Deleting HBase Data in Batches Using BulkLoad
BulkLoad deletes HBase data in batches based on the row key naming rule, row key scope, field name, and field value.
Run the following command to delete the rows from row_start to row_stop and direct the output to /output/destdir/.
hbase com.huawei.hadoop.hbase.tools.bulkload.DeleteData
-Ddelete.rowkey.start="row_start"
-Ddelete.rowkey.stop="row_stop"
-Ddelete.hfile.output="/output/destdir/"
-Ddelete.qualifier="cf1,cf0:vch,cf0:lng:1000"
'table1'
- -Ddelete.rowkey.start="row_start": indicates that the start row number is row_start.
- -Ddelete.rowkey.stop="row_stop": indicates that the end row number is row_stop.
- -Ddelete.hfile.output="/output/destdir/": indicates that the output results are directed to /output/destdir/.
- -Ddelete.qualifier="cf1,cf0:vch,cf0:lng:1000": indicates that all columns in column family cf1, the vch column in column family cf0, and the column whose value is 1,000 in column lng in column family cf0 are to be deleted.
If transparent encryption is configured for HBase, see 7 for precautions on batch deletion.
Run the following command to load HFiles:
hbase org.apache.hadoop.hbase.mapreduce.LoadIncrementalHFiles <path/for/output> <tablename>
Precautions
- If indexes have been created for column qualifier, the field cannot be deleted in batches.
- If you do not set the execution result file delete.hfile.output, the default directory to store the result is /tmp/deletedata/table name.
