Updated on 2026-01-09 GMT+08:00
hour
This function is used to return the hour (from 0 to 23) of a specified time.
Syntax
hour(string date)
Parameters
Table 1 Parameter
Mandatory
Type
date
Yes
DATE
or
STRING
Date that needs to be processed
The following formats are supported:
  • yyyy-mm-dd
  • yyyy-mm-dd hh:mi:ss
  • yyyy-mm-dd hh:mi:ss.ff3
Return Values
The return value is of the INT type.
  • If the value of date is not of the DATE or STRING type, the error message "data type mismatch" is displayed.
  • If the value of date is of the DATE or STRING type but is not in one of the supported formats, NULL is returned.
  • If the value of date is NULL, NULL is returned.
Example Code
The value 10 is returned.
select hour('2023-08-10 10:54:00');
The value 12 is returned.
select hour('12:00:00');
The value NULL is returned.
select hour('20230810105600');
select hour(null);
