Help Center/
      MapReduce Service/
        Component Operation Guide (LTS)/
        Using Spark/Spark2x/
      Spark SQL Performance Tuning
- Optimizing the Spark SQL Join Operation
 - Improving Spark SQL Calculation Performance Under Data Skew
 - Optimizing Spark SQL Performance in the Small File Scenario
 - Optimizing the Spark INSERT SELECT Statement
 - Configuring Multiple Concurrent Clients to Connect to JDBCServer
 - Configuring the Default Number of Data Blocks Divided by SparkSQL
 - Optimizing Memory When Data Is Inserted into Spark Dynamic Partitioned Tables
 - Optimizing Small Files
 - Optimizing the Aggregate Algorithms
 - Optimizing Datasource Tables
 - Merging CBO
 - SQL Optimization for Multi-level Nesting and Hybrid Join
   Parent topic: Using Spark/Spark2x
