Help Center/
MapReduce Service/
Component Operation Guide (LTS)/
Using HetuEngine/
HetuEngine Common SQL Syntax Description/
Auxiliary Command Syntax/
USE
USE
Syntax
- USE catalog.schema
- USE schema
This statement is used to specify the catalog and schema used by the current session. If the catalog is not specified, the current catalog is used by default.
Example
To specify the current session to the schema named test in the Hive catalog:
USER hive.test
Precautions
None
Parent topic: Auxiliary Command Syntax
