Access Control of a Dynamic Table View on Hive
This section describes how to create a view on Hive when MRS is configured in security mode, authorize access permissions to different users, and specify that different users access different data.
In the view, Hive can obtain the built-in function current_user() of the users who submit tasks on the client and filter the users. This way, authorized users can only access specific data in the view.
In normal mode, the current_user() function cannot distinguish users who submit tasks on the client. Therefore, the access control function takes effect only for Hive in security mode.
If the current_user() function is used in the actual service logic, the possible risks must be fully evaluated during the conversion between the security mode and normal mode.
Operation Example
- If the current_user function is not used, different views need to be created for different users to access different data.
- Authorize the view v1 permission to user hiveuser1. The user hiveuser1 can access data with type set to hiveuser1 in table1.
create view v1 as select * from table1 where type='hiveuser1';
- Authorize the view v2 permission to user hiveuser2. The user hiveuser2 can access data with type set to hiveuser2 in table1.
create view v2 as select * from table1 where type='hiveuser2';
- If the current_user function is used, only one view needs to be created.
Authorize the view v permission to users hiveuser1 and hiveuser2. When user hiveuser1 queries view v, the current_user() function is automatically converted to hiveuser1. When user hiveuser2 queries view v, the current_user() function is automatically converted to hiveuser2.
create view v as select * from table1 where type=current_user();
