Deleting a VPC
If you no longer need a VPC, you can delete it.
If you want to delete a VPC that has subnets, custom routes, or other resources, you need to delete these resources as prompted on the console first and then delete the VPC.
- Click
in the upper left corner and select the region and project. - Click
in the upper left corner and choose Network > Virtual Private Cloud. The Virtual Private Cloud page is displayed.
- On the Virtual Private Cloud page, locate the row that contains the VPC to be deleted and click Delete in the Operation column.
A confirmation dialog box is displayed.
- Confirm the information and click Yes.
If the VPC cannot be deleted, the console displays a message. Delete the resources that are using the VPC by referring to Why Can't I Delete My VPCs and Subnets?.
