Updated on 2025-11-13 GMT+08:00
Using the HDFS Client
This section describes how to perform operations, such as reading and writing files, on HDFS using the HDFS client in O&M or service scenarios.
  • You have installed the client.
    For example, the installation directory is /opt/client. The client directory in the following operations is only an example. Change it based on the actual installation directory onsite.
  • Service users of each component are created by the MRS cluster administrator based on service requirements. In security mode, machine-machine users need to download the keytab file. A human-machine user needs to change the password upon the first login. (This operation is not required in normal mode.)
  1. Install the client. If the client has been installed, skip this step.
    For example, the installation directory is /opt/client. You need to change it to the actual installation directory.
    For details about how to download and install the cluster client, see Installing an MRS Cluster Client.
  2. Log in to the node where the client is installed as the client installation user.
  3. Go to the client installation directory, for example, /opt/client.
    cd /opt/client
  4. Run the following command to configure environment variables:
    source bigdata_env
  5. If the cluster is in security mode, run the following command to authenticate the user. If the cluster is in normal mode, skip this step.
    kinit Component service user
  6. Run the HDFS Shell command. Example:
    hdfs dfs -ls /
Common HDFS Client Commands
  • Common HDFS Client Commands
    Table 1 describes the common HDFS client commands.
    Table 1 Common HDFS client commands
    Operation
    Command
    Creating a folder
    hdfs dfs -mkdir Folder name
    Create the /tmp/mydir folder.
    hdfs dfs -mkdir /tmp/mydir
    Viewing a folder
    hdfs dfs -ls Folder name
    hdfs dfs -ls /tmp
    Uploading a local file to a specified HDFS path
    hdfs dfs -put Local file on the client node Specified HDFS path
    Upload the /opt/test.txt file on the client node to the /tmp directory of HDFS.
    hdfs dfs -put /opt/test.txt /tmp
    Downloading the HDFS file to the specified local path
    hdfs dfs -get Specified file on HDFS Specified path on the client node
    Download the /tmp/test.txt file on HDFS to the /opt directory on the client node.
    hdfs dfs -get /tmp/test.txt /opt/
    Deleting a folder
    hdfs dfs -rm -r -f Specified folder on HDFS
    Delete the /tmp/mydir folder.
    hdfs dfs -rm -r -f /tmp/mydir
    Configuring the HDFS directory permission for a user
    hdfs dfs -chmod Permission parameter File directory
    Configure the 700 permission of the /tmp/test directory.
    hdfs dfs -chmod 700 /tmp/test
  • Transparent Encryption Commands
    Table 2 Transparent encryption commands
    Operation
    Command
    Creating a key
    hadoop key create<keyname> [-cipher <cipher>] [-size <size>] [-description <description>] [-attr <attribute=value>] [-provider <provider>] [-help]
    The create subcommand creates a new key for the name specified by <keyname> in provider. The provider is specified by the -provider parameter. You can use the -cipher parameter to define a password. The default password is AES/CTR/NoPadding.
    The default key length is 128. You can use the -size parameter to define a key length. Any attribute of the attribute=value type can be defined by the -attr parameter. -attr can be defined many times for each attribute.
    Performing a rollback
    hadoop key roll<keyname> [-provider <provider>] [-help]
    The roll subcommand creates a new version for the key specified in provider. The provider is specified by the -provider parameter.
    Deleting a key
    hadoop key delete<keyname> [-provider <provider>] [-f] [-help]
    The delete subcommand deletes all versions of a key. The key is specified by the <keyname> parameter in provider, and the provider is specified by the -provider parameter. The command needs to be confirmed unless -f is specified.
    Viewing a key
    hadoop key list[-provider <provider>] [-metadata] [-help]
    The list subcommand displays all key names in provider. The provider is configured in the core-site.xml or specified by the -provider parameter. The -metadata parameter displays metadata.
  • Shell Commands of the Colocation Client
    Table 3 Shell commands of the Colocation client
    Operation
    Command
    Creating a user group
    hdfs colocationadmin -createGroup -groupId
    <groupID> -locatorIds <comma separated locatorIDs> or -file <path of the file contains all of locatorIDs>
    Used to create a group. In the command, groupID indicates the group name and locatorID indicates the locator name. You can enter locator IDs through CLI. Multiple locator IDs are separated by commas (,). Locator IDs can be written into a file so that the system can obtain locator IDs by reading the file.
    Deleting a group
    hdfs colocationadmin -deleteGroup <groupID>
    Used to delete the specified group.
    Querying a group
    hdfs colocationadmin -queryGroup <groupID>
    Used to query details about a specified group, including locators in the group and information about each locator and their DataNodes.
    Viewing all groups
    hdfs colocationadmin -listGroups
    Used to list all groups and their creation time.
    Setting ACL permission of Colocation root directory
    hdfs colocationadmin -setAcl
    Used to set the ACL permission of the Colocation root directory in ZooKeeper.
    The default root directory of Colocation in ZooKeeper is /hadoop/colocationDetails.
Helpful Links
  • The following lists more common problems about using the HDFS client:
