However, if hoodie.clustering.plan.strategy.class is set to SparkSingleFileSortPlanStrat, hoodie.clustering.execution.strategy.class must be set to SparkSingleFileSortExecutionStrategy.
| hoodie.clustering.inline | Clustering optimizes data storage layout to increase query speed without reducing ingestion performance. Hudi clustering can be performed synchronously or asynchronously.
| false |
| hoodie.clustering.inline.max.commits | Number of commits that trigger clustering during synchronous clustering. This parameter limits the synchronous clustering scope and prevents excessive commits in a single write operation from reducing write performance. | 4 |
| hoodie.clustering.async.enabled | Whether to enable asynchronous clustering to reduce write latency and improve write performance.
NOTE: This parameter is available only in MRS 3.3.0-LTS and later versions. | false |
| hoodie.clustering.async.max.commits | Number of commits that trigger clustering during asynchronous clustering. NOTE: This parameter is available only in MRS 3.3.0-LTS and later versions. | 4 |
| hoodie.clustering.plan.strategy.target.file.max.bytes | Maximum size of each file after clustering. | 1024 * 1024 * 1024 byte |
| hoodie.clustering.plan.strategy.small.file.limit | Files smaller than the value of this parameter are clustered. | 300 * 1024 * 1024 byte |
| hoodie.clustering.plan.strategy.sort.columns | Column used by clustering for sorting. | None |
| hoodie.layout.optimize.strategy | Clustering execution policy. The value can be linear, z-order, or hilbert. | linear |
| hoodie.layout.optimize.enable | This function must be enabled when z-order and hilbert are used. | false |
| hoodie.clustering.plan.strategy.class | Strategy class for filtering file groups for clustering. By default, files smaller than the value of hoodie.clustering.plan.strategy.small.file.limit are filtered. | org.apache.hudi.client.clustering.plan.strategy.SparkSizeBasedClusteringPlanStrategy |
| hoodie.clustering.execution.strategy.class | Strategy class for executing clustering (subclass of RunClusteringStrategy), which is used to define the execution mode of a cluster plan. The default class sorts the file groups in the plan by the specified column and meets the configured target file size. | org.apache.hudi.client.clustering.run.strategy.SparkSortAndSizeExecutionStrategy |
| hoodie.clustering.plan.strategy.max.num.groups | Maximum number of file groups that can be selected during clustering. A larger value indicates a higher concurrency. | 30 |
| hoodie.clustering.plan.strategy.max.bytes.per.group | Maximum number of data records in each file group involved in clustering | 2 * 1024 * 1024 * 1024 byte |
