Adding an HBase Data Source
Add an HBase data source on HSConsole.
Prerequisites for Adding an HBase Data Source
- The domain name of the cluster where the data source is located must be different from that of the HetuEngine cluster.
- The cluster where the data source is located and the HetuEngine cluster nodes can communicate with each other.
- On all nodes in the cluster where HetuEngine is located, update the /etc/hosts file to include the host name and IP address mappings for the cluster that contains the data source to be connected. In addition, add the entry 10.10.10.10 hadoop.System domain name (for example, 10.10.10.10 hadoop.hadoop.com) from the data source cluster to the /etc/hosts file on all nodes in the cluster where HetuEngine is located. Without these settings, HetuEngine cannot connect to nodes outside its cluster using host names.
- A HetuEngine compute instance has been created. For details, see Creating a HetuEngine Compute Instance.
- In MRS 3.6.0-LTS or later, the data source cluster must have its time synchronized with the HetuEngine cluster.
- The SSL communication encryption configuration of ZooKeeper in the cluster where the data source is located must be the same as that of ZooKeeper in the cluster where HetuEngine is located.
To check whether SSL communication encryption is enabled, log in to FusionInsight Manager, choose Cluster > Services > ZooKeeper, click Configurations and then All Configurations, and search for ssl.enabled. If the value of ssl.enabled is true, SSL communication encryption is enabled. If the value is false, SSL communication encryption is disabled.
Procedure for Adding an HBase Data Source
- Obtain the hbase-site.xml, hdfs-site.xml, and core-site.xml configuration files of the HBase data source.
- Log in to FusionInsight Manager of the cluster where the HBase data source is located.
- In the upper right corner of the homepage, click Download Client to download the complete client as prompted.
- Decompress the downloaded client file package and obtain the hbase-site.xml, core-site.xml, and hdfs-site.xml files in the FusionInsight_Cluster_1_Services_ClientConfig/HBase/config directory.
- Obtain the user.keytab and krb5.conf files of the proxy user of the HBase data source.
- Choose System > Permission > User.
- Locate the row that contains the target data source user, click More in the Operation column, and select Download Authentication Credential.
- Decompress the downloaded package to obtain the user.keytab and krb5.conf files.
The proxy user of the data source must have the permission to perform operations on HBase.
- Log in to FusionInsight Manager as a HetuEngine administrator and choose Cluster > Services > HetuEngine.
- In the Basic Information area on the Dashboard page, click the link next to HSConsole WebUI to access the HSConsole page.
- Choose Data Source and click Add Data Source. Configure parameters on the Add Data Source page.
- In the Basic Configuration area, set Name and select HBase for Data Source Type.
- Configure parameters in the HBase Configuration area. For details, see Table 1.
Table 1 HBase configuration Parameter
Example Value
Driver
The default value is hbase-connector.
hbase-connector
ZooKeeper Quorum Address
Service IP addresses of all quorumpeer instances of the ZooKeeper service for the data source. If the ZooKeeper service of the data source uses IPv6, you need to specify the client port number in the ZooKeeper Quorum address.
Log in to FusionInsight Manager and choose Cluster > Services > ZooKeeper. On the displayed page, click Instances and view the service IP addresses of all the hosts where the quorumpeer instances locate.
- IPv4: 10.10.10.10,10.10.10.11,10.10.10.12
- IPv6: [10:10::10:11]:24002
ZooKeeper Client Port Number
Port number of the ZooKeeper client.
Log in to FusionInsight Manager and choose Cluster > Services > ZooKeeper. On the Configurations page, check the value of clientPort.
2181
HBase RPC Communication Protection
Set this parameter based on the value of hbase.rpc.protection in the hbase-site.xml file obtained in 1.
- If the value is authentication, set this parameter to No.
- If the value is privacy, set this parameter to Yes.
No
Security Authentication Mechanism
After the security mode is enabled, the default value is KERBEROS.
KERBEROS
Principal
Configure this parameter when the security authentication mechanism is enabled. Set the parameter to the user who owns the user.keytab file obtained in 2.
user_hbase@HADOOP2.COM
Keytab File
Configure this parameter when the security mode is enabled. It specifies the security authentication key. Select the user.keytab file obtained in 2.
user.keytab
krb5 File
Configure this parameter when the security mode is enabled. It is the configuration file used for Kerberos authentication. Select the krb5.conf file obtained in 2.
krb5.conf
hbase-site File
Configure this parameter when the security mode is enabled. It is the configuration file required for connecting to HDFS. Select the hbase-site.xml file obtained in 1.
hbase-site.xml
core-site File
Configure this parameter when the security mode is enabled. This file is required for connecting to HDFS. Select the core-site.xml file obtained in 1.
core-site.xml
hdfs-site File
Configure this parameter when the security mode is enabled. This file is required for connecting to HDFS. Select the hdfs-site.xml file obtained in 1.
hdfs-site.xml
- (Optional) Customize the configuration.
- Click OK.
- Log in to the node where the cluster client is located and run the following commands to switch to the client installation directory and authenticate the user:
cd /opt/client
source bigdata_env
kinit User performing HetuEngine operations (If the cluster is in normal mode, skip this step.)
- Log in to the catalog of the data source.
hetu-cli --catalog Data source name --schema Database name
For example, run the following command:
hetu-cli --catalog hbase_1 --schema default
- Run the following command. If the database table information can be viewed or no error is reported, the connection is successful.
show tables;
- Create a structured mapping table. The format of the statement for creating a mapping table is as follows:
CREATE TABLE schemaName.tableName ( rowId VARCHAR, qualifier1 TINYINT, qualifier2 SMALLINT, qualifier3 INTEGER, qualifier4 BIGINT, qualifier5 DOUBLE, qualifier6 BOOLEAN, qualifier7 TIME, qualifier8 DATE, qualifier9 TIMESTAMP ) WITH ( column_mapping = 'qualifier1:f1:q1,qualifier2:f1:q2,qualifier3:f2:q3,qualifier4:f2:q4,qualifier5:f2:q5,qualifier6:f3:q1,qualifier7:f3:q2,qualifier8:f3:q3,qualifier9:f3:q4', row_id = 'rowId', hbase_table_name = 'hbaseNamespace:hbaseTable', external = true );
The value of schemaName must be the same as that of hbaseNamespace in hbase_table_name.
- Supported mapping tables: Mapping tables can be directly associated with tables in the HBase data source or created and associated with new tables that do not exist in the HBase data source.
- Supported data types in a mapping table: VARCHAR, TINYINT, SMALLINT, INTEGER, BIGINT, DOUBLE, BOOLEAN, TIME, DATE, and TIMESTAMP
- The following table describes the keywords in the statements for creating mapping tables.
Table 2 Keywords in the statements for creating mapping tables Keyword
Type
Mandatory
Default Value
Remarks
column_mapping
String
No
All columns belong to the same Family column family.
Specify the mapping between columns in the mapping table and column families in the HBase data source table. To associate a table in the HBase data source, set this parameter to the same value as that configured in the HBase data source. To create a table that does not exist in the HBase data source, configure this parameter based on your requirements.
Value format: Mapping table column name:HBase column family:HBase column name. Mapping table column names must be in lowercase. HBase column names must be the same as that in HBase.
row_id
String
No
First column in the mapping table
Column name corresponding to the rowkey table in the HBase data source
hbase_table_name
String
No
Leave blank
Tablespace and table name of the HBase data source to be associated. Use a colon (:) to separate them. The default tablespace is default. To create a new table that does not exist in the HBase data source, you do not need to specify hbase_table_name.
external
Boolean
No
true
If external is set to true, the table is a mapping table in the HBase data source and the original table in the HBase data source cannot be deleted. If external is set to false, the table in the HBase data source is deleted when the Hetu-HBase table is deleted.
HBase Data Type Mapping
HBase is a byte-based distributed storage system that stores all data types as byte arrays. To represent HBase data in HetuEngine, select a data type that matches the value of the HBase column qualifier for the HetuEngine column qualifier by creating a mapping table in HetuEngine.
Currently, HetuEngine column qualifiers support the following data types: VARCHAR, TINYINT, SMALLINT, INTEGER, BIGINT, DOUBLE, BOOLEAN, TIME, DATE, and TIMESTAMP.
Performance Optimization
- Predicate pushdown
Queries support pushdown of most operators. The following predicate conditions are supported: =, >=, >, <, <=, !=, IN, NOT IN, IS NULL, IS NOT NULL, and BETWEEN AND.
- Batch GET query
Multiple row keys to be queried are encapsulated into one List<Get> in the HBase API, and then the list is requested to query data. In this way, each row key does not need to initiate a request separately.
- HBase single-table query range scanning optimization
The HBase single-table query range scanning optimization is to automatically infer the start and end addresses of rowkeys based on the predicate conditions of HBase columns and configure the start and end addresses of HBase scan during tableScan for higher access performance.
For example, assume that the rowkey of the HBase data table consists of four columns: building_code:house_code:floor:uuid. For the search criteria where building_code = '123' and house_code = '456', the HetuEngine single-table query optimization scans only columns whose rowkey range prefixes are 123 to 456, improving performance.
To enable the HBase single-table query range scanning optimization function, add the custom parameter hbase.rowkey.adaptive.optimization.enabled in 5.c and set it to true.
In addition, you need to specify the columns and separators of rowkeys in the table creation property of table creation statements.
Table 3 Columns and separators of HBase rowkeys Table Property
Example
row_id_construct_columns
Columns of rowkeys in an HBase data table
row_id_construct_columns_terminal
Separator of columns of rowkeys in an HBase data table
For example, a table creation statement containing a rowkey consisting of four columns building_code:house_code:floor:uuid is as follows:
CREATE TABLE test.table_hbase_test ( row_id string, col1 string, col2 string, col3 string, building_code string, house_code string, floor string, uuid string) WITH (column_mapping = ' col1:attr:col1, col2:attr:col2, col3:attr:col3, building_code:attr:building_code, house_code:attr:house_code, floor:attr:floor, uuid:attr:uuid', row_id = 'row_id', row_id_construct_columns = 'building_code:house_code:floor:uuid', row_id_construct_columns_terminal = ':', hbase_table_name='test:table_hbase_test', external = true)
- Dynamic filtering optimization for HBase multi-table join query
HBase supports dynamic filtering optimization.
To enable the dynamic filtering function, enable the HBase single-table query range scanning optimization function, add the custom parameter enable-dynamic-filtering in the coordinator.config.properties and worker.config.properties parameter files of compute instances, and set the parameter to true. For details, see 4.e.
Constraints on HBase Data Sources
The ALTER and VIEW syntaxes are not supported.
