Submitting an Oozie DistCp Job Using Hue
This section describes how to submit an Oozie job of the DistCp type on the Hue web UI.
- Create a workflow. For details, see Creating a Workflow Using Hue.
- On the workflow editing page, select
next to Distcp and drag it to the operation area. - Determine whether the current DistCp operation is performed across clusters.
- Establish cross-Manager mutual trust between two clusters.
- In the Distcp window that is displayed, set the value of Source, for example, to hdfs://hacluster/user/admin/examples/input-data/text/data.txt. Set Destination, for example, to hdfs://target_ip:target_port/user/admin/examples/output-data/distcp-workflow/data.txt. Click Add.
- Click the configuration button
in the upper right corner. On the Properties tab page, click PROPERTIES+, enter the attribute name oozie.launcher.mapreduce.job.hdfs-servers in the text box on the left, enter the attribute value hdfs://source_ip:source_port,hdfs://target_ip:target_port in the text box on the right, and go to 8.
source_ip: service address of the HDFS NameNode in the source cluster
source_port: port number of the HDFS NameNode in the source cluster.
target_ip: service address of the HDFS NameNode in the target cluster
target_port: port number of the HDFS NameNode in the target cluster.
- In the Distcp window that is displayed, set the value of Source, for example, to /user/admin/examples/input-data/text/data.txt. Set Destination, for example, to /user/admin/examples/output-data/distcp-workflow/data.txt. Click Add.
- Click
in the upper right corner. On the configuration page that is displayed, click Delete+ and add the directory to be deleted, for example, /user/admin/examples/output-data/distcp-workflow.
- Click
in the upper right corner of the Oozie editor. If you need to modify the job name before saving the job (default value: My Workflow), click the name directly for modification, for example, Distcp-Workflow.
- After the configuration is saved, click
, and submit the job. After the job is submitted, you can view the related contents of the job, such as the detailed information, logs, and processes, on Hue.
