Updated on 2024-05-29 GMT+08:00
Syntax Compatibility of Common Data Sources
Syntax
Hive
MPPDB
Elasticsearch
HBase
HetuEngine (Cross-domain)
ClickHouse
Hudi
MySQL
show schemas of databases
Y
Y
Y
Y
Y
Y
Y
Y
create schema of databases
Y
Y
N
Y
N
N
Y
N
use schema of databases
Y
Y
Y
Y
Y
Y
Y
Y
alter schema of databases
Y
N
N
N
N
N
N
N
drop schema of databases
Y
Y
Y
Y
N
N
Y
N
show tables/show create table/show functions/show session of tables
Y
Y
Y
Y
Y
Y
Y
Y
create of tables
Y
Y
N
Y
N
N
N
N
create table TABLENAME as of tables
Y
Y
Y
Y
N
N
N
N
insert into TABLENAME values of tables
Y
Y
Y
Y
Y
N
N
N
insert into TABLENAME select of tables
Y
Y
Y
Y
Y
N
N
N
insert overwrite TABLENAME values of tables
Y
N
N
N
N
N
N
N
insert overwrite TABLENAME select of tables
Y
N
N
N
N
N
N
N
alter of tables
Y
Y
N
N
N
N
N
N
select of tables
Y
Y
Y
Y
Y
Y
Y
Y
update of tables
Y
Y
Y
N
N
N
N
N
delete of tables
Y
Y
Y
Y
N
N
N
N
drop of tables
Y
N
Y
Y
Y
N
N
N
desc/describe TABLENAME of tables
Y
Y
Y
Y
Y
Y
Y
Y
analyze of tables
Y
Y
Y
N
N
N
Y
N
comment of tables
Y
N
N
N
N
N
N
N
explain of tables
Y
Y
Y
Y
Y
N
Y
N
show stats of tables
Y
Y
Y
N
N
N
Y
N
show columns of tables
Y
Y
Y
Y
Y
Y
Y
Y
select column of tables
Y
Y
Y
Y
Y
Y
Y
Y
create view of views
Y
Y
N
N
N
N
N
N
create or replace view of views
Y
N
N
N
N
N
N
N
alter of views
Y
N
N
N
N
N
N
N
drop of views
Y
N
N
N
N
N
N
N
select of views
Y
Y
N
N
Y
Y
Y
Y
desc/describe VIEWNAME of views
Y
Y
N
N
Y
Y
Y
Y
show views/show create view of views
Y
Y
N
N
N
Y
Y
Y
show columns of views
Y
Y
Y
Y
Y
Y
Y
Y
select column of views
Y
Y
Y
Y
Y
Y
Y
Y
