Help Center/ MapReduce Service/ Component Operation Guide (LTS)/ Using HDFS/ Common Issues About HDFS/ Why are There Two Standby NameNodes After the active NameNode Is Restarted?
Updated on 2025-07-16 GMT+08:00
Question
Why are there two standby NameNodes after the active NameNode is restarted?
When this problem occurs, check the ZooKeeper and ZooKeeper FC logs. You can find that the sessions used for the communication between the ZooKeeper server and client (ZKFC) are inconsistent. The session ID of the ZooKeeper server is 0x164cb2b3e4b36ae4, and the session ID of the ZooKeeper FC is 0x144cb2b3e4b36ae4. Such inconsistency means that the data interaction between the ZooKeeper server and ZKFC fails.
Content of the ZooKeeper log is as follows:
2015-04-15 21:24:54,257 | INFO | CommitProcessor:22 | Established session 0x164cb2b3e4b36ae4 with negotiated timeout 45000 for client /192.168.0.117:44586 | org.apache.zookeeper.server.ZooKeeperServer.finishSessionInit(ZooKeeperServer.java:623)
2015-04-15 21:24:54,261 | INFO | NIOServerCxn.Factory:192-168-0-114/192.168.0.114:2181 | Successfully authenticated client: authenticationID=hdfs/hadoop@<System domain name>; authorizationID=hdfs/hadoop@<System domain name>. | org.apache.zookeeper.server.auth.SaslServerCallbackHandler.handleAuthorizeCallback(SaslServerCallbackHandler.java:118)
2015-04-15 21:24:54,261 | INFO | NIOServerCxn.Factory:192-168-0-114/192.168.0.114:2181 | Setting authorizedID: hdfs/hadoop@<System domain name> | org.apache.zookeeper.server.auth.SaslServerCallbackHandler.handleAuthorizeCallback(SaslServerCallbackHandler.java:134)
2015-04-15 21:24:54,261 | INFO | NIOServerCxn.Factory:192-168-0-114/192.168.0.114:2181 | adding SASL authorization for authorizationID: hdfs/hadoop@<System domain name> | org.apache.zookeeper.server.ZooKeeperServer.processSasl(ZooKeeperServer.java:1009)
2015-04-15 21:24:54,262 | INFO | ProcessThread(sid:22 cport:-1): | Got user-level KeeperException when processing sessionid:0x164cb2b3e4b36ae4 type:create cxid:0x3 zxid:0x20009fafc txntype:-1 reqpath:n/a Error Path:/hadoop-ha/hacluster/ActiveStandbyElectorLock Error:KeeperErrorCode = NodeExists for /hadoop-ha/hacluster/ActiveStandbyElectorLock | org.apache.zookeeper.server.PrepRequestProcessor.pRequest(PrepRequestProcessor.java:648)
Content of the ZKFC log is as follows:
2015-04-15 21:24:54,237 | INFO | main-SendThread(192-168-0-114:2181) | Socket connection established to 192-168-0-114/192.168.0.114:2181, initiating session | org.apache.zookeeper.ClientCnxn$SendThread.primeConnection(ClientCnxn.java:854)
2015-04-15 21:24:54,257 | INFO | main-SendThread(192-168-0-114:2181) | Session establishment complete on server 192-168-0-114/192.168.0.114:2181, sessionid = 0x144cb2b3e4b36ae4 , negotiated timeout = 45000 | org.apache.zookeeper.ClientCnxn$SendThread.onConnected(ClientCnxn.java:1259)
2015-04-15 21:24:54,260 | INFO | main-EventThread | EventThread shut down | org.apache.zookeeper.ClientCnxn$EventThread.run(ClientCnxn.java:512)
2015-04-15 21:24:54,262 | INFO | main-EventThread | Session connected. | org.apache.hadoop.ha.ActiveStandbyElector.processWatchEvent(ActiveStandbyElector.java:547)
2015-04-15 21:24:54,264 | INFO | main-EventThread | Successfully authenticated to ZooKeeper using SASL. | org.apache.hadoop.ha.ActiveStandbyElector.processWatchEvent(ActiveStandbyElector.java:573)
Answer
  • Cause Analysis
    After the active NameNode restarts, the temporary node /hadoop-ha/hacluster/ActiveStandbyElectorLock created on ZooKeeper is deleted. After the standby NameNode receives that information that the /hadoop-ha/hacluster/ActiveStandbyElectorLock node is deleted, the standby NameNode creates the /hadoop-ha/hacluster/ActiveStandbyElectorLock node in ZooKeeper in order to switch to the active NameNode. However, when the standby NameNode connects with ZooKeeper through the client ZKFC, the session ID of ZKFC differs from that of ZooKeeper due to network issues, overload CPU, or overload clusters. In this case, the watcher of the standby NameNode fails to detect that the temporary node has been successfully created, and fails to consider the standby NameNode as the active NameNode. After the original active NameNode restarts, it detects that the /hadoop-ha/hacluster/ActiveStandbyElectorLock already exists and becomes the standby NameNode. Therefore, both NameNodes are standby NameNodes.
  • Solution
    You are advised to restart two ZKFCs of HDFS on FusionInsight Manager.
