Flink Job Engine
Flink web UI provides a web-based visual development platform. You only need to compile SQL statements to develop jobs, slashing the job development threshold. In addition, the exposure of platform capabilities allows service personnel to compile SQL statements for job development to quickly respond to requirements, greatly reducing the Flink job development workload.
Flink Web UI Features
The Flink web UI has the following features:
  • Enterprise-class visual O&M: GUI-based O&M management, job monitoring, and standardization of Flink SQL statements for job development.
    Figure 1 Operations management
  • Quick cluster connection: After configuring the client and user credential key file, you can quickly access a cluster using the cluster connection function.
  • Quick data connection: You can access a component by configuring the data connection function. If Data Connection Type is set to HDFS, you need to create a cluster connection. If Authentication Mode is set to KERBEROS for other data connection types, you need to create a cluster connection. If Authentication Mode is set to SIMPLE, you do not need to create a cluster connection.
    If Data Connection Type is set to Kafka, Authentication Type cannot be set to KERBEROS.
  • Visual development platform: The input/output mapping table can be customized to meet the requirements of different input sources and output destinations.
  • Easy to use GUI-based job management
    Figure 2 Job management
Key Web UI Capabilities
Table 1 shows the key capabilities provided by Flink web UI.
Table 1 Key web UI capabilities
Item
Batch-Stream convergence
  • Batch jobs and stream jobs can be processed with a unified set of Flink SQL statements.
Flink SQL kernel capabilities
  • Flink SQL supports customized window size, stream compute within 24 hours, and batch processing beyond 24 hours.
  • Flink SQL supports reading data from Kafka and HDFS, writing data to Kafka and HDFS.
  • A job can define multiple Flink SQL statements, and multiple metrics can be combined into one computing job. If a job contains same primary keys as well as same inputs and outputs, the job supports the computing of multiple windows.
  • The AVG, SUM, COUNT, MAX, and MIN statistical methods are supported.
Flink SQL functions on the console
  • Cluster connection management allows you to configure clusters where services such as Kafka and HDFS reside.
  • Data connection management allows you to configure services such as Kafka and HDFS.
  • Data table management allows you to define data tables accessed by SQL statements and generate DDL statements.
  • Flink SQL job definition allows you to use SQL statements to verify, parse, optimize, convert a job into a Flink job, and submit the job.
Flink job visual management
  • Stream jobs and batch jobs can be defined in a visual manner.
  • Job resources, fault recovery policies, and checkpoint policies can be configured in a visual manner.
  • Status monitoring of stream and batch jobs are supported.
  • The Flink job O&M is enhanced, including redirection of the native monitoring page.
Performance and reliability
  • Stream processing supports 24-hour window aggregation computing and millisecond-level performance.
  • Batch processing supports 90-day window aggregation computing, which can be completed in minutes.
  • Invalid data of stream processing and batch processing can be filtered out.
  • When HDFS data is read, the data can be filtered based on the calculation period in advance.
  • If the job definition platform is faulty or the service is degraded, jobs cannot be redefined, but the computing of existing jobs is not affected.
  • The automatic restart mechanism is provided for job failures. You can configure restart policies.
Flink Web UI Application Process
The Flink web UI application process is shown as follows:
Figure 3 Flink web UI application process
Table 2 Description of the Flink web UI application process
Step
Reference
Creating an application
Applications can be used to isolate different upper-layer services.
Creating a FlinkServer Application
Creating a cluster connection
Different clusters can be accessed by configuring the cluster connection.
Creating a FlinkServer Cluster Connection
Creating a Data Connection
Through data connections, you can access different data services, including HDFS and Kafka.
Creating a FlinkServer Data Connection
Creating a stream table
Data tables can be used to define basic attributes and parameters of source tables, dimension tables, and output tables.
Creating a FlinkServer Stream Table Source
Creating a SQL/JAR job (stream/batch job)
APIs can be used to define Flink jobs, including Flink SQL and Flink Jar jobs.
Creating a FlinkServer Job
Managing jobs
A created job can be managed, including starting, developing, stopping, deleting, and editing the job.
