On this page
ZooKeeper Log Overview
Updated on 2023-04-28 GMT+08:00
Log Description
Log path: /var/log/Bigdata/zookeeper/quorumpeer (Run log), /var/log/Bigdata/audit/zookeeper/quorumpeer (Audit log)
Log archive rule: The automatic ZooKeeper log compression function is enabled. By default, when the size of logs exceeds 30 MB, logs are automatically compressed into a log file. A maximum of 20 compressed files can be reserved. The number of compressed files can be configured on Manager.
Table 1 ZooKeeper log list
Log Type
Log File Name
Run logs
zookeeper-<SSH_USER>-<process_name>-<hostname>.log
ZooKeeper system log file, which records most of the logs generated when the ZooKeeper system is running.
check-serviceDetail.log
Log that records whether the ZooKeeper service starts successfully.
zookeeper-<SSH_USER>-<DATA>-<PID>-gc.log
ZooKeeper garbage collection log file
instanceHealthDetail.log
Log that records the health check details of ZooKeeper instance
zookeeper-omm-server-<hostname>.out
Log indicating that ZooKeeper unexpectedly quits
zk-err-<zkpid>.log
ZooKeeper fatal error log
java_pid<zkpid>.hprof
ZooKeeper memory overflow log
funcDetail.log
ZooKeeper instance startup log
zookeeper-period-check.log
Health check log of the ZooKeeper instance
zookeeper-period-check-java.log
ZooKeeper quota monitoring period check log
Audit Log
zk-audit-quorumpeer.log
ZooKeeper operation audit log
Log levels
Table 2 describes the log levels supported by ZooKeeper. The priorities of log levels are FATAL, ERROR, WARN, INFO, and DEBUG in descending order. Logs whose levels are higher than or equal to the specified level are printed. The number of printed logs decreases as the specified log level increases.
Table 2 Log levels
Level
FATAL
Logs of this level record fatal error information about the current event processing that may result in a system crash.
ERROR
Error information about the current event processing, which indicates that system running is abnormal.
WARN
Abnormal information about the current event processing. These abnormalities will not result in system faults.
INFO
Logs of this level record normal running status information about the system and events.
DEBUG
Logs of this level record the system information and system debugging information.
To modify log levels, perform the following operations:
  1. Go to the All Configurations page of the ZooKeeper service by referring to Modifying Cluster Service Configuration Parameters.
  2. On the menu bar on the left, select the log menu of the target role.
  3. Select a desired log level.
  4. Click Save. In the displayed dialog box, click OK to make the configuration take effect.
    The configurations take effect immediately without the need to restart the service.
Log Format
The following table lists the ZooKeeper log formats.
Table 3 Log Format
Log Type
Component
Format
Example
Run logs
zookeeper
quorumpeer
<yyyy-MM-dd HH:mm:ss,SSS>|<Log level>|<Name of the thread that generates the log>|<Message in the log>|<Location where the log event occurs>
2020-01-20 16:33:43,816 | INFO | main | Defaulting to majority quorums | org.apache.zookeeper.server.quorum.QuorumPeerConfig.parseProperties(QuorumPeerConfig.java:335)
Audit logs
zookeeper
quorumpeer
2020-01-20 16:33:54,313 | INFO | CommitProcessor:13 | session=0xd4b0679daea0000 ip=10.177.112.145 operation=create znode target=ZooKeeperServer znode=/zk-write-test-2 result=success | org.apache.zookeeper.ZKAuditLogger$LogLevel$5.printLog(ZKAuditLogger.java:70)
