Updated on 2026-06-27 GMT+08:00
Using the Flink Client
This section describes how to use Flink to run wordcount jobs.
  • Flink has been installed in an MRS cluster.
  • The cluster runs properly and the client has been correctly installed, for example, in the /opt/hadoopclient directory. The client directory in the following operations is only an example. Change it to the actual installation directory.
  1. Install a client.
    The following uses installing a Flink client on a node in the cluster as an example:
    1. Log in to FusionInsight Manager, choose Cluster, click the name of the desired cluster, click More, and select Download Client.
    2. In the Download Cluster Client dialog box that is displayed, select Complete Client for Select Client Type, select the platform type that matches the architecture of the node where the client is to install, select Save to Path, and click OK.
      • The generated file is stored in the /tmp/FusionInsight-Client directory on the active management node by default.
      • The name of the client software package is in the following format: FusionInsight_Cluster_<Cluster ID>_Services_Client.tar. In this section, the cluster ID 1 is used as an example. Replace it with the actual cluster ID.
    3. Log in to the server where the client is to be installed as the client installation user.
    4. Go to the directory where the installation package is stored and run the following commands to decompress the package:
      cd /tmp/FusionInsight-Client
      tar -xvf FusionInsight_Cluster_1_Services_Client.tar
    5. Run the following command to verify the decompressed file and check whether the command output is consistent with the information in the sha256 file:
      sha256sum -c FusionInsight_Cluster_1_Services_ClientConfig.tar.sha256
      FusionInsight_Cluster_1_Services_ClientConfig.tar: OK
    6. Decompress the obtained installation file.
      tar -xvf FusionInsight_Cluster_1_Services_ClientConfig.tar
    7. Go to the directory where the installation package is stored, and run the following command to install the client to a specified directory (absolute path), for example, /opt/hadoopclient:
      cd /tmp/FusionInsight-Client/FusionInsight_Cluster_1_Services_ClientConfig
      ./install.sh /opt/hadoopclient
      The client is installed if information similar to the following is displayed:
      The component client is installed successfully
  2. Log in to the node where the client is installed as the client installation user.
  3. Run the following command to go to the client installation directory:
    cd /opt/hadoopclient
  4. Run the following command to initialize environment variables:
    source /opt/hadoopclient/bigdata_env
  5. Perform the following operations if Kerberos authentication is enabled for the cluster. Otherwise, skip these operations.
    1. Prepare a user for submitting Flink jobs.
      Log in to FusionInsight Manager and choose System > Permission > Role. Click Create Role and configure Role Name and Description. In Configure Resource Permission, choose Name of the desired cluster > Flink and select FlinkServer Admin Privilege. Then click OK.
      Choose System > Permission > User and click Create. Specify Username, set User Type to Human-Machine, specify Password and Confirm Password, add user groups hadoop, yarnviewgroup, and hadoopmanager as needed, add roles System_administrator, default, and the one you created, and click OK. (If you create a Flink job user for the first time, log in to FusionInsight Manager as the user and change the password.)
    2. Log in to Manager and download the authentication credential.
      Log in to Manager and choose System > Permission > User. On the displayed page, locate the row that contains the added user, click More in the Operation column, and select Download Authentication Credential.
      Figure 1 Downloading the authentication credential
    3. Decompress the downloaded authentication credential package and copy the obtained file to the client node, for example, the /opt/hadoopclient/Flink/flink/conf directory. If the client is installed on a node outside the cluster, copy the obtained files to the /etc/ directory on the node.
    4. Add the service IP address of the node where the client is installed and IP address of the master node to the jobmanager.web.access-control-allow-origin and jobmanager.web.allow-access-address configuration items in the /opt/hadoopclient/Flink/flink/conf/flink-conf.yaml file. Use commas (,) to separate the IP addresses.
      jobmanager.web.access-control-allow-origin: xx.xx.xxx.xxx,xx.xx.xxx.xxx,xx.xx.xxx.xxx
      jobmanager.web.allow-access-address: xx.xx.xxx.xxx,xx.xx.xxx.xxx,xx.xx.xxx.xxx
      To obtain the service IP address of the node where the client is installed, perform the following operations:
      • Node inside the cluster:
        In the navigation pane of the MRS management console, choose Active Clusters, select a cluster, and click its name to switch to the cluster details page.
        On the Nodes tab page, view the IP address of the node where the client is installed.
      • Node outside the cluster: IP address of the ECS where the client is installed.
    5. Configure security authentication by adding the keytab path and username in the /opt/hadoopclient/Flink/flink/conf/flink-conf.yaml configuration file.
      security.kerberos.login.keytab: <user.keytab file path>
      security.kerberos.login.principal: <Username>
      Example:
      security.kerberos.login.keytab: /opt/hadoopclient/Flink/flink/conf/user.keytab
      security.kerberos.login.principal: test
    6. Configure security hardening by referring to Configuring Flink Authentication and Encryption. Perform the following operations to set a password for submitting jobs:
      • If security.ssl.encrypt.enabled is true (default value) in the flink-conf.yaml file, the operations are as follows:
        • Obtain the encrypted password.
          Run the following command to obtain the password using the FusionInsight Manager plaintext encryption API:
          curl -k -i -u user name:password -X POST -HContent-type:application/json  -d '{"plainText":"password"}' 'https://x.x.x.x:28443/web/api/v2/tools/encrypt'
          In the command, user name and password indicate the current login username and password. password for plainText indicates the password for invoking the generate_keystore.sh script. x.x.x.x indicates the floating IP address of FusionInsight Manager. Commands carrying authentication passwords pose security risks. Disable historical command recording before running such commands to prevent information leakage.
        • Set a password.
          In the /opt/hadoopclient/Flink/flink/conf/flink-conf.yaml configuration file, set the encrypted password in security.ssl.key-password, security.ssl.keystore-password, and security.ssl.truststore-password.
      • If security.ssl.encrypt.enabled is false in the flink-conf.yaml file, the operations are as follows:
        The script automatically changes the SSL-related parameter values in the /opt/hadoopclient/Flink/flink/conf/flink-conf.yaml file.
        cd /opt/hadoopclient/Flink/flink/bin
        sh generate_keystore.sh
      After the script is executed, the flink.keystore and flink.truststore files are generated in the conf directory on the Flink client. In the flink-conf.yaml file, default values are specified for following parameters:
      • Parameter security.ssl.keystore is set to the absolute path of the flink.keystore file.
      • Parameter security.ssl.truststore is set to the absolute path of the flink.truststore file.
      • Parameter security.cookie is set to a random password automatically generated by the generate_keystore.sh script.
    7. Configure paths for the client to access the flink.keystore and flink.truststore files.
      • Relative path (recommended):
        Perform the following steps to set the file path of flink.keystore and flink.truststore to the relative path and ensure that the directory where the Flink client command is executed can directly access the relative paths.
        1. Create a directory, for example, ssl, in /opt/hadoopclient/Flink/flink/conf/.
          cd /opt/hadoopclient/Flink/flink/conf/
          mkdir ssl
        2. Move the flink.keystore and flink.truststore files to the /opt/hadoopclient/Flink/flink/conf/ssl/ directory.
          mv flink.keystore ssl/
          mv flink.truststore ssl/
        3. Change the values of the following parameters to relative paths in the flink-conf.yaml file:
          security.ssl.keystore: ssl/flink.keystore
          security.ssl.truststore: ssl/flink.truststore
      • Absolute path:
        After the generate_keystore.sh script is executed, the file path of flink.keystore and flink.truststore is automatically set to the absolute path /opt/hadoopclient/Flink/flink/conf/ in the flink-conf.yaml file. In this case, you need to move the flink.keystore and flink.truststore files from the conf directory to this absolute path on the Flink client and YARN nodes.
  6. Run a wordcount job.
    To submit or run jobs on Flink, the user must have the following permissions:
    • If Ranger authentication is enabled, the current user must belong to the hadoop group or the user has been granted the /flink read and write permissions in Ranger.
    • If Ranger authentication is disabled, the current user must belong to the hadoop group.
    • For a normal cluster (Kerberos authentication disabled), you can submit jobs in either of the following ways:
      • Run the following commands to start a session and submit a job in the session:
        yarn-session.sh -nm "session-name" -d
        flink run /opt/hadoopclient/Flink/flink/examples/streaming/WordCount.jar
      • Run the following command to submit a single job on Yarn:
        flink run -m yarn-cluster /opt/hadoopclient/Flink/flink/examples/streaming/WordCount.jar
    • For a security cluster (Kerberos authentication enabled), you can submit jobs in either of the following ways based on the paths of the flink.keystore and flink.truststore files:
      • If the flink.keystore and flink.truststore files are stored in the relative path:
        • Run the following command in the directory at the same level as ssl to start the session and submit the job in the session:
          ssl is a relative path. For example, if ssl is in opt/hadoopclient/Flink/flink/conf/, run the command in the opt/hadoopclient/Flink/flink/conf/ directory.
          yarn-session.sh -t ssl/ -nm "session-name" -d
          flink run -m yarn-cluster -yt ssl/ /opt/hadoopclient/Flink/flink/examples/streaming/WordCount.jar
      • If the flink.keystore and flink.truststore files are stored in the absolute path:
  7. After the job has been successfully submitted, the following information is displayed on the client:
    Figure 2 Job submitted successfully on Yarn
    Figure 3 Session started successfully
    Figure 4 Job submitted successfully in the session
  8. Go to the native page of the YARN service, find the application of the corresponding job, and click the application name to go to the job details page.
    • If the job is not completed, click Tracking URL to go to the native Flink page and view the job running information.
    • If the job submitted in a session has been completed, you can click Tracking URL to log in to the native Flink service page to view job information.
      Figure 5 application
