Overview of HDFS File System Directories
Hadoop Distributed File System (HDFS) implements reliable and distributed read/write of massive amounts of data. HDFS is applicable to the scenario where data read/write features "write once and read multiple times". However, the write operation is performed in sequence, that is, it is a write operation performed during file creation or an adding operation performed behind the existing file. HDFS ensures that only one caller can perform write operation on a file but multiple callers can perform read operation on the file at the same time.
Table 1 describes the directory structure in HDFS.
| Path | Type | Function | Whether the Directory Can Be Deleted | Deletion Consequence |
| Fixed directory | Stores temporary files of metastore sessions in Spark JDBCServer. | No | Failed to run the task. |
| /tmp/sparkhive-scratch | Fixed directory | Stores temporary files of metastore sessions that are executed using the Spark CLI. | No | Failed to run the task. |
| /tmp/logs/ | Fixed directory | Stores container log files. | Yes | Container logs cannot be viewed. |
| /tmp/carbon/ | Fixed directory | Stores abnormal CarbonData data that is detected during data import. | Yes | Error data is lost. |
| /tmp/Loader-${Job name}_${MR job ID} | Temporary directory | Stores region information for Loader HBase bulk load jobs. The data is automatically deleted once the job completes. | No | Failed to run the Loader HBase bulk load job. |
| /tmp/hadoop-omm/yarn/system/rmstore | Fixed directory | Stores the ResourceManager running information. | Yes | Status information is lost after ResourceManager restarts. |
| /tmp/archived | Fixed directory | Archives the MR task logs on HDFS. | Yes | MR task logs are lost. |
| /tmp/hadoop-yarn/staging | Fixed directory | Stores the run logs, summary information, and configuration attributes of ApplicationMaster jobs. | No | Tasks are not running properly. |
| /tmp/hadoop-yarn/staging/history/done_intermediate | Fixed directory | Stores temporary files in the /tmp/hadoop-yarn/staging directory after all tasks are executed. | No | MR task logs are lost. |
| /tmp/hadoop-yarn/staging/history/done | Fixed directory | The periodic scan thread periodically moves the done_intermediate log file to the done directory. | No | MR task logs are lost. |
| /tmp/mr-history | Fixed directory | Stores the historical record files that are pre-loaded. | No | Historical MR task log data is lost. |
| /tmp/hive-scratch | Fixed directory | Stores temporary data (such as session information) generated during Hive running. | No | Failed to run the current task. |
| /user/{user}/.sparkStaging | Fixed directory | Stores temporary files of the SparkJDBCServer application. | No | Failed to start the executor. |
| /user/spark2x/jars | Fixed directory | Stores dependency packages required for running the Spark2x executor. | No | Failed to start the executor. |
| /user/loader | Fixed directory | Stores dirty data of Loader jobs and data of HBase jobs. | No | Failed to execute the HBase job. Or dirty data is lost. |
| /user/loader/etl_dirty_data_dir | ||||
| /user/loader/etl_hbase_putlist_tmp | ||||
| /user/loader/etl_hbase_tmp | ||||
| /user/oozie | Fixed directory | Stores dependent libraries required for Oozie running. You need to manually upload the libraries. | No | Oozie scheduling failed. |
| /user/mapred/hadoop-mapreduce-xxx.tar.gz | Fixed files | Stores JAR packages used by the distributed MR cache. | No | The MR distributed cache function is unavailable. |
| /user/hive | Fixed directory | Default directory for storing Hive-related data, including the dependent Spark lib package and default table data storage path. | No | User data is lost. |
| /user/omm-bulkload | Temporary directory | Temporary directory of the HBase batch import tool. | No | HBase batch import tasks failed. |
| /user/hbase | Temporary directory | Temporary directory of the HBase batch import tool. | No | HBase batch import tasks failed. |
| Fixed directory | Stores Spark event log data. | No | The History Server service is unavailable, and task execution failed. |
| /flume | Fixed directory | Stores data collected by Flume from HDFS. | No | Flume is not running properly. |
| /mr-history/tmp | Fixed directory | Stores logs generated by MapReduce jobs. | Yes | Log information is lost. |
| /mr-history/done | Fixed directory | Stores logs managed by MR JobHistory Server. | Yes | Log information is lost. |
| /tenant | Created when a tenant is added. | Directory in the HDFS for a tenant. By default, the system automatically creates a folder in the /tenant directory based on the tenant name. For example, the default HDFS storage directory for ta1 is tenant/ta1. When a tenant is created for the first time, the system automatically creates the /tenant directory in the HDFS root directory. You can customize the storage path. | No | The tenant account is unavailable. |
| /apps{1~5}/ | Fixed directory | Stores the Hive package used by WebHCat. | No | Failed to run the WebHCat tasks. |
| /hbase | Fixed directory | Stores HBase data. | No | HBase user data is lost. |
| /hbaseFileStream | Fixed directory | Stores HFS files. | No | The HFS files are lost and cannot be recovered. |
Checking File System Directories
You can log in to the HDFS client and check the directories by referring to the following operations:
- The client has been installed, for example, in the /opt/client directory.
For details about how to download and install the cluster client, see Installing an MRS Cluster Client.
- Log in to the node where the client is installed as the client installation user.
- Go to the client installation directory.
cd /opt/client - Configure environment variables.
source bigdata_env
- If Kerberos authentication has been enabled for the cluster (in security mode), run the command for user authentication. User authentication is not required for clusters with Kerberos authentication disabled.
kinit Component service user
- Check the HDFS system directory.
hdfs dfs -ls Folder name
For example, run the following command to view file information in the / directory of the HDFS system:
hdfs dfs -ls /
The command output is as follows:
... drwxrwxrwx - mapred hadoop 0 2025-03-10 21:47 /mr-history drwxrwxrwx - hdfs hadoop 0 2025-03-10 21:47 /mrs drwx--x--x - admin supergroup 0 2025-03-10 21:47 /tenant drwxrwxrwx - hdfs hadoop 0 2025-03-10 21:50 /tmp drwxrwxrwx - hdfs hadoop 0 2025-03-10 21:51 /user ...
Helpful Links
- After a quota is set for a directory, file write operations may fail with the error message "The DiskSpace quota of /tmp/tquota2 is exceeded." To resolve this issue, see Failed to Write Files Because the HDFS Directory Quota Is Insufficient.
- MRS allows you to set a limit on the number of files in a single directory to prevent task failures caused by exceeding the threshold. For details, see Configuring the Number of Files in a Single HDFS Directory.
- For more information about HDFS and its enhanced features, see HDFS.
