Submitting an Oozie HDFS Job Using Hue
This section describes how to submit an Oozie job of the HDFS type on the Hue web UI.
- Create a workflow. For details, see Creating a Workflow Using Hue.
- On the workflow editing page, select
next to Fs and drag it to the operation area. - In the Fs window that is displayed, click Add.
- Click CREATE DIRECTORY+ to add the HDFS directories to be created, for example, /user/admin/examples/output-data/mkdir_workflow and /user/admin/examples/output-data/mkdir_workflow1.
If you click DELETE PATH+ to add the HDFS path to be deleted, this parameter cannot be empty. Otherwise, the /user/{Submit user name} directory of the HDFS is deleted by default, which may cause other tasks to run abnormally.
- Click
in the upper right corner of the Oozie editor. If you need to modify the job name before saving the job (default value: My Workflow), click the name directly for modification, for example, HDFS-Workflow.
- After the configuration is saved, click
, and submit the job. After the job is submitted, you can view the related contents of the job, such as the detailed information, logs, and processes, on Hue.
