On this page
CarbonData Table User Permissions
The following table provides details about Hive ACL permissions required for performing operations on CarbonData tables.
Parameters listed in Table 5 or Table 6 have been configured.
Table 1 Hive ACL permissions required for CarbonData table-level operations
Required Permission
DESCRIBE TABLE
SELECT (of table)
SELECT
SELECT (of table)
EXPLAIN
SELECT (of table)
CREATE TABLE
CREATE (of database)
CREATE TABLE As SELECT
CREATE (on database), INSERT (on table), RW on data file, and SELECT (on table)
LOAD
INSERT (of table) RW on data file
DROP TABLE
OWNER (of table)
DELETE SEGMENTS
DELETE (of table)
SHOW SEGMENTS
SELECT (of table)
CLEAN FILES
DELETE (of table)
INSERT OVERWRITE / INSERT INTO
INSERT (of table) RW on data file and SELECT (of table)
CREATE INDEX
OWNER (of table)
DROP INDEX
OWNER (of table)
SHOW INDEXES
SELECT (of table)
ALTER TABLE ADD COLUMN
OWNER (of table)
ALTER TABLE DROP COLUMN
OWNER (of table)
ALTER TABLE CHANGE DATATYPE
OWNER (of table)
ALTER TABLE RENAME
OWNER (of table)
ALTER TABLE COMPACTION
INSERT (on table)
FINISH STREAMING
OWNER (of table)
ALTER TABLE SET STREAMING PROPERTIES
OWNER (of table)
ALTER TABLE SET TABLE PROPERTIES
OWNER (of table)
UPDATE CARBON TABLE
UPDATE (of table)
DELETE RECORDS
DELETE (of table)
REFRESH TABLE
OWNER (of main table)
REGISTER INDEX TABLE
OWNER (of table)
SHOW PARTITIONS
SELECT (on table)
ALTER TABLE ADD PARTITION
OWNER (of table)
ALTER TABLE DROP PARTITION
OWNER (of table)
  • If tables in the database are created by multiple users, the Drop database command fails to be executed even if the user who runs the command is the owner of the database.
  • In a secondary index, when the parent table is triggered, insert and compaction are triggered on the index table. If you select a query that has a filter condition that matches index table columns, you should provide selection permissions for the parent table and index table.
  • The LockFiles folder and lock files created in the LockFiles folder will have full permissions, as the LockFiles folder does not contain any sensitive data.
  • If you are using ACL, ensure you do not configure any path for DDL or DML which is being used by other process. You are advised to create new paths.
    Configure the path for the following configuration items:
    1) carbon.badRecords.location
    2) Db_Path and other items during database creation
  • For Carbon ACL in a non-security cluster, hive.server2.enable.doAs in the hive-site.xml file must be set to false. Then the query will run as the user who runs the hiveserver2 process.
