Updated on 2026-06-27 GMT+08:00
Adding a GaussDB Data Source
Add a GaussDB JDBC data source on HSConsole.
Prerequisites for Adding a GaussDB Data Source
  • The cluster where the data source is located and the HetuEngine cluster nodes can communicate with each other.
  • On all nodes in the cluster where HetuEngine is located, update the /etc/hosts file to include the host name and IP address mappings for the cluster that contains the data source to be connected. In addition, add the entry 10.10.10.10 hadoop.System domain name (for example, 10.10.10.10 hadoop.hadoop.com) from the data source cluster to the /etc/hosts file on all nodes in the cluster where HetuEngine is located. Without these settings, HetuEngine cannot connect to nodes outside its cluster using host names.
  • A HetuEngine compute instance has been created.
Procedure for Adding a GaussDB Data Source
  1. Log in to FusionInsight Manager as a HetuEngine administrator and choose Cluster > Services > HetuEngine.
  2. In the Basic Information area on the Dashboard page, click the link next to HSConsole WebUI to access the HSConsole page.
  3. Choose Data Source and click Add Data Source. Configure parameters on the Add Data Source page.
    1. In the Basic Configuration area, set Name and select JDBC > GAUSSDB-A for Data Source Type.
    2. Configure parameters in the GAUSSDB-A Configuration area. For details, see Table 1.
      Table 1 GAUSSDB-A Configuration
      Example Value
      Driver
      The default value is gaussdba.
      gaussdba
      JDBC URL
      JDBC URL for connecting to the GaussDB database. The format is as follows:
      jdbc:postgresql://CN service IP address:Port number/Database name
      If SSL is enabled for the GaussDB database, add the following SSL-related parameter to the URL: ssl=true&sslfactory=org.postgresql.ssl.NonValidatingFactory
      • SSL is disabled for the GaussDB database:
        jdbc:postgresql://10.0.136.1:25308/postgres
      • SSL is enabled for the GaussDB database:
        jdbc:postgresql://10.0.136.1:25308/postgres?ssl=true&sslfactory=org.postgresql.ssl.NonValidatingFactory
      Username
      Username for connecting to the GaussDB data source.
      Change the value based on the username for connecting to the data source.
      Password
      Password for connecting to the GaussDB data source.
      Change the value based on the username and password for connecting to the data source.
    3. (Optional) Configure GaussDB user information based on Table 2.
      GaussDB User Information Configuration and HetuEngine-GaussDB User Mapping Configuration must be used together. When HetuEngine is connected to the GaussDB data source, user mapping enables HetuEngine users to have the same permissions of the mapped GaussDB data source user. Multiple HetuEngine users can correspond to one GaussDB user.
      In the GaussDB database, the created username must comply with the identifier naming convention and can contain a maximum of 63 characters. If a username contains uppercase letters, the database automatically converts them to lowercase letters. To create a username that contains uppercase letters, enclose the username with double quotation marks (""). Therefore, you must use the converted username to set the Data Source User parameter.
      For example:
      • If the username created in the GaussDB database is Gaussuser1, the value of Data Source User must be gaussuser1.
      • If the username created in the GaussDB database is "Gaussuser1", the value of Data Source User must be Gaussuser1.
      Table 2 GaussDB User Information Configuration
      Data Source User
      Username of the data source user
      If the data source user is gaussuser1, a HetuEngine user mapped to gaussuser1 must exist. For example, create user hetuuser1 and map it to gaussuser1.
      Password
      Password of the corresponding data source user
    4. (Optional) Configure HetuEngine-GaussDB user mapping based on Table 3.
      Multiple HetuEngine accounts are configured in the format of HetuEngine User and Data Source User key-value pairs, corresponding to one of the users configured in the GaussDB User Information Configuration area. When different HetuEngine users are used to access GaussDB, different GaussDB usernames and passwords can be used.
      Table 3 HetuEngine-GaussDB User Mapping Configuration
      HetuEngine User
      HetuEngine username
      Data Source User
      Data source user, for example, gaussuser1 (data source user configured in Table 2)
    5. (Optional) Customize the configuration.
      • Click Add to add custom configuration parameters. Configure custom parameters of the GaussDB data source. For details, see Table 4.
        Table 4 Custom parameters of the GaussDB data source
        Example Value
        use-connection-pool
        Whether to use the JDBC connection pool.
        true
        jdbc.connection.pool.maxTotal
        Maximum number of connections in the JDBC connection pool.
        8
        jdbc.connection.pool.maxIdle
        Maximum number of idle connections in the JDBC connection pool.
        8
        jdbc.connection.pool.minIdle
        Minimum number of idle connections in the JDBC connection pool.
        0
        join-pushdown.enabled
        • true: JOIN statements can be pushed down to the data source for execution.
        • false: JOIN statements are not pushed down to the data source for execution. As a result, more network and compute resources are consumed.
        true
        join-pushdown.strategy
        The JOIN push-down function should be enabled in advance. Value options are as follows:
        • AUTOMATIC: cost-based JOIN pushdown
        • EAGER: JOIN pushdown as much as possible
        AUTOMATIC
        source-encoding
        GaussDB data source encoding mode.
        UTF-8
        multiple-cnn-enabled
        Whether to use the GaussDB multi-CN configuration. To use it, ensure that the JDBC connection pool is disabled and the JDBC URL format is as follows: jdbc:postgresql://host:port/database,jdbc:postgresql://host:port/database,jdbc:postgresql://host:port/database.
        false
        parallel-read-enabled
        Whether to use the parallel data read function.
        If the parallel data read function is enabled, the actual number of splits is determined based on the node distribution and the value of max-splits.
        Multiple concurrent connections to the data source will be established for parallel read operations. Ensure the dependent data source can sustain the increased load.
        false
        split-type
        Type of parallel data read.
        • NODE: The degree of parallelism (DOP) is determined by the number of GaussDB DataNodes.
        • PARTITION: The DOP is determined by the number of table partitions.
        • INDEX: The DOP is determined by the number of table indexes.
        NODE
        max-splits
        Maximum degree of parallelism.
        5
        unsupported-type-handling
        If the connector does not support the data of a certain type, convert it to VARCHAR.
        • After the CONVERT_TO_VARCHAR parameter is configured, the data of BIT VARYING, CIDR, MACADDR, INET, OID, REGTYPE, REGCONFIG, and POINT types are converted to the VARCHAR type during query and data of these types can only be read.
        • The default value is IGNORE, indicating that unsupported types will not be displayed in the query result.
        CONVERT_TO_VARCHAR
        decimal-mapping
        By default, HetuEngine ignores the data of the DECIMAL, NUMBER, or NUMERIC type whose precision is not specified or exceeds the maximum precision of 38 digits. You can map the data to the DECIMAL(38, x) type by setting the decimal-mapping=allow_overflow parameter. The value of x is the value of decimal-default-scale.
        allow_overflow
        Decimal precision when data of the DECIMAL, NUMBER, or NUMERIC type is mapped into DECIMAL(38, x). The value ranges from 0 to 38, and the default value is 0.
        0
        case-insensitive-name-matching
        HetuEngine supports case-sensitive table and schema names of the GaussDB data source.
        • false: Only schemas or tables whose names contain only lowercase letters can be queried. The default value is false.
        • true:
          • If no schema or table is matched when case sensitivity is ignored, the schema and table can be queried.
          • If schemas and tables are matched when case sensitivity is ignored, the schema and table cannot be queried.
        false
      • You can click Delete to delete custom configuration parameters.
    6. Click OK.
  4. Log in to the node where the cluster client is located and run the following commands to switch to the client installation directory and authenticate the user:
    cd /opt/client
    source bigdata_env
    kinit User performing HetuEngine operations (If the cluster is in normal mode, skip this step.)
  5. Run the following command to log in to the catalog of the data source:
    hetu-cli --catalog Data source name --schema Database name
    For example, run the following command:
    hetu-cli --catalog gaussdb_1 --schema admin
  6. Run the following command. If the database table information can be viewed or no error is reported, the connection is successful.
    show tables;
GaussDB Data Type Mapping
GaussDB Data Type
HetuEngine Data Type
BOOLEAN
BOOLEAN
TINYINT
TINYINT
SMALLINT
SMALLINT
INTEGER
INTEGER
BINARY_INTEGER
INTEGER
BIGINT
BIGINT
SMALLSERIAL
SMALLINT
SERIAL
INTEGER
BIGSERIAL
BIGINT
FLOAT4 (REAL)
REAL
FLOAT8(DOUBLE PRECISION)
DOUBLE PRECISION
DECIMAL[p (,s)]
DECIMAL[p (,s)]
NUMERIC[p (,s)]
DECIMAL[p (,s)]
CHAR(n)
CHAR(n)
CHARACTER(n)
CHAR(n)
NCHAR(n)
CHAR(n)
VARCHAR(n)
VARCHAR(n)
CHARACTER VARYING(55)
VARCHAR(n)
VARCHAR2(n)
VARCHAR(n)
NVARCHAR2(n)
VARCHAR
TEXT(CLOB)
VARCHAR
DATE
TIMESTAMP
TIMESTAMP
TIMESTAMP
UUID
UUID
JSON
JSON
Constraints on GaussDB Data Sources
  • The following syntaxes are not supported: GRANT, REVOKE, SHOW GRANTS, SHOW ROLES, and SHOW ROLE GRANTS.
  • The UPDATE and DELETE syntaxes cannot be used to filter clauses containing cross-catalog conditions, for example, UPDATE mppdb.table SET column1=value WHERE column2 IN (SELECT column2 from hive.table).
  • The UPDATE syntax cannot be used to update the DATE, TIMESTAMP, and VARBINARY fields.
  • WHERE statements whose condition is REAL cannot be queried, for example, SELECT * FROM mppdb.table WHERE column1 = REAL '1.1'.
  • The DELETE syntax cannot be used to filter clauses containing subqueries, for example, DELETE FROM mppdb.table WHERE column IN (SELECT column FROM mppdb.table1).
  • HetuEngine supports a maximum precision of 38 digits for GaussDB data sources, specifically for the DECIMAL, NUMBER, and NUMERIC data types.
  • If either end of a predicate contains a subquery, the predicate will not be pushed down. For example, if a subquery exists after the example statement count(*), the predicate will not be pushed down, but the min function in the subquery can be pushed down.
    select count(*) from item where i_current_price = (select min(i_current_price) from item);
