SELECT
Syntax
[/*+ query_rewrite_hint*/]
[ WITH [ RECURSIVE ] with_query [, ...] ]
SELECT [ ALL | DISTINCT ] select_expression [, ...]
[ FROM from_item [, ...] ]
[ WHERE condition ]
[ GROUP BY [ ALL | DISTINCT ] grouping_element [, ...] ]
[ HAVING condition]
[ { UNION | INTERSECT | EXCEPT } [ ALL | DISTINCT ] select ]
[ ORDER BY expression [ ASC | DESC ] [, ...] ]
[ OFFSET count [ ROW | ROWS ] ]
[ LIMIT { count | ALL } ]
[ FETCH { FIRST | NEXT } [ count ] { ROW | ROWS } { ONLY | WITH TIES } ]
  • from_item can be used in the following formats:
    • table_name [ [ AS ] alias [ ( column_alias [, ...] ) ] ]
    • from_item join_type from_item [ ON join_condition | USING ( join_column [, ...] ) ]
      MATCH_RECOGNIZE pattern_recognition_specification
  • join_type can be used in the following formats:
    • [ INNER ] JOIN
    • LEFT [ OUTER ] JOIN
    • RIGHT [ OUTER ] JOIN
    • FULL [ OUTER ] JOIN
    • LEFT [SEMI] JOIN
    • RIGHT [SEMI] JOIN
    • LEFT [ANTI] JOIN
    • RIGHT [ANTI] JOIN
    • CROSS JOIN
  • grouping_element can be:
    • expression
    • GROUPING SETS ( ( column [, ...] ) [, ...] )
    • CUBE ( column [, ...] )
    • ROLLUP ( column [, ...] )
This statement is used to retrieve row data from zero or more tables.
Query the content of the stu table.
SELECT id,name FROM stu;
