Date and Time Functions and Operators
Date and Time Operators
Operator
Example
Result
date '2012-08-08' + interval '2' day
2012-08-10
time '01:00' + interval '3' hour
04:00:00.000
timestamp '2012-08-08 01:00' + interval '29' hour
2012-08-09 06:00:00.000
timestamp '2012-10-31 01:00' + interval '1' month
2012-11-30 01:00:00.000
interval '2' day + interval '3' hour
2 03:00:00.000
interval '3' year + interval '5' month
3-5
date '2012-08-08' - interval '2' day
2012-08-06
time '01:00' - interval '3' hour
22:00:00.000
timestamp '2012-08-08 01:00' - interval '29' hour
2012-08-06 20:00:00.000
timestamp '2012-10-31 01:00' - interval '1' month
2012-09-30 01:00:00.000
interval '2' day - interval '3' hour
1 21:00:00.000
interval '3' year - interval '5' month
2-7
Time Zone Conversion
Operator: AT TIME ZONE sets the time zone of a timestamp.
SELECT timestamp '2012-10-31 01:00 UTC';-- 2012-10-31 01:00:00.000 UTC
SELECT timestamp '2012-10-31 01:00 UTC' AT TIME ZONE 'Asia/Singapore'; -- 2012-10-30 09:00:00.000 Asia/Singapore
Date/Time Functions
  • current_date -> date
    Returns the current date (UTC time zone).
    select current_date; -- 2020-07-25
  • current_time -> time with time zone
    Returns the current time (UTC time zone).
    select current_time;-- 16:58:48.601+08:00
  • current_timestamp -> timestamp with time zone
    Returns the current timestamp (current time zone).
    select current_timestamp; -- 2020-07-25 11:50:27.350 Asia/Singapore
  • current_timezone() → varchar
    Returns the current time zone.
    select current_timezone();-- Asia/Singapore
  • date(x) → date
    Converts a date literal to a variable of the date type.
    select date('2020-07-25');-- 2020-07-25
  • from_iso8601_timestamp(string) → timestamp with time zone
    Converts a timestamp literal in ISO 8601 format into a timestamp variable with a time zone.
    SELECT from_iso8601_timestamp('2020-05-11');-- 2020-05-11 00:00:00.000 Asia/Singapore
    SELECT from_iso8601_timestamp('2020-05-11T11:15:05'); -- 2020-05-11 11:15:05.000 Asia/Singapore
    SELECT from_iso8601_timestamp('2020-05-11T11:15:05.055+01:00');-- 2020-05-11 11:15:05.055 +01:00
  • from_iso8601_date(string) → date
    Converts a date literal in ISO 8601 format into a variable of the date type.
    SELECT from_iso8601_date('2020-05-11');-- 2020-05-11
    SELECT from_iso8601_date('2020-W10');-- 2020-03-02
    SELECT from_iso8601_date('2020-123');-- 2020-05-02
  • from_unixtime(unixtime) → timestamp with time zone
    Converts a UNIX timestamp to a timestamp variable (current time zone).
    Select FROM_UNIXTIME(1.595658735E9); -- 2020-07-25 14:32:15.000 Asia/Singapore
    Select FROM_UNIXTIME(875996580); --1997-10-05 04:23:00.000 Asia/Singapore
  • from_unixtime(unixtime, string) → timestamp with time zone
    Converts a UNIX timestamp into a timestamp variable. The time zone option can be contained.
    select from_unixtime(1.595658735E9, 'Asia/Singapore');-- 2020-07-25 14:32:15.000 Asia/Singapore
  • from_unixtime(unixtime, hours, minutes) → timestamp with time zone
    Converts a UNIX timestamp to a timestamp variable with a time zone. hours and minutes indicate the time zone offsets.
    select from_unixtime(1.595658735E9, 8, 30);-- 2020-07-25 14:32:15.000 +08:30
  • localtime -> time
    Obtains the current time
    select localtime;-- 14:16:13.096
  • localtimestamp -> timestamp
    Obtains the current timestamps.
    select localtimestamp;-- 2020-07-25 14:17:00.567
  • months_between(date1, date2) -> double
    Return the number of months between date1 and date2. If date1 is later than date2, the result is a positive number. Otherwise, the result is a negative number. If the days of the two dates are the same, the result is an integer. Otherwise, the decimal part is calculated based on the difference between the hour, minute, and second (31 days of each month). The type of date1 and date2 can be date, timestamp, or a string in the yyyy-MM-dd or yyyy-MM-dd HH:mm:ss format.
    select months_between('2020-02-28 10:30:00', '2021-10-30');-- -20.05040323
    select months_between('2021-01-30', '2020-10-30'); -- 3.0
  • now() → timestamp with time zone
    Obtains the current time, which is the alias of current_timestamp.
    select now();-- 2020-07-25 14:39:39.842 Asia/Singapore
  • unix_timestamp()
    Obtains the current unix timestamp.
    select unix_timestamp(); -- 1600930503
  • to_iso8601(x) → varchar
    Converts x into a character string in the ISO 8601 format. x can be DATE or TIMESTAMP [with time zone].
    select to_iso8601(date '2020-07-25'); -- 2020-07-25
    select to_iso8601(timestamp '2020-07-25 15:22:15.214'); -- 2020-07-25T15:22:15.214
  • to_milliseconds(interval) → bigint
    Obtains the number of milliseconds since 00:00 on the current day.
    select to_milliseconds(interval '8' day to second);-- 691200000
  • to_unixtime(timestamp) → double
    Converts the timestamp to the UNIX time.
    select to_unixtime(cast('2020-07-25 14:32:15.147' as timestamp));-- 1.595658735147E9
  • trunc(string date, string format) →string
    Truncates a date value based on the format. The supported format is MONTH/MON/MM or YEAR/YYYY/YY, QUARTER/Q
    select trunc(date '2020-07-08','yy');-- 2020-01-01
    select trunc(date '2020-07-08','MM');-- 2020-07-01
    You can use the parentheses () when using the following SQL standard functions:
    • current_date
    • current_time
    • current_timestamp
    • localtime
    • Localtimestamp
    For example: select current_date ();
Truncation Function
Similar to the operation of reserving decimal places, the date_trunc function supports the following units:
Unit
Value After Truncation
second
2001-08-22 03:04:05.000
minute
2001-08-22 03:04:00.000
hour
2001-08-22 03:00:00.000
day
2001-08-22 00:00:00.000
week
2001-08-20 00:00:00.000
month
2001-08-01 00:00:00.000
quarter
2001-07-01 00:00:00.000
year
2001-01-01 00:00:00.000
In the preceding example, the timestamp 2001-08-22 03:04:05.321 is used as the input.
date_trunc(unit, x) → [same as input]
Returns the value of x after the unit.
select date_trunc('hour', timestamp '2001-08-22 03:04:05.321'); -- 2001-08-22 03:00:00.000
Interval Functions
The functions in this chapter support the following interval units:
Unit
second
Seconds
minute
Minutes
hour
Hours
day
Days
week
Weeks
month
Months
quarter
Quarters of a year
year
Years
  • date_add(unit, value, timestamp) → [same as input]
    Add value units to timestamp. If you want to perform the subtraction operation, you can assign a negative value to the value.
    SELECT date_add('second', 86, TIMESTAMP '2020-03-01 00:00:00');-- 2020-03-01 00:01:26
    SELECT date_add('hour', 9, TIMESTAMP '2020-03-01 00:00:00');-- 2020-03-01 09:00:00
    SELECT date_add('day', -1, TIMESTAMP '2020-03-01 00:00:00 UTC');-- 2020-02-29 00:00:00 UTC
  • date_diff(unit, timestamp1, timestamp2) → bigint
    Returns the value of timestamp2 minus timestamp1. The unit of the value is unit.
    The value of unit is a character string. For example, day, week, and year.
    SELECT date_diff('second', TIMESTAMP '2020-03-01 00:00:00', TIMESTAMP '2020-03-02 00:00:00');-- 86400
    SELECT date_diff('hour', TIMESTAMP '2020-03-01 00:00:00 UTC', TIMESTAMP '2020-03-02 00:00:00 UTC');-- 24
    SELECT date_diff('day', DATE '2020-03-01', DATE '2020-03-02');-- 1
    SELECT date_diff('second', TIMESTAMP '2020-06-01 12:30:45.000', TIMESTAMP '2020-06-02 12:30:45.123');-- 86400
    SELECT date_diff('millisecond', TIMESTAMP '2020-06-01 12:30:45.000', TIMESTAMP '2020-06-02 12:30:45.123');-- 86400123
  • adddate(date, bigint)→ [same as input]
    Description: Date addition. The input type can be date or timestamp, indicating that the date is added or deducted. If the input type is subtraction, the value of bigint is negative.
    select ADDDATE(timestamp '2020-07-04 15:22:15.124',-5);-- 2020-06-29 15:22:15.124
    select ADDDATE(date '2020-07-24',5); -- 2020-07-29
Duration Function
The duration can use the following units:
Unit
ns
nanosecond
us
microsecond
ms
millisecond
s
second
m
minute
h
hour
d
day
parse_duration(string) → interval
SELECT parse_duration('42.8ms'); -- 0 00:00:00.043
SELECT parse_duration('3.81 d'); -- 3 19:26:24.000
SELECT parse_duration('5m'); -- 0 00:05:00.000
MySQL Date Functions
The formatted strings that are compatible with the MySQL date_parse and str_to_date methods in this section.
  • date_format(timestamp, format) → varchar
    Uses format to format timestamp.
    select date_format(timestamp '2020-07-22 15:00:15', '%Y/%m/%d');-- 2020/07/22
  • date_parse(string, format) → timestamp
    Parses the date literals using format.
    select date_parse('2020/07/20', '%Y/%m/%d');-- 2020-07-20 00:00:00.000
The following table is based on the MySQL manual and describes various format descriptors.
Format Descriptor
%a
Day in a week (Sun .. Sat)
%b
Month (Jan .. Dec)
%c
Month (1 .. 12)
%D
Day of the month (0th, 1st, 2nd, 3rd, ...)
%d
Day in the month (01.. 31) (Two digits. Zeros are added before the single digits.)
%e
Day in the month (1 .. 31)
%f
Seconds after the decimal point (6 digits for printing: 000000 .. 999000; 1 - 9 digits for parsing: 0 .. 999999999)
%H
Hour (00 .. 23)
%h
Hour (01.. 12)
%I
Hour (01.. 12)
%i
Minute, number (00 .. (59)
%j
Day of the year (001 .. 366)
%k
Hour (0 .. 23)
%l
Hour (1.. 12)
%M
Month name (January .. December)
%m
Month, number (01 .. 12)
%p
AM or PM
%r
Time in the 12-hour format (hh:mm:ss followed by AM or PM)
%S
Second (00 .. 59)
%s
Second (00 .. 59)
%T
Time in the 24-hour format (hh:mm:ss)
%U
Week (00 .. 53) Sunday is the first day of a week.
%u
Week (00 .. 53) Monday is the first day of a week.
%V
Week (01.. 53) Sunday is the first day of a week. Used together with %X.
%v
Week (01 .. 53) Monday is the first day of a week. Used together with %X.
%W
Day of the week (Sunday .. Saturday)
%w
Day of the week (0.. 6) Sunday is the first day of a week.
%X
Year, a four-digit number. The first day is Sunday.
%x
Year, a four-digit number. The first day is Monday.
%Y
%y
Year. The value is a two-digit number ranging from 1970 to 2069.
Indicates the character '%'.
Example:
select date_format(timestamp '2020-07-25 15:04:00.124','%j day of a year with English suffix (0th, 1st, 2nd, 3rd...),%m month %d day,%p %T %W');
                       _col0
 207th day of the year, 25th day of July, PM 15:04:00 Saturday
(1 row)
These format descriptors are not supported: %D, %U, %u, %V, %w, %X.
    Parses the timestamp character string.
Java Date Functions
The formatting strings used in this section are compatible with the Java SimpleDateFormat style.
  • format_datetime(timestamp, format) → varchar
  • parse_datetime(string, format) → timestamp with time zone
    Format a string to timestamp with time zone in a specified format.
    select parse_datetime('1960/01/22 03:04', 'yyyy/MM/dd HH:mm');
                     _col0
     1960-01-22 03:04:00.000 Asia/Shanghai
    (1 row)
Common Extraction Functions
Domain
YEAR
year()
QUARTER
quarter()
MONTH
month()
WEEK
week()
DAY
day()
DAY_OF_MONTH
day_of_month()
DAY_OF_WEEK
day_of_week()
DOW
day_of_week()
DAY_OF_YEAR
day_of_year()
DOY
day_of_year()
YEAR_OF_WEEK
year_of_week()
YOW
year_of_week()
HOUR
hour()
MINUTE
minute()
SECOND
second()
TIMEZONE_HOUR
timezone_hour()
TIMEZONE_MINUTE
timezone_minute()
Example:
select second(timestamp '2020-02-12 15:32:33.215');-- 33
select timezone_hour(timestamp '2020-02-12 15:32:33.215');-- 8
  • MONTHNAME(date)
    Description: Obtains the month name.
    SELECT monthname(timestamp '2019-09-09 12:12:12.000');-- SEPTEMBER
    SELECT monthname(date '2019-07-09');--JULY
  • extract(field FROM x) → bigint
    Description: Returns the field from x. For details about the corresponding field, see the table in this document.
    select extract(YOW FROM timestamp '2020-02-12 15:32:33.215');-- 2020
    select extract(SECOND FROM timestamp '2020-02-12 15:32:33.215');-- 33
    select extract(DOY FROM timestamp '2020-02-12 15:32:33.215');--43
Function
Example
SECONDS_ADD(TIMESTAMP date, INT seconds)
SELECT seconds_add(timestamp '2019-09-09 12:12:12.000', 10);
The time is added in seconds.
SECONDS_SUB(TIMESTAMP date, INT seconds)
SELECT seconds_sub(timestamp '2019-09-09 12:12:12.000', 10);
Subtracts time in seconds.
MINUTES_ADD(TIMESTAMP date, INT minutes)
SELECT MINUTES_ADD(timestamp '2019-09-09 12:12:12.000', 10);
Add the time in the unit of minute.
MINUTES_SUB(TIMESTAMP date, INT minutes)
SELECT MINUTES_SUB(timestamp '2019-09-09 12:12:12.000', 10);
The time is subtracted in the unit of minute.
HOURS_ADD(TIMESTAMP date, INT hours)
SELECT HOURS_ADD(timestamp '2019-09-09 12:12:12.000', 1);
Add the time in the unit of hour.
HOURS_SUB(TIMESTAMP date, INT hours)
SELECT HOURS_SUB(timestamp '2019-09-09 12:12:12.000', 1);
The time is subtracted in hours.
  • last_day(timestamp) -> date
    Description: Returns the last day of each month based on the specified timestamp.
    SELECT last_day(timestamp '2019-09-09 12:12:12.000');--  2019-09-30
    SELECT last_day(date '2019-07-09');--2019-07-31
  • add_months(timestamp) -> [same as input]
    Description: Returns the correct date by adding the specified date to the specified month.
    SELECT add_months(timestamp'2019-09-09 00:00:00.000', 11);-- 2020-08-09 00:00:00.000
  • next_day() (timestamp, string) -> date
    Description: Returns the next day of the specified weekday based on the specified date.
    SELECT next_day(timestamp'2019-09-09 00:00:00.000', 'monday');-- 2019-09-16 00:00:00.000
    SELECT next_day(date'2019-09-09', 'monday');-- 2019-09-16
  • numtoday(integer) -> BIGINT
    Description: Converts transferred integer values to values of the day type, for example, BIGINT.
    SELECT numtoday(2);-- 2
