Updated on 2026-06-27 GMT+08:00
Creating a FlinkServer Cluster Connection
Different clusters can be accessed by configuring the cluster connection.
  1. Access the Flink web UI. For details, see Accessing the FlinkServer Web UI.
  2. Choose System Management > Cluster Connection Management. The Cluster Connection Management page is displayed.
  3. Click Create Cluster Connection. On the displayed page, set parameters by referring to Table 1 and click OK. After the cluster connection is created, you can edit, test, or delete the cluster connection in the Operation column.
    Figure 1 Creating a cluster connection
    Table 1 Parameters for creating a cluster connection
    Cluster Connection Name
    Enter the name of the cluster connection.
    Enter the description of the cluster connection name.
    FusionInsight HD Version
    Set a cluster version.
    Secure Version
    • If the secure version is used, select Yes for a security cluster. Enter the username and upload the user credential.
    • If not, select No.
    Username
    The user must have the minimum permissions for accessing services in the cluster.
    This parameter is available only when Secure Version is set to Yes.
    Client Profile
    Client profile of the cluster, in TAR format.
    User Credential
    User authentication credential in FusionInsight Manager in TAR format.
    Files can be uploaded only after the username is entered.
    To obtain the cluster client configuration files, perform the following steps:
    • For versions earlier than MRS 3.3.0, log in to FusionInsight Manager and choose Cluster > Dashboard. On the displayed page, choose More > Download Client > Configuration Files Only, select a platform type, and click OK.
    • For MRS 3.3.0 or later, log in to FusionInsight Manager, choose Homepage > Download Client > Configuration Files Only, select a platform type, and click OK.
    To obtain the user credential, perform the following steps:
    1. Log in to FusionInsight Manager and click System.
    2. In the Operation column of the user, choose More > Download Authentication Credential, select a cluster, and click OK.
