Updated on 2026-06-27 GMT+08:00
Viewing Ranger Audit Information
Ranger provides comprehensive audit log viewing functions. Administrators can directly view two types of core audit logs on the Ranger web UI: Ranger's own operational audit logs and access control audit logs generated after each component uses Ranger for authentication. The audit logs include detailed information such as the authentication result, operation details, and execution time of user access to component resources.
This document provides guidance for you to query audit logs on the Ranger web UI, helping administrators monitor access control operations in real time and quickly troubleshoot abnormal events. This provides strong support for data security management and compliance auditing.
  1. Log in to the Ranger web UI as the Ranger administrator. For details, see Logging In to the Ranger Web UI.
  2. Choose Audit to view the audit information. For details about each tab page, see Table 1. If there are a large number of audit records, you can filter them in the search box by keyword.
    Table 1 Audit information
    Tab
    Access
    Currently, MRS does not support online query of audit logs of component resources. You can log in to the component installation node and access /var/log/Bigdata/audit to view audit logs of each component.
    • result: policy verification result. The value 0 indicates that the policy is rejected, and the value 1 indicates that the policy is approved.
    • policy: ID of the applied policy. The value is the same as the value of Policy ID on the page. If the value is -1, no policy is matched.
    • action: operation permission, which corresponds to the operation permission selected in Permissions for the policy.
    • access: operation to be performed. Available values for each component are different.
    Admin
    Audit information about operations on Ranger, such as creating, updating, and deleting security access policies, creating and deleting component permission policies, and creating, updating, and deleting roles.
    Login Sessions
    Session audit information about users who log in to Ranger.
    Plugins
    Component permission policy information in Ranger.
    Plugin Status
    Audit information about synchronization of the permission policy of each component node.
    User Sync
    Audit information about synchronization between Ranger and LDAP users.
