Updated on 2026-06-27 GMT+08:00
Adjusting HetuEngine Cluster Node Resource Configurations
The default memory size and disk overflow path of HetuEngine are not the best. You need to adjust node resources in the cluster based on the actual service and server configuration of the cluster to achieve the optimal performance.
  2. Choose Cluster > Services > HetuEngine > Configurations > All Configurations and adjust the cluster node resource parameters by referring to Table 1.
    Table 1 Parameters for configuring cluster node resources
    Default Value
    Recommended Value
    Parameter File
    yarn.hetuserver.engine.coordinator.memory
    5120
    At least 2 GB less than that of yarn.scheduler.maximum-allocation-mb
    Memory size used by a Coordinator node
    application.properties
    yarn.hetuserver.engine.coordinator.number-of-containers
    2
    2
    Number of Coordinator nodes
    yarn.hetuserver.engine.coordinator.number-of-cpus
    At least two vCores less than yarn.scheduler.maximum-allocation-vcores
    CPU vCores used by a Coordinator node
    yarn.hetuserver.engine.worker.memory
    10240
    Memory size used by a worker node
    yarn.hetuserver.engine.worker.number-of-containers
    2
    Adjusted based on application requirements
    Number of worker nodes
    yarn.hetuserver.engine.worker.number-of-cpus
    CPU vCores used by a Worker node
    Xmx size in the extraJavaOptions parameter
    8 GB
    Memory size used by a worker node x 0.8
    Maximum available memory of the worker JVM process
    worker.jvm.config
    query.max-memory-per-node
    5 GB
    Worker JVM x 0.7
    Maximum available memory of a Query node
    worker.config.properties
    query.max-total-memory-per-node
    5 GB
    Worker JVM x 0.7
    Maximum available memory of a Query + System node
    memory.heap-headroom-per-node
    3 GB
    Worker JVM x 0.3
    Maximum available memory of a system heap node
    4 GB
    Memory size used by a Coordinator node x 0.8
    Maximum available memory of the Coordinator JVM process
    coordinator.jvm.config
    3 GB
    Coordinator JVM x 0.7
    Maximum memory that can be used for node query
    coordinator.config.properties
    3 GB
    1 GB
    Coordinator JVM x 0.3
    query.max-memory
    7 GB
    Sum(query.max-memory-per-node) x 0.7
    Maximum available memory of a Query cluster
    worker.config.properties/coordinator.config.properties
    spiller-spill-path
    CONTAINER_ROOT_PATH/tmp/hetuserver/hetuserver-sqlengine/
    One or more independent SSDs
    Disk output file path
    max-spill-per-node
    10 GB
    Sum(Available space of each node) x 50%
    Available disk space for storing output files of all queries on a node
    query-max-spill-per-node
    10 GB
    80% of the available disk space on a node
    Available disk space for storing output files of a query on a node
    HetuEngine uses JDK 17. Biased locking is disabled by default. In big data scenarios, enabling biased locking can improve the query performance. It is recommended that you add XX:+UseBiasedLocking to the extraJavaOptions parameter in the coordinator.jvm.config and worker.jvm.config files to enable biased locking.
  3. Click Save.
  4. Choose Cluster > Services > HetuEngine > More > Restart Service to restart the HetuEngine service for the parameters to take effect.
  5. Restart the HetuEngine compute instance that is running.
    1. Log in to FusionInsight Manager as a HetuEngine administrator and choose Cluster > Services > HetuEngine.
    2. In the displayed Dashboard tab, find the Basic Information area, and click the link next to HSConsole WebUI.
    3. Click Compute Instances, select the running HetuEngine instance, click Restart, and operate as prompted.
