Help Center/ MapReduce Service/ Component Operation Guide (LTS)/ Using Hive/ Common Issues About Hive/ How Do I Forcibly Stop MapReduce Jobs Executed by Hive?
Updated on 2024-10-25 GMT+08:00
Question
How do I stop a MapReduce task manually if the task is suspended for a long time?
Answer
- Choose Cluster > Name of the desired cluster > Services > Yarn.
- On the left pane, click ResourceManager(Host name, Active), and log in to Yarn.
- Click the button corresponding to the task ID. On the task page that is displayed, click Kill Application in the upper left corner and click OK in the displayed dialog box to stop the task.
Parent topic: Common Issues About Hive
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
