Updated on 2025-08-22 GMT+08:00
Optimizing the Aggregate Algorithms
Spark SQL supports hash aggregate algorithm. Namely, use fast aggregate hashmap as cache to improve aggregate performance. The hashmap replaces the previous ColumnarBatch to avoid performance problems caused by the wide mode (multiple key or value fields) of an aggregate table.
  1. Install the Spark client.
    For details, see Installing a Client.
  2. Log in to the Spark client node as the client installation user.
    Modify the following parameters in the {Client installation directory}/Spark/spark/conf/spark-defaults.conf file on the Spark client.
    Table 1 Parameter description
    Example Value
    spark.sql.codegen.aggregate.map.twolevel.enabled
    Specifies whether to enable aggregation algorithm optimization.
    • true: Enable
    • false: Disable
    true
