Updated on 2026-06-27 GMT+08:00
Configuring Flink Authentication and Encryption
Security Authentication
Flink supports the following authentication modes:
  • Kerberos authentication: It is used between the Flink Yarn client and Yarn ResourceManager, JobManager and ZooKeeper, JobManager and HDFS, TaskManager and HDFS, Kafka and TaskManager, as well as TaskManager and ZooKeeper.
  • Security cookie authentication: Security cookie authentication is used between Flink Yarn client and JobManager, JobManager and TaskManager, as well as TaskManager and TaskManager.
  • Internal authentication of Yarn: The Internal authentication mechanism of Yarn is used between Yarn ResourceManager and ApplicationMaster (AM).
    • Flink JobManager and Yarn ApplicationMaster are in the same process.
    • If Kerberos authentication is enabled for the user's cluster, Kerberos authentication is required.
    Table 1 Authentication modes
    Authentication Mode
    Configuration Method
    Currently, only keytab authentication mode is supported.
    1. Download the user keytab file from FusionInsight Manager and save the keytab file to a folder on the host where the Flink client is located.
    2. Configure the following parameters in the flink-conf.yaml file:
      1. Keytab path
        security.kerberos.login.keytab: /home/flinkuser/keytab/abc222.keytab
        /home/flinkuser/keytab/abc222.keytab indicates the user directory.
      2. Principal name
        security.kerberos.login.principal: abc222
      3. In HA mode, if ZooKeeper is configured, the Kerberos authentication configuration items must be configured as follows:
        zookeeper.sasl.disable: false
        security.kerberos.login.contexts: Client
      4. If you want to perform Kerberos authentication between Kafka client and Kafka broker, set the value as follows:
        security.kerberos.login.contexts: Client,KafkaClient
    1. In the bin directory of the Flink client, call the generate_keystore.sh script to generate Security cookie, flink.keystore, and flink.truststore.
      Run the sh generate_keystore.sh command and enter the user-defined password. The password cannot contain #.
      After the script is executed, the flink.keystore and flink.truststore files are generated in the conf directory on the Flink client. In the flink-conf.yaml file, default values are specified for following parameters:
      • Parameter security.ssl.keystore is set to the absolute path of the flink.keystore file.
      • Parameter security.ssl.truststore is set to the absolute path of the flink.truststore file.
      • Parameter security.cookie is set to a random password automatically generated by the generate_keystore.sh script.
      • The value of security.ssl.encrypt.enabled is true in the flink-conf.yaml file by default. If this parameter is set to false, you can run the generate_keystore.sh script to automatically replace the values of security.ssl.key-password, security.ssl.keystore-password, and security.ssl.truststore-password with the password entered during script execution.
        cd /opt/hadoopclient/Flink/flink/bin
        The script automatically changes the SSL-related parameter values in the /opt/hadoopclient/Flink/flink/conf/flink-conf.yaml file.
      • The value of security.ssl.encrypt.enabled is true in the flink-conf.yaml file by default. If this parameter is set to true, the generate_keystore.sh script does not configure the values of security.ssl.key-password, security.ssl.keystore-password, and security.ssl.truststore-password. To obtain the password, call the Manager plaintext encryption API to run the curl -k -i -u Username:Password -X POST -HContent-type:application/json -d '{"plainText":"Password"}' 'https://x.x.x.x:28443/web/api/v2/tools/encrypt' command.
        In the preceding command, Username:Password indicates the username and password for logging in to the system. The password of "plainText" is used to invoke the generate_keystore.sh script. x.x.x.x indicates the floating IP address of FusionInsight Manager. Commands carrying authentication passwords pose security risks. Disable historical command recording before running such commands to prevent information leakage.
    2. Check whether Security Cookie is enabled. That is, check security.enable: true in the flink-conf.yaml file and check whether security cookie is configured. An example is as follows:
      security.cookie: ae70acc9-9795-4c48-ad35-8b5adc8071744f605d1d-2726-432e-88ae-dd39bfec40a9
    The validity period of the SSL certificate obtained by using the generate_keystore.sh script preset on the MRS client is 5 years.
    To disable the default SSL authentication mode, set security.ssl.enabled to false in the flink-conf.yaml file and comment out security.ssl.key-password, security.ssl.keystore-password, security.ssl.keystore, security.ssl.truststore-password, and security.ssl.trustore.
    This authentication mode does not need to be configured by the user.
    One Flink cluster supports only one user. One user can create multiple Flink clusters.
Encrypted Transmission
Flink supports three encrypted transmission modes:
  • Encrypted transmission inside Yarn: It is used between the Flink Yarn client and Yarn ResourceManager, as well as Yarn ResourceManager and JobManager.
  • SSL transmission: SSL transmission is used between Flink Yarn client and JobManager, JobManager and TaskManager, as well as TaskManager and TaskManager.
  • Encrypted transmission inside Hadoop: The internal encrypted transmission mode of Hadoop used between JobManager and HDFS, TaskManager and HDFS, JobManager and ZooKeeper, as well as TaskManager and ZooKeeper.
Configuration about SSL encrypted transmission is mandatory while configuration about encryption of Yarn and Hadoop is not required.
To configure SSL encrypted transmission, configure the following parameters in the flink-conf.yaml file on the client:
  1. Turn on the SSL switch and set SSL encryption algorithms. Table 2 describes the parameters. Set the parameters based on your need.
    Table 2 Parameter description
    Example Value
    true
    Enable SSL.
    akka.ssl.enabled
    true
    Enable Akka SSL.
    blob.service.ssl.enabled
    true
    Enable SSL for the Blob channel.
    taskmanager.data.ssl.enabled
    true
    Enable SSL transmissions between TaskManagers.
    security.ssl.algorithms
    TLS_DHE_RSA_WITH_AES_128_GCM_SHA256,TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256,TLS_DHE_RSA_WITH_AES_256_GCM_SHA384,TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384
    Configure the SSL encryption algorithm.
    Enabling SSL for data transmission between TaskManagers may pose great impact on the system performance.
  2. In the bin directory of the Flink client, run the sh generate_keystore.sh <Password> command. The configuration items in Table 3 are set by default. You can change the configurations. Commands containing authentication passwords pose security risks. Disable the command recording function (history) before running such commands to prevent information leakage.
    Table 3 Parameter description
    Example Value
    ${path}/flink.keystore
    Path for storing the keystore. flink.keystore indicates the name of the keystore file generated by the generate_keystore.sh* tool.
    A user-defined password of keystore.
    A user-defined password of the SSL key.
    ${path}/flink.truststore
    Path for storing the truststore. flink.truststore indicates the name of the truststore file generated by the generate_keystore.sh* tool.
    A user-defined password of truststore.
    The path directory is a user-defined directory for storing configuration files of the SSL keystore and truststore.
  3. Configure the paths for the client to access the keystore or truststore file.
    • Relative path (recommended)
      Perform the following steps to set the file paths of flink.keystore and flink.truststore to relative paths and ensure that the directory where the Flink client command is executed can directly access the relative paths.
      1. In the conf/ directory of the Flink client, create a directory, for example, ssl.
        cd / Flink client directory/Flink/flink/conf/
        mkdir ssl
      2. Move the flink.keystore and flink.truststore files to the new paths.
        mv flink.keystore ssl/
        mv flink.truststore ssl/
      3. Change the values of the following parameters to relative paths in the flink-conf.yaml file:
        vi / Flink client directory/Flink/flink/conf/flink-conf.yaml
        security.ssl.keystore: ssl/flink.keystore
        security.ssl.truststore: ssl/flink.truststore
    • Absolute path
      After the generate_keystore.sh script is executed, the flink.keystore and flink.truststore file paths are automatically set to absolute paths in the flink-conf.yaml file by default. In this case, you need to place the flink.keystore and flink.truststore files in the conf directory to the absolute paths of the Flink client and each Yarn node, respectively.
