Typical Hue Parameters
Page Access
Go to the All Configurations page of the Hue service by referring to Modifying Cluster Service Configuration Parameters.
Parameter Description
For details about Hue common parameters, see Table 1.
| Configuration | Description | Default Value | Value Range |
| HANDLER_ACCESSLOG_LEVEL | Hue access log level. | DEBUG |
| HANDLER_AUDITSLOG_LEVEL | Hue audit log level. | DEBUG |
| HANDLER_ERRORLOG_LEVEL | Hue error log level. | ERROR |
| HANDLER_LOGFILE_LEVEL | Hue run log level. | INFO |
| HANDLER_LOGFILE_MAXBACKUPINDEX | Maximum number of Hue log files. | 20 | 1 to 999 |
| HANDLER_LOGFILE_SIZE | Maximum size of a Hue log file. | 5 MB | - |
For details about Hue custom parameters, see Table 2. The following custom parameters are available only for MRS 3.1.2 or later.
| dfs.customized.configs | Custom configuration item added to the global configuration file hdfs-site.xml. |
| hbase.customized.configs | Custom configuration item added to the global configuration file hbase-site.xml. |
| hive.customized.configs | Custom configuration item added to the global configuration file hive-site.xml. |
