Updated on 2025-11-13 GMT+08:00
Optimizing HDFS NameNode RPC QoS
When NameNodes are overloaded and fail to respond, the Hadoop clusters may be blocked. This is caused by the initial design of Hadoop. In Hadoop, the NameNode functions as an independent device and coordinates various HDFS operations in its namespace. These operations include obtaining data block locations, listing directories, and creating files. The NameNode receives HDFS operations, regards them as RPC calls, and places them in the FIFO call queue for read threads to process. Requests in FIFO call queue are served first-in first-out. However, users who perform more I/O operations are served more time than those performing fewer I/O operations. In this case, the FIFO is unfair and causes the delay.
Figure 1 NameNode request processing based on the FIFO call queue
The unfair problem and delaying mentioned before can be improved by replacing the FIFO queue with a new type of queue called FairCallQueue. In this way, FAIR queues assign incoming RPC calls to multiple queues based on the scale of the caller's call. The scheduling module tracks the latest calls and assigns a higher priority to users with a smaller number of calls.
Figure 2 NameNode request processing based on FAIRCallQueue
Notes and Constraints
This section applies to MRS 3.x or later.
  • FairCallQueue ensures quality of service (QoS) by internally adjusting the order in which RPCs are invoked.
    This queue consists of the following parts:
    • DecayRpcScheduler: used to provide priority values from 0 to N (the value 0 indicates the highest priority).
    • Multi-level queues (located in the FairCallQueue): used to ensure that queues are invoked in order of priority.
    • Multi-channel converters (provided with Weighted Round Robin Multiplexer): used to provide logic control for queue selection.
    After the FairCallQueue is configured, the control module determines the sub-queue to which the received invoking is allocated. The current scheduling module is DecayRpcScheduler. This module continuously tracks the priority numbers of various invoking requests and periodically decreases the numbers.
    To configure the FairCallQueue, perform the following steps:
      For details about how to log in to FusionInsight Manager, see Accessing MRS Manager.
    2. Choose Cluster > Services > HDFS > Configurations > All Configurations.
    3. Search for the following parameters and change their values as required.
      Table 1 FairCallQueue parameters
      Default Value
      ipc.<port>.callqueue.impl
      Specifies the queue implementation class.
      The options are as follows:
      • java.util.concurrent.LinkedBlockingQueue: uses the FIFO queue.
      • org.apache.hadoop.ipc.FairCallQueue: enables the QoS feature.
      • org.apache.hadoop.ipc.PriorityCallQueue: processes msync requests from the NameNode more efficiently, thereby improving the processing capability of the NameNode.
    4. Save the settings. Restart the expired service or instance for the configuration to take effect.
  • RPC BackOff
    Backoff is one of the FairCallQueue functions. It requires the client to retry operations (such as creating, deleting, and opening a file) after a period of time. When the backoff occurs, the RCP server throws RetriableException. The FairCallQueue performs backoff in either of the following cases:
    • The queue is full, that is, there are many client calls in the queue.
    • The queue response time is longer than the threshold time (specified by the ipc.<port>.decay-scheduler.backoff.responsetime.thresholds parameter).
    To configure the RPC BackOff, perform the following steps:
    3. Search for the following parameters and change their values as required. <port> indicates the RPC port configured on the NameNode.
      Table 2 RPC Backoff configuration
      Default Value
      ipc.<port>.backoff.enable
      Indicates whether to enable the backoff function.
      When the current application contains a large number of user callings, the RPC request is blocked if the connection limit of the operating system is not reached. Alternatively, when the RPC or NameNode is heavily loaded, some explicit exceptions can be thrown back to the client based on certain policies. The client can understand these exceptions and perform exponential rollback, which is another implementation of the RetryInvocationHandler class.
      The backoff function based on the response time takes effect only when ipc.<port> .backoff.enable is set to true.
      false
      ipc.<port>.decay-scheduler.backoff.responsetime.enable
      Indicate whether to enable the backoff based on the average queue response time.
      false
      Configure the response time threshold for each queue.
      The response time threshold must match the number of priorities (the value of ipc.<port> .faircallqueue.priority-levels). Unit: millisecond
      10000,20000,30000,40000
