Help Center/
MapReduce Service/
Component Operation Guide (LTS)/
Using HetuEngine/
HetuEngine Common SQL Syntax Description/
DDL Syntax/
SHOW CREATE TABLE
SHOW CREATE TABLE
Syntax
SHOW CREATE TABLE table_name
This statement is used to display the SQL creating statement for a specified data table.
Example
To display the SQL statements that can be used to create the table orders:
CREATE TABLE orders ( orderkey bigint, orderstatus varchar, totalprice double, orderdate date ) WITH (format = 'ORC', location='/user',orc_compress='ZLIB',external=true, "auto.purge"=false); show create table orders; Create Table ------------------------------------------------- CREATE TABLE hive.default.orders ( orderkey bigint, orderstatus varchar, totalprice double, orderdate date ) WITH ( external_location = 'hdfs://hacluster/user', format = 'ORC', orc_compress = 'ZLIB', orc_compress_size = 262144, orc_row_index_stride = 10000, orc_stripe_size = 67108864 ) (1 row)
Parent topic: DDL Syntax
