Exporting Subnet List
Information about all subnets under your account can be exported as an Excel file to a local directory. This file records the name, ID, VPC, CIDR block, and associated route table of each subnet.
- Click
in the upper left corner and choose Network > Virtual Private Cloud. The Virtual Private Cloud page is displayed.
- In the navigation pane on the left, choose Virtual Private Cloud > Subnets.
The Subnets page is displayed.
- In the subnet list, select one or more subnets you want to export and click Export in the upper left corner.
The system will automatically export information about all of your subnets as an Excel file to a local directory.
