Updated on 2026-06-27 GMT+08:00
Adding a Cross-Cluster HetuEngine Data Source
Add another HetuEngine data source on the HSConsole page for a cluster in security mode.
Procedure for Adding a Cross-Cluster HetuEngine Data Source
  1. Obtain the user.keytab file of the proxy user of the HetuEngine cluster in a remote domain.
    1. Log in to FusionInsight Manager of the HetuEngine cluster in the remote domain.
    2. Choose System > Permission > User.
    3. Locate the row that contains the target data source user, click More in the Operation column, and select Download Authentication Credential.
    4. The user.keytab file extracted from the downloaded file is the user credential file.
  2. Log in to FusionInsight Manager as a HetuEngine administrator and choose Cluster > Services > HetuEngine.
  3. In the Basic Information area on the Dashboard page, click the link next to HSConsole WebUI. The HSConsole page is displayed.
  4. Choose Data Source and click Add Data Source. Configure parameters on the Add Data Source page.
    1. In the Basic Configuration area, set Name and select HetuEngine for Data Source Type.
    2. Configure parameters in the HetuEngine Configuration area. For details, see Table 1.
      Table 1 HetuEngine configuration
      Example Value
      Driver
      The default value is hsfabric-initial.
      hsfabric-initial
      Username
      Configure this parameter when the security mode is enabled.
      User who accesses the remote HetuEngine. Set the parameter to the user who owns the user.keytab file obtained in 1.
      hetu_test
      Keytab File
      Keytab file of the user who accesses the remote data center. Select the user.keytab file obtained in 1.
      user.keytab
      Two Way Transmission
      Whether to enable bidirectional transmission for cross-domain data transmission. The default value is Yes.
      • Yes: Two-way transmission. Requests are forwarded to the remote HSFabric through the local HSFabric. If two-way transmission is enabled, the local HSFabric address must be configured.
      • No: Unidirectional transmission. Requests are directly sent to the remote HSFabric.
      Yes
      Local Configuration
      Host IP address and port number of the HSFabric instance that is responsible for external communication of the HetuEngine service in the local MRS cluster.
      1. Log in to FusionInsight Manager of the local cluster, choose Cluster > Services > HetuEngine > Instances, and check the service IP address of the HSFabric.
      2. Click HSFabric, choose Instance Configuration, and check the value of server.port. The default value is 29900.
      192.162.157.32:29900
      Remote Address
      Host IP address and port number of the HSFabric instance that is responsible for external communication of the HetuEngine service in the remote MRS cluster.
      1. Log in to FusionInsight Manager of the remote cluster, choose Cluster > Services > HetuEngine > Instances, and check the service IP address of the HSFabric.
      192.168.1.1:29900
      Region
      Region to which the current request initiator belongs. The value can contain only digits and underscores (_).
      0755_01
      Receiving Data Timeout (s)
      Timeout interval for receiving data, in seconds.
      60
      Total Task Timeout (s)
      Total timeout duration for executing a cross-domain task, in seconds.
      300
      Tasks Used by Worker Nodes
      Number of tasks used by each worker node to receive data.
      5
      Data Compression
      • Yes: Data compression is enabled.
      • No: Data compression is disabled.
      Yes
      hsfabric.local.tenant
      (available for MRS 3.3.0 or later)
      Tenant queue used by the remote HetuEngine for computing
      • If this parameter is not set, the system randomly selects the tenant to which the user belongs based on the configured user.
      • If this parameter is set, the specified tenant will be used. This parameter applies to scenarios where strict tenant verification is enabled.
      • This parameter is mandatory if the value of tenant.strict.mode.enabled of the target cluster is true.
      Log in to FusionInsight Manager and choose Cluster > Services > HetuEngine. Click Configurations and then All Configurations, and search for tenant.strict.mode.enabled to view the value.
    3. (Optional) Customize the configuration.
      • Click Add to add custom configuration parameters. Configure custom parameters of the HetuEngine data source. For details, see Table 2.
        Table 2 Custom parameters of the HetuEngine data source
        Name
        Example Value
        hsfabric.health.check.time
        Interval for checking the HSFabric instance status, in seconds.
        60
        hsfabric.subquery.pushdown
        Whether to enable cross-domain query pushdown. The function is enabled by default.
        • true: enables cross-domain query pushdown.
        • false: disables cross-domain query pushdown.
        true
      • You can click Delete to delete custom configuration parameters.
    4. Click OK.
  5. Log in to the node where the cluster client is located and run the following commands to switch to the client installation directory and authenticate the user:
    cd /opt/client
    source bigdata_env
    kinit User performing HetuEngine operations (If the cluster is in normal mode, skip this step.)
  6. Log in to the catalog of the data source.
    hetu-cli --catalog Data source name --schema Database name
    For example, run the following command:
    hetu-cli --catalog hetuengine_1 --schema default
  7. Run the following command. If the database table information can be viewed or no error is reported, the connection is successful.
    show tables;
Cross-Cluster HetuEngine Data Type Mapping
Currently, HetuEngine data sources support the following data types: BOOLEAN, TINYINT, SMALLINT, INT, BIGINT, REAL, DOUBLE, DECIMAL, VARCHAR, CHAR, DATE, TIMESTAMP, ARRAY, MAP, TIME WITH TIMEZONE, TIMESTAMP WITH TIME ZONE, and TIME.
Performance Optimization
The query pushdown function is supported to improve query speed.
This function is enabled by default. You can also enable it by adding related custom parameters according to 4.c.
Constraints on Cross-Cluster HetuEngine Data Sources
The following syntaxes are not supported: CREATE, ALTER, DROP VIEW, INSERT OVERWRITE, UPDATE, and DELETE.
INSERT is not supported for cross-domain data sources.
