Updated on 2026-09-07 GMT+08:00
CLI Command Reference
Image Cache Management
API Name
Command
Operation
Creating an Image Cache
hcloud CCE CreateImageCache
This API is used to create an image cache. During the creation, a temporary pod is started for the image cache in the specified cluster. After the image cache is created, you can use it to greatly reduce the time required for downloading the container images during workload creation and quickly start the containers. A tenant can create a maximum of 50 image caches.
Go debug
Listing Image Caches
hcloud CCE ListImageCaches
Go debug
Viewing Details About an Image Cache
hcloud CCE ShowImageCache
This API is used to view the details about an image cache.
Go debug
Deleting an Image Cache
hcloud CCE DeleteImageCache
This API is used to delete an image cache.
Go debug
Cluster Management (Autopilot)
API Name
Command
Operation
Obtaining Clusters in a Project
hcloud CCE ListAutopilotClusters
This API is used to obtain details about all clusters in a project.
Go debug
Creating a Cluster
hcloud CCE CreateAutopilotCluster
This API is used to create an empty cluster, which has only master nodes but no worker nodes.
Go debug
Obtaining a Cluster
hcloud CCE ShowAutopilotCluster
This API is used to obtain details about a cluster.
Go debug
Updating a Cluster
hcloud CCE UpdateAutopilotCluster
This API is used to update a cluster.
Go debug
Deleting a Cluster
hcloud CCE DeleteAutopilotCluster
This API is used to delete a cluster.
Go debug
Obtaining a Cluster Certificate
hcloud CCE CreateAutopilotKubernetesClusterCert
This API is used to obtain the certificate of a cluster.
Go debug
Obtaining Job Information
hcloud CCE ShowAutopilotJob
This API is used to obtain information about a job via the job ID returned after a query request is delivered.
Go debug
Binding/Unbinding Public API Server Address
hcloud CCE UpdateAutopilotClusterEip
This API is used to bind or unbind the public API server address of the cluster by cluster ID.
Go debug
Obtaining Cluster Access Address
hcloud CCE ShowAutopilotClusterEndpoints
This API is used to obtain the cluster access addresses by cluster ID, including the private IP and public IP.
Go debug
Obtaining Cluster Log Configurations
hcloud CCE ShowAutopilotClusterConfig
This API is used to obtain LTS configurations reported by cluster components.
Go debug
Obtaining the Feature Gate Status
hcloud CCE ShowAutopilotFeatureGates
This API is used to obtain the feature gate status.
Go debug
Add-on Management (Autopilot)
API Name
Command
Operation
Listing Add-on Instances
hcloud CCE ListAutopilotAddonInstances
This API is used to obtain all add-on instances in a cluster.
Go debug
Creating an Add-on Instance
hcloud CCE CreateAutopilotAddonInstance
This API is used to create an add-on instance using an add-on template.
Go debug
Listing Add-on Templates
hcloud CCE ListAutopilotAddonTemplates
This API is used to obtain an add-on template.
Go debug
Obtaining an Add-on Instance
hcloud CCE ShowAutopilotAddonInstance
This API is used to obtain details about an add-on instance.
Go debug
Updating an Add-on Instance
hcloud CCE UpdateAutopilotAddonInstance
This API is used to update an add-on instance.
Go debug
Deleting an Add-on Instance
hcloud CCE DeleteAutopilotAddonInstance
This API is used to delete an add-on instance.
Go debug
Rolling Back an Add-on Instance
hcloud CCE RollbackAutopilotAddonInstance
This API is used to roll back the version of an add-on instance to the source version. Only when status.isRollbackable is set to true, and the add-on instance is in the running, available, abnormal, upgradeFailed, or rollbackFailed state, the version can be rolled back to the source version.
Go debug
Cluster Upgrade (Autopilot)
API Name
Command
Operation
Upgrading a Cluster
hcloud CCE UpgradeAutopilotCluster
This API is used to upgrade a cluster.
Go debug
Obtaining Cluster Upgrade Task Details
hcloud CCE ShowAutopilotUpgradeClusterTask
This API is used to obtain details about an upgrade task of a cluster. The task ID is obtained from the uid field in the response body after the cluster upgrade API is called.
Go debug
Retrying a Cluster Upgrade Task
hcloud CCE RetryAutopilotUpgradeClusterTask
This API is used to execute the failed cluster upgrade task again.
Go debug
Obtaining a List of Cluster Upgrade Task Details
hcloud CCE ListAutopilotUpgradeClusterTasks
This API is used to obtain a list of cluster upgrade task details.
Go debug
Performing a Pre-upgrade Check for a Cluster
hcloud CCE CreateAutopilotPreCheck
This API is used to perform a pre-upgrade check for a cluster.
Go debug
Obtaining Details About a Pre-upgrade Check Task of a Cluster
hcloud CCE ShowAutopilotPreCheck
This API is used to obtain details about a pre-upgrade check task of a cluster. The task ID is obtained from the uid field in the response body after the cluster check API is called.
Go debug
Obtaining a List of Pre-upgrade Check Tasks of a Cluster
hcloud CCE ListAutopilotPreCheckTasks
This API is used to obtain a list of pre-upgrade check tasks of a cluster.
Go debug
Performing a Post-upgrade Check for a Cluster
hcloud CCE CreateAutopilotPostCheck
This API is used to perform a post-upgrade check for a cluster, which is used by the customer to check the cluster status after an upgrade and provide feedback after services are restored. Use this API with the console.
Go debug
Backing Up a Cluster
hcloud CCE CreateAutopilotClusterMasterSnapshot
This API is used to back up a cluster.
Go debug
Obtaining a List of Cluster Backup Task Details
hcloud CCE ListAutopilotClusterMasterSnapshotTasks
This API is used to obtain a list of cluster backup task details.
Go debug
Obtaining the Cluster Upgrade Information
hcloud CCE ShowAutopilotClusterUpgradeInfo
This API is used to obtain the cluster upgrade information.
Go debug
Obtaining a Cluster Upgrade Path
hcloud CCE ListAutopilotClusterUpgradePaths
This API is used to obtain the cluster upgrade path.
Go debug
Obtaining the Configuration of Cluster Upgrade Feature Gates
hcloud CCE ListAutopilotClusterUpgradeFeatureGates
This API is used to obtain the configuration of cluster upgrade feature gates.
Go debug
Enabling the Cluster Upgrade Process Booting Task
hcloud CCE CreateAutopilotUpgradeWorkFlow
This API is used to create a cluster upgrade booting task. After the booting task is created by calling this API, start the check through the cluster pre-upgrade check.
Go debug
Obtaining a List of Upgrade Workflows
hcloud CCE ListAutopilotUpgradeWorkFlows
This API is used to obtain a list of historical cluster upgrade booting tasks.
Go debug
Obtaining Details About a Specified Cluster Upgrade Booting Task
hcloud CCE ShowAutopilotUpgradeWorkFlow
This API is used to obtain details about an upgrade booting task based on the task ID.
Go debug
Updating the Status of a Specified Cluster Upgrade Booting Task
hcloud CCE UpgradeAutopilotWorkFlowUpdate
This API is used to update the status of a specified cluster upgrade booting task. This API applies only to the upgrade cancellation process.
Go debug
Obtaining an Automatic Upgrade Plan
hcloud CCE ListAutopilotUpgradePlans
This API is used to obtain an automatic cluster upgrade plan.
Go debug
Postponing an Automatic Upgrade Plan
hcloud CCE UpdateAutopilotUpgradePlan
This API is used to postpone an automatic cluster upgrade plan.
Go debug
Quota Management (Autopilot)
API Name
Command
Operation
Obtaining CCE Resource Quotas
hcloud CCE ShowAutopilotQuotas
This API is used to get CCE resource quotas.
Go debug
Tag Management (Autopilot)
API Name
Command
Operation
Adding Resource Tags to a Cluster in Batches
hcloud CCE BatchCreateAutopilotClusterTags
This API is used to add resource tags to a cluster in batches.
Go debug
Deleting Resource Tags from a Cluster in Batches
hcloud CCE BatchDeleteAutopilotClusterTags
This API is used to delete resource tags from a cluster in batches.
Go debug
Chart Management (Autopilot)
API Name
Command
Operation
Obtaining a Chart List
hcloud CCE ListAutopilotCharts
This API is used to obtain a chart list.
Go debug
Uploading a Chart
hcloud CCE UploadAutopilotChart
This API is used to upload a chart.
Go debug
Obtaining a Release List
hcloud CCE ListAutopilotReleases
This API is used to obtain a release list.
Go debug
Creating a Release
hcloud CCE CreateAutopilotRelease
This API is used to create a release.
Go debug
Obtaining a Chart
hcloud CCE ShowAutopilotChart
This API is used to obtain a chart.
Go debug
Updating a Chart
hcloud CCE UpdateAutopilotChart
This API is used to update a chart.
Go debug
Deleting a Chart
hcloud CCE DeleteAutopilotChart
This API is used to delete a chart.
Go debug
Obtaining a Release
hcloud CCE ShowAutopilotRelease
This API is used to obtain a release.
Go debug
Updating a Release
hcloud CCE UpdateAutopilotRelease
This API is used to update a release.
Go debug
Deleting a Release
hcloud CCE DeleteAutopilotRelease
This API is used to delete a release.
Go debug
Downloading a Chart
hcloud CCE DownloadAutopilotChart
This API is used to download a chart.
Go debug
Obtaining Chart Values
hcloud CCE ShowAutopilotChartValues
This API is used to obtain chart values.
Go debug
Obtaining Historical Records of a Release
hcloud CCE ShowAutopilotReleaseHistory
This API is used to obtain historical records of a release.
Go debug
Obtaining the Quota of a User Chart
hcloud CCE ShowAutopilotUserChartsQuotas
This API is used to obtain the quota of a user chart.
Go debug
Job Management (Autopilot)
API Name
Command
Operation
Listing Jobs
hcloud CCE ListAutopilotJobs
This API is used to obtain all jobs in a specified project.
Go debug
Querying a Job
hcloud CCE GetAutopilotOneJob
This API is used to query the details of a job in a specified project.
Go debug
Deleting a Job
hcloud CCE DeleteAutopilotJob
This API is used to delete a job in a specified project.
Go debug
