Help Center/
MapReduce Service/
Component Operation Guide (LTS)/
Using HetuEngine/
HetuEngine Common SQL Syntax Description/
SQL Functions and Operators/
IP Address Functions
contains(network, address) → boolean
If the CIDR network contains the address value, true is returned.
SELECT contains('10.0.0.0/8', IPADDRESS '10.255.255.255'); -- true SELECT contains('10.0.0.0/8', IPADDRESS '11.255.255.255'); -- false SELECT contains('2001:0db8:0:0:0:ff00:0042:8329/128', IPADDRESS '2001:0db8:0:0:0:ff00:0042:8329'); -- true SELECT contains('2001:0db8:0:0:0:ff00:0042:8329/128', IPADDRESS '2001:0db8:0:0:0:ff00:0042:8328'); -- false
Parent topic: SQL Functions and Operators
