Updated on 2026-06-27 GMT+08:00
Ranger Log Overview
Log Description
Log path: The default storage path of Ranger logs is /var/log/Bigdata/ranger/Role name.
  • RangerAdmin: /var/log/Bigdata/ranger/rangeradmin (run logs); /var/log/Bigdata/audit/ranger/rangeradmin (audit logs in MRS 3.3.0 and later versions)
  • TagSync: /var/log/Bigdata/ranger/tagsync (run logs)
  • UserSync: /var/log/Bigdata/ranger/usersync (run logs)
  • PolicySync: /var/log/Bigdata/ranger/policysync (run logs in MRS 3.3.0 and later versions)
Log archive rule: The automatic compression and archive function is enabled for Ranger logs. By default, when the size of a log file exceeds 20 MB, the log file is automatically compressed. The naming rule of the compressed log file is as follows: <Original log file name>-<yyyy-mm-dd_hh-mm-ss>.[ID].log.zip. A maximum of 20 compressed files are retained.
Table 1 Ranger log list
Type
Name
RangerAdmin run log file
access_log.<DATE>.log
Tomcat access log
catalina.out
Tomcat service run log
threadDump-<DATE>.log
JVM GC log of the process
gc-worker-pid<PID>-<Date>.log.<ID>
RangerAdmin garbage collection (GC) log
postinstallDetail.log
Work log generated after an instance is started before installation
prestartDetail.log
Log that records preparations before instance startup
ranger-admin.log
RangerAdmin run log
pid-check.log
Instance process check log
monitorCheck.log
Monitoring check log
serviceCheck.log
Service check log
stopDetail.log
Instance stopping log
startDetail.log
Instance startup log
TagSync run log
Instance GC log
prestartDetail.log
pid-check.log
ranger-tagsync.log
TagSync run log
startDetail.log
stopDetail.log
tagsync.out
TagSync run log
UserSync run log
auth.log
UnixAuth service run log
Instance GC log
prestartDetail.log
pid-check.log
ranger-usersync.log
UserSync run log
startDetail.log
stopDetail.log
RangerKMS run logs (MRS 3.3.0 and later versions)
access-<host>-<DATE>.log
Tomcat access log
Instance GC log
stopDetail.log
startDetail.log
ranger-kms.log
Instance run log
prestartDetail.log
catalina.out
PolicySync run logs (MRS 3.3.0 and later versions)
cleanupDetail.log
Instance clearing log
policysync.out
Instance run log
prestartDetail.log
ranger-policysync.log
Instance run log
startDetail.log
Instance GC log
stopDetail.log
Audit logs (MRS 3.3.0 and later versions)
rangeradmin-audit.log
RangerAdmin audit log
Log Levels
Table 2 describes the log levels provided by HDFS. The priorities of log levels are FATAL, ERROR, WARN, INFO, and DEBUG in descending order. Logs whose levels are higher than or equal to the specified level are printed. The number of printed logs decreases as the specified log level increases.
Table 2 Log levels
Level
FATAL
Logs of this level record fatal error information about the current event processing that may result in a system crash.
ERROR
Logs of this level record error information about the current event processing, which indicates that system running is abnormal.
WARN
Logs of this level record abnormal information about the current event processing. These abnormalities will not result in system faults.
INFO
Logs of this level record normal running status information about the system and events.
DEBUG
Logs of this level record the system information and system debugging information.
To modify log levels, perform the following operations:
  2. Choose Cluster > Services > Ranger > Configurations.
  3. Select All Configurations.
  4. On the menu bar on the left, select the log menu of the target role.
  5. Select a desired log level.
  6. Click Save. In the displayed dialog box, click OK to make the configuration take effect.
    The configurations take effect immediately without the need to restart the service.
Log Formats
The following table lists the Ranger log formats.
Table 3 Log formats
Type
Format
Example Value
Run log
<yyyy-MM-dd HH:mm:ss,SSS>|<Log level>|<Name of the thread that generates the log>|<Message in the log>|<Location where the log event occurs>
2020-04-29 20:09:28,543 | INFO | http-bio-21401-exec-56 | Request comes from API call, skip cas filter. | CasAuthenticationFilterWrapper.java:25
