Updated on 2026-06-27 GMT+08:00
MapReduce Log Overview
Log Description
Log paths:
  • JobhistoryServer: /var/log/Bigdata/mapreduce/jobhistory (run log) and /var/log/Bigdata/audit/mapreduce/jobhistory (audit log)
  • Container: /srv/BigData/hadoop/data1/nm/containerlogs/application_${appid}/container_{$contid}
The logs of running tasks are stored in the preceding paths. After the running is complete, the system determines whether to aggregate the logs to an HDFS directory based on the YARN configuration. For details, see Common YARN Parameters.
Log archive rule:
The automatic compression and archive function is enabled for MapReduce logs. By default, a log file is automatically compressed when the size of the log file is greater than 50 MB. The name of the compressed log file is in the following format: <Name of the original log>-<yyyy-mm-dd_hh-mm-ss>.[NO.].log.zip. A maximum of 100 latest compressed files are reserved. The number of compressed files can be configured on the parameter configuration page.
In MapReduce, JobhistoryServer cleans the old log files stored in HDFS periodically. The default storage directory is /mr-history/done. mapreduce.jobhistory.max-age-ms is used to set the cleanup interval. The default value of this parameter is 1,296,000,000 ms, which indicates 15 days.
Table 1 MapReduce log list
Type
Name
Run log
jhs-daemon-start-stop.log
Startup log file of the daemon process
hadoop-<SSH_USER>-jhshadaemon-<hostname>.log
Run log file of the daemon process
hadoop-<SSH_USER>-<process_name>-<hostname>.out
Log that records the MapReduce running environment information
historyserver-<SSH_USER>-<DATE>-<PID>-gc.log
Log that records the garbage collection of the MapReduce service
jhs-haCheck.log
Log that records the active and standby status of MapReduce instances
yarn-start-stop.log
Log that records the startup and stop of the MapReduce service
yarn-prestart.log
Log that records cluster operations before the MapReduce service startup
yarn-postinstall.log
Work log before the MapReduce service startup and after the installation
yarn-cleanup.log
Log that records the cleanup logs about the uninstallation of the MapReduce service
mapred-service-check.log
Log that records the health check details of the MapReduce service
container_{$contid}
Container log
hadoop-<SSH_USER>-<process_name>-<hostname>.log
MR run log
mapred-switch-jhs.log
MR active/standby switchover log
env.log
Environment information log before the instance is started or stopped
Audit log
mapred-audit-jobhistory.log
MapReduce operation audit log
SecurityAuth.audit
MapReduce security audit log
Log Level
Table 2 describes the log levels supported by MapReduce The log levels are FATAL, ERROR, WARN, INFO, and DEBUG from high priority to low. Logs whose levels are higher than or equal to the specified level are printed. The number of printed logs decreases as the specified log level increases.
Table 2 Log level
Level
FATAL
Logs of this level record critical error information about the current event processing.
ERROR
Logs of this level record error information about the current event processing.
WARN
Logs of this level record unexpected alarm information about the current event processing.
INFO
Logs of this level record normal running status information about the system and events.
DEBUG
Logs of this level record the system information and system debugging information.
To modify log levels, perform the following operations:
  1. Go to the All Configurations page of the MapReduce service. For details, see Modifying Cluster Service Configuration Parameters.
  2. On the left menu bar, select the log menu of the target role.
  3. Select a desired log level.
  4. Save the configuration. In the displayed dialog box, click OK to make the configurations take effect.
    The configurations take effect immediately without restarting the service.
Log Format
The following table lists the MapReduce log formats.
Table 3 Log format
Type
Format
Example
Run log
<yyyy-MM-dd HH:mm:ss,SSS>|<Log level>|<Name of the thread that generates the log>|<Message in the log>|<Location where the log event occurs>
2020-01-26 14:18:59,109 | INFO | main | Client environment:java.compiler=<NA> | org.apache.zookeeper.Environment.logEnv(Environment.java:100)
Audit log
2020-01-26 14:24:43,605 | INFO | main-EventThread | USER=omm OPERATION=refreshAdminAcls TARGET=AdminService RESULT=SUCCESS | org.apache.hadoop.yarn.server.resourcemanager.RMAuditLogger$LogLevel$6.printLog(RMAuditLogger.java:91)
