Help Center/ MapReduce Service/ Component Operation Guide (LTS)/ Using Ranger/ Ranger Troubleshooting/ Ranger Fails to Be Started During Cluster Installation
Updated on 2025-08-15 GMT+08:00
Question
Ranger fails to start during cluster installation and the Manager process task list shows database errors like "ERROR: cannot drop sequence X_POLICY_REF_ACCESS_TYPE_SEQ". Measures should be taken to fix the issue and complete the Ranger installation.
Answer
This issue arises when there are two instances of RangerAdmin installed.
If the installation fails, you can log in to Manager, manually restart a RangerAdmin instance, and then restart other instance
