File Output
Overview
The File Output operator uses delimiters to concatenate existing fields and exports new fields to a file.
Input and Output
  • Input: fields to be exported
  • Output: files
Parameter Description
Table 1 Operator parameters description
Type
Mandatory
Default Value
Output delimiter
Set a delimiter.
string
Yes
None
Line breaker
Line delimiter, which can be any string specified by users based on the actual situation. Any character string is supported. The OS line delimiter is used by default.
string
No
\n
Output fields
Information about output fields:
  • position: Position of output fields.
  • field name: Names of output fields.
  • type: Field type. If type is set to DATE, TIME, or TIMESTAMP, you must specify a time format. If type is set to other values, the time format is invalid. The example time format is yyyyMMdd HH:mm:ss.
  • length: Field value length. If the actual field value is excessively long, the value is cut based on the configured length. When type is set to CHAR, spaces are added to the field value for supplement if the actual field value length is less than the configured length. When type is set to VARCHAR, no space is added to the field value for supplement if the actual field value length is less than the configured length.
map
No
None
Data Processing Rule
The field is exported to a file.
Example
Use the CSV File Input operator to generate two fields A and B.
The following figure shows the source file.
aaa,product
bbb,Bigdata
Configure the File Output operator, set Output delimiter to a comma (,), and export A and B to a file, as shown in the following figure.
The following figure shows the result.
aaa,product
bbb,Bigdata
