Open Source sqoop-shell Tool Usage Guide
Overview
Sqoop-shell is a shell tool of Loader. All its functions are implemented by executing the sqoop2-shell script.
The sqoop-shell tool provides the following functions:
- Creating and updating connectors
- Creating and updating jobs
- Deleting connectors and jobs
- Starting jobs in the synchronous or asynchronous mode.
- Stopping jobs
- Viewing job status
- Viewing historical execution records of jobs
- Cloning connectors and jobs
- Creating and updating conversion steps
- Specifying line and field separators
The sqoop-shell tool supports the following modes:
- Interaction mode
Users execute the sqoop2-shell script without parameters to go to the particular interaction window of Loader. After the contents of the script are input, the tool returns the relevant information to the interaction window.
- Batch mode
The sqoop2-shell script has a file name as a parameter and multiple commands are stored in lines in the file. The sqoop-shell tool runs all commands in the file in sequence by executing the script. Alternatively, users can execute the sqoop2-shell script, to the end of which a command is attached with the -c parameter as the bridge. In this case, the sqoop-shell tool runs one command each time.
The sqoop-shell implements functions of Loader by running the commands in Table 1.
| Command | Description |
| exit | Exits the interaction mode. This command is supported only in the interaction mode. |
| history | Views the executed commands. This command is supported only in the interaction mode. |
| help | Views the tool help information. |
| set | Sets server attributes. |
| show | Displays service attributes and all the metadata information of Loader. |
| create | Creates connectors and jobs. |
| update | Updates connectors and jobs. |
| delete | Deletes connectors and jobs. |
| clone | Clones connectors and jobs. |
| start | Starts jobs. |
| stop | Stops jobs. |
| status | Views job status. |
Commands
- The sqoop2-shell tool provides two methods to obtain login authentication information. The first method is to obtain login authentication information from the configuration file. For details about the configuration items, see Importing Data to HDFS Using sqoop-shell and Importing Data to HDFS Using sqoop-shell. The second one is to obtain the authentication information by using parameters. Two modes are available in the second method: password mode and Kerberos authentication mode.
- Command for accessing the interaction mode
Execute the sqoop2-shell script without parameters to go to the sqoop tool window and run the commands one by one.
Run the following command to obtain the authentication information by reading the configuration file:
./sqoop2-shell
Run the following command to authenticate login using the password mode:
./sqoop2-shell -uk false -u username -p encryptedPassword
Commands containing authentication passwords pose security risks. Disable the command recording function (history) before running such commands to prevent information leakage.
Run the following command to authenticate login using the Kerberos mode:
./sqoop2-shell -uk true -k user.keytab -s userPrincipal
The following information is displayed:
Welcome to sqoop client Use the username and password authentication mode Authentication success. Sqoop Shell: Type 'help' or '\h' for help. sqoop:000>
- Command for entering the batch mode
Two methods are available for accessing the batch mode.
- Execute the sqoop2-shell script, in which a file name is used as a parameter and multiple commands are stored in lines in this file. The sqoop-shell tool runs all commands in the file in sequence. The script must be stored in the home directory of the current user, for example, /root/batchCommand.sh.
Run the following command to authenticate login by reading configuration files:
./sqoop2-shell /root/batchCommand.sh
./sqoop2-shell -uk false -u username -p encryptedPassword /root/batchCommand.sh
./sqoop2-shell -uk true -k user.keytab -s userPrincipal /root/batchCommand.sh
batchCommand.sh is the user-defined name of the text file.
- Execute the sqoop2-shell script, to the end of which a command is attached with the -c parameter as the bridge. The sqoop-shell tool will execute the command.
./sqoop2-shell -c expression
./sqoop2-shell -uk false -u username -p encryptedPassword -c expression
./sqoop2-shell -uk true -k user.keytab -s userPrincipal -c expression
expression is the attached statement, whose format is the same as that in the text file in the first method.
- Exit command
This command is used for exiting the interaction mode and supported only in the interaction mode.
Example:
Welcome to sqoop client Use the username and password authentication mode Authentication success. Sqoop Shell: Type 'help' or '\h' for help. sqoop:000> exit 10-5-211-9:/opt/hadoopclient/Loader/loader-tools-1.99.3/sqoop-shell#
- History command
This command is used for viewing the executed commands and supported only in the interaction mode.
Example:
sqoop:000> history 0 show connector 1 create connection -c 4 2 show connections; 3 show connection; 4 show connection -a; 5 show connections; 6 show connection; 7 show connection -x 53; 8 show connection -x 52; 9 show connection -x 2 10 show connection -x 53; 11 show connection 12 show connection -x 53 13 create job -x 53 -t import 14 show connector 15 create connection -c 5 16 show connection -x 54 17 exit 18 show connector 19 create connection -c 5 20 exit 21 show connector 22 create connection -c 6 23 create job -x 20 -t import 24 start job -j 85 -s 25 \x 26 exit 27 history sqoop:000>
- Help command
This command is used for viewing the tool help information.
Example:
sqoop:000> help For information about Sqoop, visit: http://sqoop.apache.org/docs/1.99.3/index.html Available commands: exit (\x ) Exit the shell history (\H ) Display, manage and recall edit-line history help (\h ) Display this help message set (\st ) Set server or option Info show (\sh ) Show server, connector, framework, connection, job, submission or option Info create (\cr ) Create connection or job Info delete (\d ) Delete connection or job Info update (\up ) Update connection or job Info clone (\cl ) Clone connection or job Info start (\sta) Start job stop (\stp) Stop job status (\stu) Status job For help on a specific command type: help command sqoop:000>
- Set command
The set command is used for setting attributes of clients and servers and supports the following attributes:
- server indicates setting the connection attributes for servers.
When attribute -u is set, attributes -h, -p, and -w can be ignored.
- option indicates setting the client attributes.
option can be set by key values. For example, set option --name verbose --value true.
Attribute Type
Subattribute
server
-h,--host
Service IP address.
-p,--port
Service Port
-w,--webapp
Tomcat application name.
-u,--url
Sqoop service URL.
option
verbose
Redundancy mode, which indicates that more information is printed.
poll-timeout
Sets the polling timeout duration.
Example:
set option --name verbose --value false set server --host 10.0.0.1 --port 21351 --webapp loader
- show command
This command is used for displaying information, such as variable information and storage metadata information.
Attribute Type
Subattribute
server
-a,--all
Displays all server attributes.
-p,--port
Displays the service port.
-w,--webapp
Displays the Tomcat application name.
-h,--host
Displays the service IP address.
option
-name
Displays the attributes of the specified name.
connector
-a,--all
Displays information about all connection types.
-c,--cid
Displays information about the connection type of a specified ID.
framework
None.
Displays metadata information about frameworks.
connection
-a,--all
Displays all connection attributes.
-x,--xid
Displays the attributes of a specified connection.
-n,--name
Displays the connection attributes of a specified name.
job
-a,--all
Displays information about all jobs.
-j,--jid
Displays job information about a specified ID.
-n,--name
Displays job information about a specified name.
submission
-j,--jid
Displays the submission record of a specified job.
-d,--detail
Displays details.
Example:
show server -all show option --name verbose show connector -all show framework show connection -all show connection -n sftp-example show job -all show job -j 1 show submission --jid 1 show submission --jid 1 -d
- Create command This command is used for creating connectors and jobs.
Attribute Type
Subattribute
connection
-c,--cid
Specifies the ID of a connector type.
-cn,--cname
Specifies the name of a specified connector type.
job
-x,--xid
Specifies the connector ID.
-xn,--xname
Specifies the connector name.
-t,--type
Specifies the job type.
Possible values:- import
- export
- In the interaction mode, enter the attribute values one by one as prompted.
Example for creating connectors:
create connection -c 1 create connection -cn example
Example for creating jobs:
create job -x 1 -t import create job -xn job_example -t export
- In the batch mode, run the following command to view the specific attribute and then set a value for the attribute:
create job -t import -x 1 --help
You can run the above command in either of the following ways:
Save the command to a text file and attach this file to the end of the sqoop-shell script, and run the following command:
./sqoop2-shell batchCommand.sh
Attach a command with the -c parameter to the end of the sqoop-shell script and run the following command:
For details about command execution, refer to previous description in this section. The following shows two complete commands:
create connection -c 4 --connector-connection-sftpPassword xxxxx --connector-connection-sftpServerIp 10.0.0.1 --connector-connection-sftpServerPort 22 --connector-connection-sftpUser root--name testConnection
create job -t import -x 1 --connector-file-inputPath /opt/tempfile --connector-file-fileFilter * --framework-output-outputDirectory /user/loader/1 --framework-output-storageType HDFS --framework-throttling-extractorSize 120 --framework-output-fileType TEXT_FILE --connector-file-splitType FILE -queue default -priority low -name newJob
- In the batch mode, you can attach a statement using the -c parameter as the bridge.
./sqoop2-shell -c "create connection -c 4 --connector-connection-sftpPassword xxxxx --connector-connection-sftpServerIp 10.0.0.1 --connector-connection-sftpServerPort 22 --connector-connection-sftpUser root--name testConnection"
- update command
This command is used for updating connectors and jobs.
Attribute Type
Subattribute
connection
-x,--xid
NOTE:When the connectors are updated, the password must be set.
job
-j,--jid
Specifies the job ID.
- Interaction mode
Example for updating connectors:
update connection --xid 1
Example for updating jobs:
update job --jid 1
- Batch mode
update connection -x 6 --connector-connection-sftpServerPort 21 - --name sfp_130--connector-connection-sftpPassword xxxx
Example 1:
update job -jid 1 -name sftp2hdfs --connector-file-fileFilter *.txt
Example 2:
./sqoop2-shell -uk true -k /opt/loader/user.keytab -s luser /opt/loader/testupdate.txt ./sqoop2-shell -uk true -k /opt/loader/user.keytab -s luser -c "update job --jid 24 --name oracle-hive --connector-table-sql 'SELECT * FROM range_example WHERE replace(datadt,\'-\',\'\')='20240801' and \${CONDITIONS}'"
When updating a job, you can write the update commands in a file, for example, /opt/loader/testupdate.txt (the file name can be customized), or specify the commands using --connector-table-sql, in which the sql command must be enclosed in single quotation marks ('). For details, see example 2. Involved commands include connector-table-sql, connector-table-columns, connector-table-partitionColumn, connector-table-conditions, connector-table-queryCondition.
- Interaction mode
- delete command
This command is used for deleting connectors and jobs.
Attribute Type
Subattribute
connection
-x,--xid
-n,--name
job
-j,--jid
-n,--name
Specifies the job name.
Example:
delete connection -x 1 delete connection --name abc delete job -j 1 delete job -n qwerty
- clone command
This command is used for cloning connectors and jobs.
Attribute Type
Subattribute
connection
-x,--xid
NOTE:The password and connector name must be entered when the connectors are cloned.
job
-j,--jid
Example:
clone job -j 1
- start command
This command is used for starting jobs.
Attribute Type
Subattribute
job
-j,--jid
-n,--name
-s,--synchronous
Whether to start jobs in the synchronous mode or not.
Example for starting jobs in the asynchronous mode:
start job -j 1 start job -n abc
Example for starting jobs in the synchronous mode:
start job -j 1 -s start job --name abc --synchronous
- stop command
This command is used for stopping jobs.
Attribute Type
Subattribute
job
-j,--jid
-n,--name
Example:
stop job -j 1 stop job -n abc
- Status command
This command is used for viewing job status.
Attribute Type
Subattribute
job
-j,--jid
When -s parameter is attached to the command, the result only contains the enumerated value of job status.
Example:
status job -j 1 status job -j 1 -s
Extended Attributes of Create Command
For the scenario in which HDFS exchanges data with the SFTP server or RDB, MRS extends the create command attributes on the basis of the open source sqoop-shell tool, so as to specify line and field separators and conversion steps when jobs are created.
| Property | Description |
| fields-terminated-by | Default field separator. |
| lines-terminated-by | Default line separator. |
| input-fields-terminated-by | Inputs the step field separator. If the step field separator is not specified, the value equals to fields-terminated-by by default. |
| input-lines-terminated-by | Inputs the step line separator. If the step line separator is not specified, the value equals to lines-terminated-by by default. |
| output-fields-terminated-by | Outputs the step field separator. If the step field separator is not specified, the value equals to fields-terminated-by by default. |
| output-lines-terminated-by | Outputs the step line separator. If the step line separator is not specified, the value equals to lines-terminated-by by default. |
| trans | Specifies the conversion steps. The value is the directory where the conversion step file is located. When the relative directory of file is specified, the file is by default stored in the directory where the sqoop2-shell script is located. When the attribute is set, the other extended attributes can be ignored. |
Interconnecting Sqoop1 with MRS
- Download the open source Sqoop from https://www.apache.org/dyn/closer.lua/sqoo:p/1.4.7.
- Save the downloaded sqoop-1.4.7.bin__hadoop-2.6.0.tar.gz package to the /opt/sqoop directory on the Master node in the MRS cluster and decompress the package.
tar zxvf sqoop-1.4.7.bin__hadoop-2.6.0.tar.gz
- Go to the directory where the package is decompressed and modify the configuration.
cd /opt/sqoop/sqoop-1.4.7.bin__hadoop-2.6.0/conf
cp sqoop-env-template.sh sqoop-env.sh
vi sqoop-env.sh
Add the following configurations:
export HADOOP_COMMON_HOME=/opt/client/HDFS/hadoop export HADOOP_MAPRED_HOME=/opt/client/HDFS/hadoop export HIVE_HOME=/opt/Bigdata/MRS_1.9.X/install/FusionInsight-Hive-3.1.0/hive (Enter the actual path.) export HIVE_CONF_DIR=/opt/client/Hive/config export HCAT_HOME=/opt/client/Hive/HCatalog
- Add the system variable SQOOP_HOME to PATH.
vi /etc/profile
Add the following information:
export SQOOP_HOME=/opt/sqoop/sqoop-1.4.7.bin__hadoop-2.6.0 export PATH=$PATH:$SQOOP_HOME/bin
- Run the following command to copy the jline-2.12.jar file to the lib file.
cp /opt/share/jline-2.12/jline-2.12.jar /opt/sqoop/sqoop-1.4.7.bin__hadoop-2.6.0/lib
- Run the following command to add the following configuration to the file.
vim $JAVA_HOME/jre/lib/security/java.policy
permission javax.management.MBeanTrustPermission "register";
- Run the following command to interconnect sqoop1 with MRS.
source /etc/profile
