Updated on 2026-09-08 GMT+08:00
CLI Command Reference
Cluster Management
API Name
Command
Operation
Hibernating a Cluster
hcloud CCE HibernateCluster
This API is used to hibernate a running cluster. After a cluster is hibernated, master node resources stop being billed.
Go debug
Waking Up a Cluster
hcloud CCE AwakeCluster
This API is used to wake up a hibernated cluster. After the cluster is woken up, master node resources continue to be billed.
Go debug
Obtaining a Cluster Certificate
hcloud CCE CreateKubernetesClusterCert
This API is used to obtain a certificate of a specified cluster.
Go debug
Revoking a Cluster Certificate of a User
hcloud CCE RevokeKubernetesClusterCert
This API is used to revoke a certificate of a specified cluster.
Go debug
Rotating the Cluster Certificate of a User
hcloud CCE RotateClusterCredentials
This API is used to rotate certificates of a specified cluster.
Go debug
Listing Clusters in a Specified Project
hcloud CCE ListClusters
This API is used to obtain details about all clusters in a specified project.
Go debug
Creating a Cluster
hcloud CCE CreateCluster
This API is used to create an empty cluster, which has only master nodes but no worker nodes. After creating a cluster by calling this API, you can add nodes by creating nodes.
Go debug
Reading a Specified Cluster
hcloud CCE ShowCluster
This API is used to obtain details about a specified cluster.
Go debug
Updating a Specified Cluster
hcloud CCE UpdateCluster
This API is used to update information about a specified cluster.
Go debug
Deleting a Cluster
hcloud CCE DeleteCluster
This API is used to delete a specified cluster.
Go debug
Modifying Cluster Specifications
hcloud CCE ResizeCluster
This API is used to modify the specifications of a cluster.
Go debug
Querying a Job
hcloud CCE ShowJob
This API is used to obtain information about a job via the job ID returned after a query request is delivered.
Go debug
Binding/Unbinding Public API Server Address
hcloud CCE UpdateClusterEip
This API is used to bind or unbind the public API server address of the cluster by cluster ID.
Go debug
Obtaining Cluster Access Address
hcloud CCE ShowClusterEndpoints
This API is used to obtain the cluster access addresses by cluster ID, including the private IP (VIP returned by an HA cluster) and public IP.
Go debug
Obtaining the Global OBS Access Secret of a Cluster
hcloud CCE GetClusterLongAkskConfig
This API is used to obtain the global OBS access secret of a cluster.
Go debug
Updating the Global OBS Access Secret of a Cluster
hcloud CCE UpdateClusterLongAkskConfig
This API is used to update the global OBS access secret of a cluster.
Go debug
Obtaining the Global OBS Access Secret of a Project
hcloud CCE GetLongAkskConfig
This API is used to obtain the global OBS access secret of a project.
Go debug
Updating the Global OBS Access Secret of a Project
hcloud CCE UpdateLongAkskConfig
This API is used to update the global OBS access secret of a project.
Go debug
Obtaining Available Cluster Flavors
hcloud CCE GetClusterFlavorSpecs
This API is used to obtain the available cluster flavors.
Go debug
Obtaining the Feature Gate Status
hcloud CCE ShowFeatureGates
This API is used to obtain the feature gate status.
Go debug
Obtaining a Cluster's Logging Configurations
hcloud CCE ShowClusterConfig
This API is used to obtain LTS configurations reported by the cluster components.
Go debug
Configuring Cluster Logs
hcloud CCE UpdateClusterLogConfig
This API is used to select the master node components whose logs are reported to LTS.
Go debug
Obtaining the AZ List
hcloud CCE GetAvaliableZone
This API is used to obtain the AZ list.
Go debug
Obtaining Cluster Quotas
hcloud CCE GetClusterQuota
This API is used to obtain the cluster quotas.
Go debug
Obtaining Partition Details
hcloud CCE ShowPartition
This API is used to obtain partition details.
Go debug
Updating a Partition
hcloud CCE UpdatePartition
This API is used to update a partition.
Go debug
Obtaining the Partition List
hcloud CCE ListPartitions
This API is used to obtain the partition list.
Go debug
Creating a Partition
hcloud CCE CreatePartition
This API is used to create a partition.
Go debug
Node Management
API Name
Command
Operation
Listing All Nodes in a Cluster
hcloud CCE ListNodes
This API is used to obtain details about all nodes in a specified cluster with the cluster ID.
Go debug
Creating a Node
hcloud CCE CreateNode
This API is used to create a node in a specified cluster.
Go debug
Reading a Specified Node
hcloud CCE ShowNode
This API is used to obtain details about a specified node via the node ID.
Go debug
Updating a Specified Node
hcloud CCE UpdateNode
This API is used to update information about a specified node.
Go debug
Deleting a Node
hcloud CCE DeleteNode
This API is used to delete a specified node.
Go debug
Accepting a Node
hcloud CCE AddNode
This API is used to accept a node into a specified cluster.
Go debug
Rotating node certificates
hcloud CCE RotateNodeCert
This API is used to rotate node certificates in a specified cluster. Compensation mechanism for cluster certificate rotation: When the matching cluster certificate rotation API is used to rotate certificates, if the certificates of some nodes fail to be rotated, you can call this API to retry.
Go debug
Resetting a Node
hcloud CCE ResetNode
This API is used to reset a node in a specified cluster.
Go debug
Removing a Node
hcloud CCE RemoveNode
This API is used to remove a node from a specified cluster.
Go debug
Enabling Scale-In Protection for a Node.
hcloud CCE LockNodepoolNodeScaleDown
This API is used to enable scale-in protection for a node. A node with scale-in protection enabled cannot be removed by simply changing the number of nodes in the node pool.
Go debug
Disabling Scale-In Protection for a Node.
hcloud CCE UnlockNodepoolNodeScaleDown
This API is used to disable scale-in protection for a node. A node with scale-in protection disabled can be removed by changing the number of nodes in the node pool. Scale-in protection can be disabled only for pay-per-use nodes.
Go debug
Migrating a Node
hcloud CCE MigrateNode
This API is used to migrate a node from a specified cluster to another cluster.
Go debug
Changing the Billing Mode of a Node to Yearly/Monthly
hcloud CCE BatchChangeNodeToPeriod
This API is used to change the billing mode of a node from pay-per-use to yearly/monthly.
Go debug
Migrating a Node to a Custom Node Pool
hcloud CCE MigrateToNodePool
This API is used to migrate a node to a custom node pool. Only nodes in the default node pool can be migrated. Throughout the migration process, the node will remain unaffected and will not require resetting or restarting. Additionally, the original password will be preserved.
Go debug
sync node
hcloud CCE SyncNode
This API is used to synchronize nodes.
Go debug
Synchronizing Nodes in Batches
hcloud CCE BatchSyncNodes
This API is used to synchronize nodes in batches.
Go debug
Obtaining the Supernode List in a Cluster
hcloud CCE ListHyperNodes
This API is used to obtain details about all supernodes in a specified cluster.
Go debug
Managing a Node in a Customized Node Pool
hcloud CCE AddNodesToNodePool
This API is used to manage a node in a customized node pool of a cluster. Spot instances are not supported.
Go debug
Node Pool Management
API Name
Command
Operation
Listing All Node Pools in a Specified Cluster
hcloud CCE ListNodePools
This API is used to obtain information about all node pools in a specified cluster.
Go debug
Creating a Node Pool
hcloud CCE CreateNodePool
This API is used to create a node pool in a specified cluster. This API can be called only when the cluster is in the available, scaling-out, or scaling-in state.
Go debug
Reading a Specified Node Pool
hcloud CCE ShowNodePool
This API is used to obtain details about a specified node pool.
Go debug
Updating a Specified Node Pool
hcloud CCE UpdateNodePool
This API is used to update a specified node pool. This API can be called only when the cluster is in the available, scale-out, or scale-in state.
Go debug
Deleting a Node Pool
hcloud CCE DeleteNodePool
This API is used to delete a specified node pool.
Go debug
Node Pool Upgrade
hcloud CCE UpgradeNodePool
This API is used to synchronize the configurations of existing nodes in a node pool.
Go debug
Scaling a Node Pool
hcloud CCE ScaleNodePool
This API is used to scale in or out a node pool.
Go debug
Add-on Management
API Name
Command
Operation
Listing Add-on Instances
hcloud CCE ListAddonInstances
This API is used to list all add-on instances in the cluster.
Go debug
Installing an Add-on Instance
hcloud CCE CreateAddonInstance
This API is used to install an add-on instance by using an add-on template.
Go debug
Listing Add-on Templates
hcloud CCE ListAddonTemplates
This API is used to query add-on templates.
Go debug
Querying an Add-on Instance
hcloud CCE ShowAddonInstance
This API is used to obtain details about an add-on instance.
Go debug
Updating an Add-on Instance
hcloud CCE UpdateAddonInstance
This API is used to update an add-on instance.
Go debug
Deleting an Add-on Instance
hcloud CCE DeleteAddonInstance
This API is used to delete an add-on instance.
Go debug
Rolling Back an Add-on Instance
hcloud CCE RollbackAddonInstance
Roll back the add-on instance version to the source version. Only when the status.isRollbackable parameter is set to true, and the add-on instance is in the running, available, abnormal, upgradeFailed, or rollbackFailed state, the version can be rolled back to the source version.
Go debug
Creating Add-on Check Tasks in Batches
hcloud CCE BatchCreateAddonPrecheck
This API is used to create add-on check tasks in batches in a specified cluster.
Go debug
Obtaining the Add-on Check Task Results
hcloud CCE ListAddonPrecheckTasks
This API is used to obtain the results of the add-on check tasks in a cluster.
Go debug
Cluster Upgrade
API Name
Command
Operation
Cluster upgrade
hcloud CCE UpgradeCluster
Cluster upgrade
Go debug
Obtaining Cluster Upgrade Task Details
hcloud CCE ShowUpgradeClusterTask
Upgrade task ID, obtained from the uid field in the response body after the cluster upgrade API is called.
Go debug
Retrying a Cluster Upgrade Task
hcloud CCE RetryUpgradeClusterTask
Execute the failed cluster upgrade task again.
Go debug
Suspending a Cluster Upgrade Task
hcloud CCE PauseUpgradeClusterTask
Suspend the cluster upgrade task.
Go debug
Continue to execute the cluster upgrade task.
hcloud CCE ContinueUpgradeClusterTask
Resume the suspended cluster upgrade task.
Go debug
Enabling the Cluster Upgrade Process Booting Task
hcloud CCE CreateUpgradeWorkFlow
This API is used to create a cluster upgrade booting task. After the booting task is created by calling this API, start the check through the cluster pre-upgrade check.
Go debug
Obtaining a List of Upgrade Workflows
hcloud CCE ListUpgradeWorkFlows
Obtain a list of historical cluster upgrade booting tasks.
Go debug
Backing Up a Cluster
hcloud CCE CreateClusterMasterSnapshot
Cluster backup
Go debug
Obtaining a List of Cluster Upgrade Task Details
hcloud CCE ListUpgradeClusterTasks
Obtain a list of cluster upgrade task details.
Go debug
Performing a Pre-upgrade Check
hcloud CCE CreatePreCheck
Pre-upgrade check
Go debug
Obtaining Details About a Pre-upgrade Check Task of a Cluster
hcloud CCE ShowPreCheck
Obtain details about a pre-upgrade check task of a cluster. The task ID is obtained from the uid field in the response body after the cluster check API is called.
Go debug
Obtaining a List of Pre-upgrade Check Tasks of a Cluster
hcloud CCE ListPreCheckTasks
Obtain a list of pre-upgrade check tasks of a cluster.
Go debug
Obtaining the Cluster Upgrade Information
hcloud CCE ShowClusterUpgradeInfo
Obtain the cluster upgrade information.
Go debug
Obtaining a List of Cluster Backup Task Details
hcloud CCE ListClusterMasterSnapshotTasks
Obtain a list of cluster backup task details.
Go debug
Obtaining Details About a Specified Cluster Upgrade Task
hcloud CCE ShowUpgradeWorkFlow
This API is used to obtain details about an upgrade booting task based on the task ID.
Go debug
Updating the Status of a Specified Cluster Upgrade Booting Task
hcloud CCE UpgradeWorkFlowUpdate
This API is used to update the status of a specified cluster upgrade booting task. This API applies only to the upgrade cancellation process.
Go debug
Obtaining the Configuration of Cluster Upgrade Feature Gates
hcloud CCE ListClusterUpgradeFeatureGates
Obtain the configuration of cluster upgrade feature gates.
Go debug
Performing a Post-upgrade Check
hcloud CCE CreatePostCheck
Post-upgrade check, which is used by the customer to check the cluster status after an upgrade and provide feedback after services are restored. Use this API with the console.
Go debug
Obtaining a Cluster Upgrade Path
hcloud CCE ListClusterUpgradePaths
Obtain the cluster upgrade path.
Go debug
Quota Management
API Name
Command
Operation
Querying Resource Quotas
hcloud CCE ShowQuotas
This API is used to query CCE resource quotas.
Go debug
API Versions
API Name
Command
Operation
Listing API Versions
hcloud CCE ShowVersion
This API is used to query the list of API versions supported by CCE.
Go debug
Tag Management
API Name
Command
Operation
Adding Resource Tags to a Specified Cluster in Batches
hcloud CCE BatchCreateClusterTags
This API is used to add resource tags for a specified cluster in batches.
Go debug
Deleting Resource Tags of a Specified Cluster in Batches
hcloud CCE BatchDeleteClusterTags
This API is used to delete resource tags of a specified cluster in batches.
Go debug
Obtaining Resource Tags
hcloud CCE GetResourceTags
This API is used to obtain resource tags.
Go debug
Obtaining Custom Tags
hcloud CCE GetCustomizeTags
This API is used to obtain custom tags.
Go debug
Obtaining Node Labels
hcloud CCE GetLabels
This API is used to obtain the labels of all nodes in a cluster.
Go debug
Configuration Management
API Name
Command
Operation
Obtaining the Parameters That Can Be Configured for a Node Pool
hcloud CCE ShowNodePoolConfigurations
This API is used to obtain the parameters that can be configured for a node pool.
Go debug
Changing the Values of Configuration Parameters of a Node Pool
hcloud CCE UpdateNodePoolConfiguration
This API is used to change the values of parameter configurations of a node pool in the CCE cluster.
Go debug
hcloud CCE ShowNodePoolConfigurationDetails
This API is used to obtain the parameters that can be configured in a specified CCE node pool.
Go debug
Obtaining the List of Configurable Parameters Supported by a Cluster
hcloud CCE ShowClusterSupportConfiguration
This API is used to obtain the detailed configuration items supported by a cluster based on factors like the cluster version or type. It is specified during cluster creation.
Go debug
Obtaining the List of Parameters That Can Be Configured for a Cluster
hcloud CCE ShowClusterConfigurationDetails
This API is used to obtain the list of parameters that can be configured for a CCE cluster.
Go debug
Chart Management
API Name
Command
Operation
Obtaining a Chart List
hcloud CCE ListCharts
This API is used to obtain the chart list.
Go debug
Uploading a Chart
hcloud CCE UploadChart
This API is used to upload a chart.
Go debug
Obtaining a Chart
hcloud CCE ShowChart
This API is used to obtain a chart.
Go debug
Updating a Chart
hcloud CCE UpdateChart
This API is used to update a chart.
Go debug
Deleting a Chart
hcloud CCE DeleteChart
This API is used to delete a chart.
Go debug
Downloading a Chart
hcloud CCE DownloadChart
This API is used to download a chart.
Go debug
Obtaining Chart Values
hcloud CCE ShowChartValues
This API is used to obtain chart values.
Go debug
Obtaining the Quota of a User Chart
hcloud CCE ShowUserChartsQuotas
This API is used to obtain the quota of a user chart.
Go debug
Obtaining a Release List
hcloud CCE ListReleases
This API is used to obtain a release list.
Go debug
Creating a Release
hcloud CCE CreateRelease
This API is used to create a release.
Go debug
Obtaining a Release
hcloud CCE ShowRelease
This API is used to obtain a release.
Go debug
Updating a Release
hcloud CCE UpdateRelease
This API is used to update a release.
Go debug
Deleting a Release
hcloud CCE DeleteRelease
This API is used to delete a release.
Go debug
Obtaining Historical Records of a Release
hcloud CCE ShowReleaseHistory
This API is used to obtain historical records of a release.
Go debug
Permissions Management
API Name
Command
Operation
Creating an Access Policy
hcloud CCE CreateAccessPolicy
This API is used to create an access policy.
Go debug
Obtaining the Access Policy List
hcloud CCE ListAccessPolicy
This API is used to obtain the access policy list.
Go debug
Obtaining Access Policy Details
hcloud CCE GetAccessPolicy
This API is used to obtain an access policy.
Go debug
Updating an Access Policy
hcloud CCE UpdateAccessPolicy
This API is used to update an access policy.
Go debug
Deleting an Access Policy
hcloud CCE DeleteAccessPolicy
This API is used to delete an access policy.
Go debug
Create pod-identity association
hcloud CCE CreatePodIdentityAssociation
This API is used to create pod-identity association, in which service account in certain cluster is bound to agency
Go debug
Obtaining the pod-identity association list in certain cluster
hcloud CCE ListPodIdentityAssociations
The API is used to obtain the pod-identity association list in certain cluster
Go debug
Obtaining pod-identity association detail
hcloud CCE ShowPodIdentityAssociation
The API is used to obtain pod-identity association detail
Go debug
Update pod-identity association
hcloud CCE UpdatePodIdentityAssociation
The API is used to update agency attribute of a pod-identity association
Go debug
Delete pod-identity association
hcloud CCE DeletePodIdentityAssociation
The API is used to delete a pod-identity association
Go debug
Assume for temporary credentials of pod-identity association
hcloud CCE AssumeAgencyForPodIdentity
The API is used to assume for temporary credentials of pod-identity association
Go debug
