Why Does Not a Task Fail After More Than Two Consecutive AppAttempts Failures?
Question
The default maximum number of AppAttempts failures is 2. Why does not a task fail after more than two consecutive AppAttempts failures during task execution?
Answer
During task execution, if the return value of ContainerExitStatus is ABORTED, PREEMPTED, DISKS_FAILED, or KILLED_BY_RESOURCEMANAGER, the system does not treat the attempt as a failed attempt.
As a result, the issue occurs. The task fails only after two genuinely failed attempts.
